Exterior side window weatherstrip
Old Mar 9, 2012 | 12:48 PM
Greg1309's Avatar
Car: 91 Camaro
Engine: V8
Where can you find the exterior side window weatherstrip that is at the bottom of the outside window, mine are both showing cracks. What is the name for them or part # thanks ---Greg in Orlando
91 RS 5.0 Camaro--1 owner, 31,000 actual miles
Old Mar 9, 2012 | 12:57 PM
patricklav's Avatar
Car: 92 Camaro Z
Engine: LS 5.3 LM7
Transmission: Built TH350 with 3200 stall
Axle/Gears: 4th gen, 4.10
Re: Exterior side window weatherstrip
Those are the window sweepers. I bought mine on Ebay as part of a kit but i have seen them sold individually.
Old Mar 9, 2012 | 05:00 PM
Greg1309's Avatar
Car: 91 Camaro
Engine: V8
Thanks for the info.
Old Mar 9, 2012 | 05:03 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Pull some from a 4th gen in a junkyard. Might spend $20 for both vs $150 for the reproduction ones.
If you Search here on TGO, you'll find all the info you need without having to ask.
Old Mar 9, 2012 | 05:19 PM
Hal87's Avatar
Car: '84 Firebird TA & '87 Camaro LT
Engine: 350 V-8 & V-6
Axle/Gears: 3.23 & 3.42
1A Auto also has them
Greg1309's Avatar
Car: 91 Camaro
Engine: V8
I was also thinking outside the box about manufacturing some black silicone strips to just cover the strip and glue it on top. I could apply a black silicone adhesive to fill in the cracks before applying the strip. If it looks good when finished why not, less work almost zero cost.
Old Mar 9, 2012 | 06:00 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
i concure , i got mine from them . i'm very happy . good luck .
Old Mar 11, 2012 | 07:54 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
1992 Trans Am
May 10, 2023 07:19 PM
evan555222
Sep 20, 2016 02:51 AM
pfsteichen
Feb 9, 2016 06:59 PM
1Aauto
Sponsored Vendors
Aug 24, 2015 03:40 PM
evan555222
Aug 22, 2015 07:14 PM
