Window Fogs Easily + Won't Start When Warm
Old Nov 2, 2001 | 10:19 PM
92RSB4C's Avatar
Well, I was going to the car show tonight and noticed my windshield was fogging up really bad. I put my fingers on it and noticed it was on the inside and the outside. I went back home and got some windex and sprayed both inside and outside and it still does it. It doesn't fog when the A/C's not on, so I'm wondering if anyone else has this problem? After all that was taken care of, it wouldn't start! That ticked me off so bad! The thing is, there's no electricity getting to the starter. I know that b/c the lights don't dim down when I try to start it. So I let it sit for 20 minutes and it started right up. Does anybody else's car do that? Please help me, I'm missing cruise night! Could it be heat related?
Chevy World Home Page Tripod Home Page Speak up for our hot rodding rights!!!
Old Nov 3, 2001 | 11:24 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I would ask this in the Gen/Tech section.
"Rice burners are like tampons...Every pu$$y has to have one"
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
3" Hooker CatBack w/Aero Chamber muffler
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat, just switched to 180* b/c of winter coming and going to college in the mts.
3:73 Posi
Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
Old Nov 3, 2001 | 03:33 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
The fogging up of the inside could be due to a bad heater core.
The car not starting could be a VATS issue, I am not sure if the condesation from the heater core, if it is bad, is causing the sensor that reads the chip on the key to not function correctly.
Check the passenger side floor board to see if there is any moisture there.
WS6 Trans Am.
View My Ride @ thirdgen.org
Old Nov 3, 2001 | 05:20 PM
Adams87Camaro's Avatar
with the windows, have you recently armorall'd the inside of the car? because i did that in the winter and that happened to me, but it does sound like a heater core problem.
[This message has been edited by Adams87Camaro (edited November 03, 2001).]
Old Nov 3, 2001 | 07:19 PM
92RSB4C's Avatar
I really don't wanna mess with the heater core. I have noticed that there is a hissing noise coming from the back of the air controls. Do you think a loose vaccum line would cause a door in the heater core to not shut? If all else fails, I'll probably just block the vent or make a deflector. What do you guy's think?
jaridjohn
Jul 8, 2024 03:49 PM
Brcharrelson
Aug 26, 2015 07:47 PM
TheExaminer
Aug 26, 2015 04:59 PM
justin57
Aug 20, 2015 07:05 PM
stalkier
Aug 13, 2015 12:59 PM
