Slammed Third Gens - Post Pics
Old May 27, 2012 | 10:00 AM
  #351
KonArtist's Avatar
Car: 1992 Camaro z28
Engine: 350 HSR
Axle/Gears: 3.42's
Re: Slammed Third Gens - Post Pics
Originally Posted by itsMikey
wheels fellas wheels..not rims
its rimzz lol
Old May 27, 2012 | 04:01 PM
  #352
1bad406's Avatar
Car: 1987 Camaro
Engine: 406
Transmission: Powerglide
Axle/Gears: Moser 31 spline / 4.86
Mine isn't slammed, but about as low as I want it.
Old May 27, 2012 | 10:41 PM
  #353
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
Originally Posted by 1bad406
Mine isn't slammed,
Old May 28, 2012 | 02:42 AM
  #354
DBLTKE's Avatar
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
So I threw on some GTA wheels with stock sized 245/50/16 tires. Tire pressures at 40psi. Turns out my car is lower than I though. Dead nuts even at 24".
So, who's gonna grow a pair and try to dip into the 23" range?
Old May 28, 2012 | 07:32 AM
  #355
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Put a set of stock height tires on it and see where you are, your tires aren't even 24" tall and stock.p is 25.7. Your not as low as you think. (Suspension wise). I noticed my firestone tires are only 24.5" tall even.though they are 245/50/16 as well. I understand that with the tall sidewall and airpressures the tire will buldg at the bottom.from.weight, but that's a lot.
I like how your car looks with the gta wheels
Old May 28, 2012 | 10:20 AM
  #356
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
Thanks for the compliments everyone! It's a good feeling when people say good things about your car! Yeah it took almost 2 years to get her like I wanted. Yes it is a 3 stage candy apple red paint job. If you think the pics are sweet....you should see it pop in the sunlight!
Yeah the shaved handles and taking off the side moldings really cleaned things up.
Thx again all!!!
Old May 28, 2012 | 12:09 PM
  #357
87350IROC's Avatar
Car: 87' IROC
For reference, my Goodyear GS-D3 tires 245/50/16 are about 24.5" installed in the back and 24.25" tall installed in the front due to the weight differences on the tire. I have some pictures back on page 2.
Old May 28, 2012 | 01:33 PM
  #358
made2drag's Avatar
Car: 88 ta
Engine: tpi 305
im hoping to be in the 23" range soon....hey man, you have any pics of your car with the 80's corvette wheels? so far i havent seen that combo on a third gen....wondering how it looks
Old May 28, 2012 | 01:39 PM
  #359
87350IROC's Avatar
Car: 87' IROC
What is your plan for the radiator air dam? On my car, it scrapes at 23.25". No way you are going to be able to ride like that.
Old May 28, 2012 | 06:01 PM
  #360
DBLTKE's Avatar
Engine: LB9, LB9
It looks like ****. Lol. However they were on my GTI, so they have 205/40/16 tire on them.
A 3rd gen just doesn't look good with anything less than a 25" tire
Old May 28, 2012 | 06:05 PM
  #361
87350IROC's Avatar
Car: 87' IROC
I think he was referring to the fender height at 23" rather than the tire height. I think with proper sized tires those wheels could actually look pretty cool in an 80's kind of way.
Old May 29, 2012 | 08:15 AM
  #362
made2drag's Avatar
Car: 88 ta
Engine: tpi 305
i can trim the air dam....think outside the box...get it done
Old May 29, 2012 | 08:18 AM
  #363
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
If you trim the air dam it going to run warmer or hot.
  #364
made2drag's Avatar
Car: 88 ta
Engine: tpi 305
i agree...i do love those corvette wheels!....if only they had some meat on them....thanks for posting that...i kind of like the gta wheels the best.
Old May 29, 2012 | 08:21 AM
  #365
made2drag's Avatar
Car: 88 ta
Engine: tpi 305
oh, my bad....i just thought about how 3rd gens are...no airflow to the radiator due to the body...i guess even trimming a inch would cause trouble? thanks
Old May 29, 2012 | 08:26 AM
  #366
made2drag's Avatar
Car: 88 ta
Engine: tpi 305
man, i would love to see what the gti looked like with them! i had no idea they had the same lug pattern.
Old May 29, 2012 | 11:50 AM
  #367
87350IROC's Avatar
Car: 87' IROC
Hard to say. But trimming an inch means you are going to be scraping everywhere. You'd probably have to trim near 2" to be able to drive it. I would imagine trimming it 2" will cause serious cooling issues. On top of that, at 23" you'd have to make a skid plate for the oil pan and trans pan as you'd be sure to scrape it at some point.
Old May 29, 2012 | 12:52 PM
  #368
made2drag's Avatar
Car: 88 ta
Engine: tpi 305
ok, thanks for the info!
Old May 29, 2012 | 01:31 PM
  #369
DBLTKE's Avatar
Engine: LB9, LB9
They look a little better on the GTI
And some content to keep this on topic...
Old May 29, 2012 | 02:09 PM
  #370
b3x87's Avatar
Car: 1987 Trans Am
Engine: 5.7 V8
Transmission: Automatic
i love the lowering! i always wanted as my trans am.. im might get Eiach sportline lowering spring for my trans am.. i need get struts too?
i were had eiach sportlines lowering spring with kyb's 2 struts all around 2" drop i love the handle, saving gas, etc
that my old car. i still do again as my trans am too!
Old May 29, 2012 | 04:13 PM
  #371
made2drag's Avatar
Car: 88 ta
Engine: tpi 305
thanks DBLTKE!
Old May 29, 2012 | 06:43 PM
  #372
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Old May 29, 2012 | 07:38 PM
  #373
//<86TA>\\'s Avatar
Car: 86 Trans Am
Originally Posted by iansane
all im saying is that a stock height tire used to be 25.7", though i was pretty clear on that. With the shorter tire the car will be lower, (about 5/8" at least) thats all i said. I do find it strange that there are now 3 different tires listed here that are only 24.5" or so tall, even though they are all listed as being 25.7 on their manufactures spec list.
Old May 29, 2012 | 10:28 PM
  #374
RubberDucky's Avatar
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
I'm getting low this weekend. I've got some springs that outta bring it down. Looks like a 4x4 next to my S-Class.
Old May 30, 2012 | 08:56 AM
  #375
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
I have Sportlines on my car. It dropped it just enough for me. Michigan roads, I could not go any lower lol....And I really like the way my car sits. Don't forget your Sub frame connectors!!!!
Old May 30, 2012 | 09:05 PM
  #376
1Broke_camaro's Avatar
Car: 1992 Chevy Camaro
Engine: 350 TBi in the working
Transmission: 700R4 :(
todd you have one of the sexiest birds ive EVER seen. and seeing it what 2 years ago at the M&G over at bakers was amazing!!! your car sits perfect
Old May 30, 2012 | 10:24 PM
  #377
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Thank you Sir!!! I can't wait for this years meet and greet!! I hope to see you there!
Old May 31, 2012 | 05:29 AM
  #378
DBLTKE's Avatar
Engine: LB9, LB9
That is 2.5" of clearance. Which is also the same clearance i have to my front cross member.
Old May 31, 2012 | 08:09 AM
  #379
made2drag's Avatar
Car: 88 ta
Engine: tpi 305
question for you....im thinking that trimming the air dam could be done...here's why im thinking this....as we lower our cars the ground clearance gets smaller thus channelling more air towards the radiator and less under the dam. if you trim an inch (maybe 2) it would seem to me, since its so low, that there would still be more airflow than if it were at stock hieght.
yes if it were raised back to stock ride, it would have to be replaced.
another question...if our electric fans ran all the time and we trimmed the dam, it seems to me it wouldnt ever overheat.
Old May 31, 2012 | 08:13 AM
  #380
made2drag's Avatar
Car: 88 ta
Engine: tpi 305
that is exactly how low i want mine....nice pics....and still a untrimmed air dam?
Old May 31, 2012 | 08:46 AM
  #381
Car: 1989 Camaro RS
Engine: LH6
These were my thoughts exactly. I'm planning on running the fan to a switch inside the car so I can turn it on earlier, as well as a lower temp thermostat to allow it to cool off earlier before it gets too hot.
Old May 31, 2012 | 05:03 PM
  #382
made2drag's Avatar
Car: 88 ta
Engine: tpi 305
on the switch...make sure it is the highest amp switch you can find. like 30A or 40A or more. the fan will cause a weak switch to melt over time. i have heard of people wiring into their wiper motor on an s10. this made their fan run when the ignition was on.....do this at your own risk. i had a switch for my electric fan on my s10 that was done by the previous owner and sometimes i would forget to turn it on....and sometimes i would forget to turn it off if i parked in a loud area where i didnt hear it running after i walked away. had to jump it off later that night
Old May 31, 2012 | 05:52 PM
  #383
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
wire it up with a 35a bosh relay. This way the relay is taking the load and your "SWITCH" is only to supply power to the relay.
Better yet just get a fan switch that screws in place of the stock one to come on sooner.
Even better get your ecm programmed so the fans come on and off at the temps you want.
back on topic. I want to get a weight jack setup and drop mine more. Im on cut springs now.
Old May 31, 2012 | 07:53 PM
  #384
DBLTKE's Avatar
Engine: LB9, LB9
Stock, unaltered air dam.
Old Jun 1, 2012 | 08:55 AM
  #385
made2drag's Avatar
Car: 88 ta
Engine: tpi 305
sweet....thanks bro
Old Jun 9, 2012 | 10:45 PM
  #386
Zach/90\irocZ's Avatar
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
pics just for fun to compare my stance to stock seen this thirdgen down the street..
Just did heater hose mod to rear today little bit more happy with stance
Front fender to floor it is sitting at 25inchs haven't measured rear but should be around 26 inch range
I'm probablly going to cut the spring a little to lower a inch more
Old Jun 10, 2012 | 06:11 AM
  #387
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
it does look great but it will never be able to get over a speed bump.my subframe connecters already drag on some speed bumps at stock height.
Old Jun 10, 2012 | 10:48 AM
  #388
i have no car right now, well the 92 is still pulled apart. and im back in MD so it might be another year or two before i make the trip out,
Old Jun 10, 2012 | 11:18 AM
  #389
Engine: 305 to 350
Axle/Gears: 10 Bolt
Wow your subframe connectors drag at stock height if you have Alston then I can see why but that's a maybe because I have no issues with speed bumps or freeway and I live in the city of san diego and i drive and los angeles and to people that been to Cali knows the roads are some of the worst
so you must be driving pretty fast or your shocks are bad I just can't see sfc hitting speed bumps at stock height when I drive my car daily and have no issues at all
And its a lifestyle not ever one can deal with lowered car
If your not scrapping your not low enough lol
Old Jun 10, 2012 | 05:03 PM
  #390
itsMikey's Avatar
Engine: 5.7 350 TPI
indeed
Old Jun 10, 2012 | 05:09 PM
  #391
DBLTKE's Avatar
Engine: LB9, LB9
Agreed. I am starting to get bored with my set up already. I want to be able to get the fender lip down even with the wheel lip of an 18" wheel. The way the suspension is on these cars makes that impossible unless it were completely bottomed out. With no rear springs the rear only tucks about half the sidewall on the rear tires.
Old Jun 11, 2012 | 01:02 AM
  #392
itsMikey's Avatar
Engine: 5.7 350 TPI
saddening really :P
Old Jun 11, 2012 | 05:51 PM
  #393
Engine: 305 to 350
Axle/Gears: 10 Bolt
Yea it's kind of a limit to how low you can go unless you do some serious fab work
You ever had issue with one side being height than other my front left right fender height is like 24 1/2 in and right rear is 25in and left rear is 26in I switch coil to different sides and left rear still inch higher
Old Jun 11, 2012 | 06:26 PM
  #394
karl's-92'-z28's Avatar
Car: Too many cars
Air bags is the only way & you can adjust the height without getting under the car!!!!!!
Old Jun 14, 2012 | 12:49 PM
  #395
Engine: 305 to 350
Axle/Gears: 10 Bolt
also weight jacks lol but im going to upgrade shocks struts first to koni or blistien before i go into changing the coilspring setup but i have been looking and reading about the airbag setup a couple guys have on this site
Old Jul 3, 2012 | 10:40 PM
  #396
Tomuch7's Avatar
Old Jul 4, 2012 | 08:22 AM
  #397
carlos64030's Avatar
Car: 1991 Trans Am GTA
Tomuch7... I really hope you plan on posting more than just that one picture.
Old Jul 4, 2012 | 08:48 AM
  #398
rummie's Avatar
Car: 84 Z-28 / 98 SIERRA Z71
Transmission: 700R4 / 4L80E
tomuch07- we need more pics of that awesome ride!
Old Jul 10, 2012 | 10:42 AM
  #399
mike22115's Avatar
Car: 1990 firebird formula
Engine: 355 HSR comp xfi 268 vortec heads
Axle/Gears: 3.27 BW 9bolt
id say its slammed? my 90 formula on ground control weight jacks. its my daily with 800 front and 150 rear springs on C6 vette's. i will have better pics up soon
Attached Thumbnails Slammed Third Gens - Post Pics-556519_470667102957394_145530008_n.jpg   Slammed Third Gens - Post Pics-179522_470496759641095_628677932_n.jpg
Old Jul 10, 2012 | 11:19 AM
  #400
Engine: 305 to 350
Axle/Gears: 10 Bolt
nice
