NEW ADJUSTED PICS & HOMEMADE COLD AIR KIT WHAT DO U THINK!
Subscribe
Dec 9, 2001 | 06:03 PM
the only thing is u cant see the scoop under the pass front ill get some better lighting and redo! So any props 4 steering wheel *** thingy guy?
http://wsphotofews.excite.com/013/Mh/N4/VL/as52984.jpg
http://wsphotofews.excite.com/014/V3/zw/W3/8R34638.jpg
http://wsphotofews.excite.com/012/Er/ld/We/aD30263.jpg
BEFORE
http://wsphotofews.excite.com/014/EW/t2/8e/qz26019.jpg
AFTER
http://wsphotofews.excite.com/013/Mh/N4/VL/9i60002.jpg
http://wsphotofews.excite.com/012/CY/Dv/23/al26513.jpg
http://wsphotofews.excite.com/004/us/dv/WM/ab70948.jpg
http://wsphotofews.excite.com/021/rC/MA/Fa/9B73575.jpg
http://wsphotofews.excite.com/007/nx/iQ/zO/9r19773.jpg
ANY ADVICE ON SOME RIMS?
[This message has been edited by ONEFORMULAOVERALL (edited December 09, 2001).]
Reply 0
Dec 9, 2001 | 06:11 PM
BEFORE
AFTER
SORRY! tried 2 b smart
92 F-BIRd FORMULA T-TOP (WHITEKNIGHT) 5.7L-98,700R4 TCI STREET FIGHTERTRANS,TRANSGO-HP KIT,KEVELAR CLUTCHES,VETT SERVO 2500STALL,54MM-AS&M TB-PORTPLENT,LARGETUBRUN,L-98 ALUM. HEADS PORTED CRANE AFPR.45PSI,SMOG PUMP GUTTED,
UNDER PULLEYS K&NCOLD AIR KIT,160THERMO,ELDB HEADERS W/3 1/2 Y PIPE 2 RINO CAT 2 DUMP
MSDDIST,6AL,TAYLOR WIRES
2BLASTERCOIL.ACCELL PLUGS
CUSTOM FASTCHIP BY ED WRIGHT,AUBERN POSI W/ RICHMOND 3.23 AND MOSER AXEL SPLINES CRYGO FROZEN,TUBE FRAME CONNEC,EIBACH PRO.,HOK.LOWER ARMS,PAN,TQ ARM,ALUM. DRV.SHAFT.
PST KIT.1LE BRAKE KIT CROSSED DRILLED ROTORS MANY MORE MODS FORESEEN IN MY ERA!13.01ET @ 108.75MPH ON MICK E.T & PIZZA CUTTERS UP FRONT
Reply 0
Dec 9, 2001 | 06:22 PM
Hey sweet ride man. I would suggest these rims:
Or maybe a set of 4th Gen WS6/Firehawk Rims.
Definetly lower the car.
1992 Teal Camaro RS
T-Tops
305 TBI V8
Open air element
3" Flowmaster Exhaust System w/Quad Tips
Aiwa CD/Mp3 player
10 Disc CD Changer
Rockford Fosgate Speakers
SLP Headers Coming
Dynomax High Flow Cats Coming
More to come.
Reply 0
Dec 9, 2001 | 07:11 PM
That looks much better than most home made intakes I see(most are made out of that dryer ducting crap). Good job! What did you make it out of?
Reply 0
Dec 9, 2001 | 07:31 PM
the car is lowered but i dont have an exhaust after the hp. cat. and it will prob settle about an 1/2 inch or more w/time
the intake is made out of styrene pvc pipe(thin, durable and lightweight. had a very hard time to find it) 3.5 in D,1 90 elbow and a 45 bend painted with high temp paint.
about the rims those r sweet but 2 common how bout something a little more strange..
thanks 4 the compliments
Reply 0
Dec 9, 2001 | 07:37 PM
I have another question..
Whats up with your coolant overflow tank? Did you paint it black? Looks good.
Reply 0
Dec 9, 2001 | 07:42 PM
YEP! and the ww fluid bottle 2 high temp black paint and also forgot 2 mention i also put high temp clear paint 2 to try and keep it from chipping on both the air, and bottles
Reply 0
Dec 9, 2001 | 10:30 PM
where did u find the PVC at?
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series Muffler added to Unkown CatBack, Ported Intake
http://www.geocities.com/david_angel_16
Reply 0
Dec 9, 2001 | 11:46 PM
Your car would look a lot like mine with those rims.
1992 Formula 350
-SLP 1 3/4 Headers
-Ported Plenum, Polished w/ polished runners
-Airfoil and other small bolt on mods
Reply 0
Dec 10, 2001 | 01:55 AM
Looks good dude!
-Roshambo
-Joe
1988 Pontiac Trans Am WS6
Cascade Crew
Reply 0
Dec 10, 2001 | 03:07 AM
I like looks alot like my old setup!
bringing the filter closter to the ground will pick up a better flow, just an idea incase you go to build another.
nice car.
Reply 0
Dec 10, 2001 | 07:25 AM
nice car.
THANKS! WHERE DID U GET THAT TUBE? ido also have a scoop that directs air 2 the filter.
the pipe i found @ a plumbing co. that does water irrig. sewer ect.. bought about 4ft 4 5.$
tnanks 4 the compliments u all have sweet rides but u already knew that :-D
[This message has been edited by ONEFORMULAOVERALL (edited December 10, 2001).]
Reply 0
Subscribe
