Window Louver Resto
Old Oct 26, 2012 | 05:35 PM
Nathon's Avatar
Car: 91RS, 97hoooonda, 83sc
Engine: Carb 5.7,Tpi 5.7
Axle/Gears: 93TA rear lsd 3.23
Window Louver Resto
So after searching for quite some time i finally found some '86 rear window louvers.
cost was 80$ and came with all hardware but 1 bracket.
These are for my semi recently wrecked 1983 Frankenstein z28 styled car, which the PO had installed an '86 style hatch on.
so while i collect parts for the front end rebuild (almost done) i decided to try my hand at these louvers. i painted another set for my '91 louvers i get for 50$ and they turned out decent but i wanted to do a little better this time and affordable as possible
Ill be adding pics of this as it goes. but heres the process.
get louvers/hardware
scrub down... 25+ years on louvers isnt pretty
paint... base/clear.. Rustoleom black enamel with enamel crystal clear.
between 4 and 6 cans total
price breakdown
louvers...80$
scotch bright and steel wool.. attained from work but lets say 15$
paint.... 25$
120$.. how can i lose?
Ill post pics tonight and I look forward to your opinions.
Old Oct 26, 2012 | 07:11 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
Re: Window Louver Resto
The louvers were not gloss black so you might want to hold off on the clear. They were a satin black. I used Duplicolor Trim Black paint and it's almost an exact match to original.
Old Oct 26, 2012 | 07:31 PM
Nathon's Avatar
and thats what i did on my 91 is use an epoxy enamel and it turned out great. but my 83 is white and a high gloss. so i figured if it didnt work out, i could just strip them down.
Old Oct 26, 2012 | 07:51 PM
Nathon's Avatar
heres how they turned out. ill be doing a set of 17/18" wheels in a same finish and tinting the windows
the first pic is after prepping before paint. and the 2 others are final finish. gonna let them sit inside and cure for a few days
Attached Thumbnails Window Louver Resto-img-20121022-00105.jpg   Window Louver Resto-img-20121026-00108.jpg   Window Louver Resto-img-20121026-00109.jpg
Old Oct 27, 2012 | 06:30 PM
Raging Sloth's Avatar
Car: 1987 iroc-z
Engine: 5.7 tpi
Looks really good! Impressive work.
Old Oct 27, 2012 | 11:43 PM
Nathon's Avatar
ill post a few pics on the car as soon as i can. rain has been nonstop past few days.
Old Oct 29, 2012 | 11:30 AM
Trinity83's Avatar
Car: 1988 Camaro IROC Z-28
Engine: 5.7L
Transmission: Automatic
Oooooh, shiny!
Old Oct 29, 2012 | 02:15 PM
Nathon's Avatar
now im going to refinish to match some chrome peeling rims. think a wire brush will work well enough to strip and rough up the wheels?
Old Oct 29, 2012 | 03:50 PM
95Cam86Roc's Avatar
Car: 86 Iroc
Engine: LS3
Those look great! I'd love to find a set of louvers.
Old Oct 30, 2012 | 10:57 AM
Nathon's Avatar
what year/style third brake light you have? i can try to find a set.
and ill pick them up and we can work somethin out.
Old Nov 2, 2012 | 08:45 PM
Darryls1992RS's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: 5.0
Transmission: Stock
Axle/Gears: Stock
Awesome Job Nathon!
Old Nov 7, 2012 | 10:10 PM
95Cam86Roc's Avatar
Car: 86 Iroc
Engine: LS3
I would need them for an 87, without a brake light.
Old Nov 8, 2012 | 10:37 AM
Nathon's Avatar
ill keep an eye out for you. i got the set on my 91 like that for 50$
Fireslash
Apr 11, 2016 06:43 PM
jrdturbo
Mar 31, 2016 02:58 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
kkirch15
Sep 30, 2015 04:44 PM
