Need help on which LED bulbs...
Old Jan 6, 2014 | 01:38 PM
92GTA's Avatar
I did a search on "LED" here and came up with a couple that *appear* to work plug-n-play from another thread:
Interior dome light and rear hatch/trunk:
http://www.superbrightleds.com/moreinfo/festoon-series-bulbs/578-led-can-bus-bulb--1-led-festoon/1264/2937/
Exterior side markers, license plate, instrument, and map:
http://www.superbrightleds.com/moreinfo/miniature-wedge-base/194-led-bulb-6-smd-led-wide-angle-wedge-base/211/
Hatch brake light:
http://www.superbrightleds.com/moreinfo/tail-brake-turn/3156-led-bulb-single-intensity-45-smd-led-tower/997/2446/
Front/rear turn signal & brake (dual intensity):
http://www.superbrightleds.com/moreinfo/tail-brake-turn/1157-led-bulb-dual-intensity-45-smd-led-tower-/814/
Rear backup:
http://www.superbrightleds.com/moreinfo/tail-brake-turn/1156-led-bulb-single-intensity-45-smd-led-tower/526/
Fog lamps:
http://www.superbrightleds.com/morei...ing-light/152/
I'm only interested in direct plug-n-play and something that will replicate the original lighting appearance as perfectly as possible. I don't want something that is too bright and will give the appearance of a hot spot behind the lens, I want bulbs that will evenly disperse light like an incandescent bulb. I think the most difficult bulbs to find will be all the taillight bulbs that will give me the appearance I wish to retain...
Please review the ones I linked and give me feedback on if they will give the appearance I want or suggest another too. I've never bought or used LEDs before so I'm lost in that regard
EDIT: I researched all of the OE bulb information for a 1992 Trans Am and came up with this:
(194) Side/License/Instrument/Map:
4.62 watts
2800K
25 Lumens
(3156) Hatch Brake:
26.90 watts
2800K
402 Lumens
(H3) Fog:
55 watts
3200K
1450 Lumens
(1156) Backup:
26.90 watts
2800K
402 Lumens
(2057) Front/Rear turn & Brake (dual intensity):
26.90/6.70 watts
2800K
302/19 Lumens
(211) Dome/Hatch:
12.42 Watts
2800K
151 Lumens
So now I'm going to go thru that site and find exactly which LEDs are the most comparable with the broadest beam angle and I'll update the above links accordingly...
EDIT 2: Ok I updated the links but none of them are even close to the original rated Lumens of the originals. Are LED lumens different from incandescent lumens?
Any idea which of these blinker relays are right for my car?
http://www.superbrightleds.com/cat/l...8-532--528376/
Thanks allot!
Alex
Old Jan 6, 2014 | 09:11 PM
lb9 GTA's Avatar
Car: '88 Trans Am GTA
Re: Need help on which LED bulbs...
Does your car have a bulb out indicator?
Old Jan 6, 2014 | 09:22 PM
92GTA's Avatar
No. Actually I never knew 3rd gens had that option. I know Canadian models had a DRL option, etc. tho with a dome sensor on the dash pad.
Old Jan 7, 2014 | 08:38 PM
lb9 GTA's Avatar
I guess it was just with the digital dash. The reason I asked is if you have said indicator you need a load resistor instead of an LED flasher relay. You can still use one for your purpose because it will eliminate quick flash. Unfortunately I have no idea what relay you need.
Just so you know, LED fog light bulbs are not bright at all. At least the ones I've seen. They do look good though.
Post pics when you're done. I really want to see the end result.
Old Jan 9, 2014 | 12:19 PM
rwstegne's Avatar
Car: 1989 Iroc Z 5.7L
Engine: 5.7L
Axle/Gears: built 4.10s
I am in the same boat. Upgraded all of my interior, front side marker lights, and license plate bulbs. Here is where I posted my information.
https://www.thirdgen.org/forums/inte...-lighting.html
Right now there is a dark spot around the speedometer so I need to check to make sure the bulb is working. If it is, I might need to upgrade a few of the single LED bulbs to a 5 LED wide angle bulb.
The 5 LED bulbs work great on the front side markers.
The license plate I used some 4 LED bulbs.
Old Jan 11, 2014 | 07:40 PM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Subscribing!
I'm in the middle of led conversion myself, I tried many types of leds on my cars and this type of led bulb are awesome.
Tail/stop lights http://www.ebay.com/itm/1157-High-Power-Samsung-LED-Red-Turn-Signal-Brake-Tail-Stop-Lights-Bulbs-/330955127833?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item4d0e767c19Rear turn lights http://www.ebay.com/itm/1157-High-Power-Samsung-LED-Yellow-Turn-Signal-Brake-Tail-Stop-Lights-Bulbs-/400527612973?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item5d414e5c2dThird brake light not sure anymore but something like this, not particularly bright, one of the first led bulbs I bought to try out. http://www.ebay.com/itm/2X-RED-7440-18-COUNT-SMD-LED-LIGHT-BULB-CAR-AUTO-BACKUP-REVERSE-LAMPS-12V-CG-/121251416549?pt=Motors_Car_Truck_Parts_Accessories&hash=item1c3b25c9e5&vxp=mtrRear side markers http://www.ebay.com/itm/T10-921-High-Power-Samsung-Chip-LED-Red-License-Plate-Interior-Lights-Bulbs-/400493654356?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item5d3f483154I have these in the back up lights on two cars http://www.ebay.com/itm/231037555125...84.m1497.l2649 will probably look for some with the correct socket and use them for the thirdgen too.
I still need to install the front side markers and front park light/turn signals and the LED flashers.
Front side markers http://www.ebay.com/itm/T10-921-High-Power-Samsung-Chip-LED-Amber-License-Plate-Interior-Lights-Bulbs-/330917595961?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item4d0c39cb39front park/turn lights http://www.ebay.com/itm/Samsung-1157-Dual-Color-Switchback-High-Power-LED-Turn-Signal-Corner-Light-Bulbs-/400417548762?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item5d3abee9da (I need white front parking lights, for legal reasons)
Also trying to figure out a way to have the front side markers work as parking/turn light in sync with the front parking/turn light.
Currently looking for nice, white (not blueish) and bright H3 led bulbs fro the fog lights.
Old Jan 12, 2014 | 09:30 AM
rwstegne's Avatar
Engine: 5.7L
Do you have any pictures ?
Old Jan 13, 2014 | 05:02 AM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
You might find the below threads helpful. Al Hasse (board member) has a few helpful threads as well.
https://www.thirdgen.org/forums/inte...ml#post5492480
https://www.thirdgen.org/forums/inte...ml#post5482423
Old Jan 13, 2014 | 03:47 PM
thomas1976's Avatar
Car: 91 Trans am
Took some pictures but they are useless.
Attached Thumbnails Need help on which LED bulbs...-tail-light-samsung-chip
Old Feb 7, 2014 | 02:16 PM
thomas1976's Avatar
Car: 91 Trans am
Finally completed all the lights with LED bulbs (except head lights, dash and console), also made a Side Marker Sinc Relay.
http://www.dailymotion.com/video/x1atf7s_side-marker-sync-relay-480p_tech
In order to use led bulbs in all turn signals I replaced the O.E. flashers with the 2 pin prong led flashers.
Attached Thumbnails Need help on which LED bulbs...-electronic-flasher-12v-led
Old Feb 7, 2014 | 02:17 PM
92GTA's Avatar
Thanks for the info and the update!
Old Feb 7, 2014 | 02:20 PM
thomas1976's Avatar
Car: 91 Trans am
You are welcome!
Old May 5, 2014 | 12:35 AM
Edmonchuck's Avatar
Engine: L98 TPI
I do have the digital dash. So, basically LED is a no go for tail/signal lights as it will kick off the warnings? Adding the resistor just seems more of a PITA than it's worth...
What about dash lights? I have a set about to go into my 88 Fiero GT... isn't it the same bulb? Do the wash out the LCD?
Old May 5, 2014 | 12:51 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Have tried some, even using the more fancy multi SMD ones over reg led's. Wasn't as happy with day time brightness.
Though I do like the ones on the interior, that bluish spectrum of light looks better over the white/yellow of reg bulbs.
Old May 5, 2014 | 07:26 PM
lb9 GTA's Avatar
Exactly. The info center will think the bulb is blown without the resistor and you'll get a message like "brake light out" on the display. The dash lights are 194 bulbs. I would assume it's the same. I haven't used LEDs for dash lights because the LEDs don't dim like the normal bulbs so I couldn't tell you what they're like.
Old Aug 24, 2015 | 05:04 PM
rwstegne's Avatar
Engine: 5.7L
So I have LED front side maker light, non-LED front turn signal light which work with no problems, but once I installed an LED light in the rear turn signal position the front and rear won't flash. Did anyone else have a similar issue? My other rear LED tall light bulbs are working just fine. Confused
Old Sep 3, 2015 | 08:36 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Not enough resistance/current draw to make the flasher work. Need a solid state flasher.
Old Dec 8, 2015 | 03:07 PM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
A lot of good info here (1st Message) and the samples of LED's too... I thought I would add instead of start a new one, and show more examples...
Check these out...
Stock 1157 bulb on left, JDM Astar 1157 Amber LED (mind you, Knight Rider first season nose with smoked plexi black out...)
Stock 1157 rear tail lights on right, JDM Astar 1157 Red LED on left... just parking lights... very noticeable...
Stock 1157 rear tail lights on right, JDM Astar 1157 Red LED on left... Pressing brake pedal... Yes, pattern is not the same, was running turn signal in middle on right side, but moved it to stock location since...
But Note!
The camera itself adjusted the iris due to brightness and everything else is darker in the image... Note how much larger the glowing orange / red is on the led side compared to the right / stock side...
I don't have the license plate light installed yet (this weekend) and I'll also switch out the flasher to an electrical one to work with LED's, since the mechanical one will not work...
Also, I replaced the side marker lights... wow... I don't have a picture, but they lit up the side of the garage in light, as opposed to the stock ones... Better it's seen, the less chance of being hit
Rafael
Old Dec 8, 2015 | 06:40 PM
luvofjah's Avatar
I bought on the higher end of quality...
They come with a 1 year warranty and are having a 15% off sale, free shipping...
Side Marker, License plate, White, Amber & Yellow
https://www.jdmastar.com/index.php?r...scription=true
Front Turn Signal - Amber
3 sets (6 total) for Rear Brake Lights / Turn Signal - Red
1 set for backup - White
You need to get a new electrical / led flasher... Here is the one I got, but not yet tested...
http://www.ebay.com/itm/161584413945?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT& you need 2... one for flashers & another for Hazard lights...
Again, they sell cheaper LED's, but they are just that...
A bit over $200 for all I got....
Rafael
Old Apr 8, 2016 | 12:58 AM
wgripp's Avatar
Car: 1991 Trans Am GTA
Engine: L98(5.7 L TPI)
Transmission: 700r4(A4)
Axle/Gears: G80 RPO, 3:23s, Auburn Racer's Diff
http://www.dailymotion.com/video/x1a...elay-480p_tech
The video doesn't work correctly for me. What does the side marker sync relay do?
Old Apr 8, 2016 | 01:13 AM
wgripp's Avatar
So, I was able to see the video. It appears as if your sync relay makes the bulbs function as stock. Shouldn't you be able to achieve that effect by swapping your flasher from a load-resistor style to an LED style?
Old Apr 9, 2016 | 11:49 AM
MintWS6FORMULA's Avatar
From: Michigan [Bodacious Member with the Bodacious TA'TAs (Trans Ams)]
Car: 91 Formula - Authentic and REAL
Engine: 5.0 Liter
Why is there a shortage (nonexistance) of led fog light bulbs? Is that why? I've been wanting them for months now for the DD, but all I have that's white are the burn-out-easily Sylvania 880ST that are hard to find and when you do find them, they want $25-30 each.
Old Apr 9, 2016 | 11:56 AM
Engine: 5.0 Liter
I have to caution you: for the smaller bulbs (ie 194 license plate, dome, etc bulbs) - they have 5 led and longer 9 LEDs that probably won't fit inside the housing. Play it safe, get the 5 LED. I did the swap for the license plate light of the DD and even that (the 5 LED) just barely fit. No way the 9 led would have fit.
Old Apr 9, 2016 | 12:02 PM
Engine: 5.0 Liter
Alex
I know what you mean. I've been wanting a new spotlight and they are no longer listed in the familiar 'X million candlepower' designation, only in lumens. Something tells me they won't be as bright.
Old Apr 9, 2016 | 12:13 PM
skinny z's Avatar
Any feedback on what works and looks the best for the dash light lamps? I've built my own gauge cluster and the typical 194 wedge base style doesn't work all that well. From a brightness stand point that is.
Old Apr 10, 2016 | 01:53 PM
thomas1976's Avatar
Car: 91 Trans am
Sorry I did not have time reply earlier.
With park lights on, the front park lights and side marker flash together. (stock they alternate)
Cheers
Old May 26, 2020 | 04:17 PM
ILMODC's Avatar
Sorry for the blast from the past. In short, i'm doing something similar. ALL LEDs inside and out.
I just ordered two electronic flasher to replace the turn signal and the emergency flashers. I'm still not getting any blink. All lights are bright and light up. But just no blinking or flashing with turn signal stalk or button for hazzards.
Do I need to get this flasher instead?? Mine are the new red ones but are two prong only. NO black ground wire. Wondering if that's what's needed.
Daniel
Old May 26, 2020 | 05:09 PM
Firebat's Avatar
https://www.amazon.com/gp/product/B00JXLH7CG/ref=ox_sc_act_title_2?smid=A24I8BRTUB8C52&psc=1 https://www.amazon.com/gp/product/B00JXLH7CG/ref=ox_sc_act_title_2?smid=A24I8BRTUB8C52&psc=1
I'm planning on ordering this one from amazon that does have the ground wire. I'll find out if it works soon enough. CEC EF32RL Flasher. My turn signals aren't flashing at all right now but my hazard flasher works fine so I'm going to try just buying one.
Old May 27, 2020 | 02:35 PM
92GTA's Avatar
That's the one I have and it works great.
Old May 27, 2020 | 04:41 PM
thomas1976's Avatar
Car: 91 Trans am
Used the LED flashers with the extra ground wire, still working great here too!
Old May 28, 2020 | 12:19 PM
ILMODC's Avatar
Dang. Ok. It's worth a shot. Gonna see if I can return mine I got for the one's with the ground wire. It's worth a shot.
Old Jun 1, 2020 | 08:47 AM
PAformula's Avatar
Anyone replace their 91-92 3rd brake light bulb with LED? I notice my stock bulb is melting the red lense.
Old Jun 2, 2020 | 06:16 PM
DontBlnkBadWolf's Avatar
Car: 2002 Dodge Ram 1500 Quad Cab
Engine: 4.7 Liter
Transmission: 4 Speed Auto
20 years ago, my Uncle modified my Spoiler's 3rd brake light to an LED circuit board strip. Wish I still had that. I'll see if he can do it again. But since Radio Shack is out of business, IDK.
Old Jun 2, 2020 | 06:50 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Just get a tbl from an astro van/blazer.They have a nice 30 led tbl, early versions use 40 LEDs.I used one from a chrysler crossfire for mine.
Same tbl as above when it was in my 84 with the OE housing.
Old Jun 3, 2020 | 01:30 AM
Engine: 4.7 Liter
Dude, that's awesome. I'll have to hunt for them. 84? I thought 3rdBL wasn't offered on 3rd Gens until 1986 when it became a Federal Law? I know my Mom's 85 Buick Century had one and I remember it didn't become Fed Law until 86.
Old Jun 3, 2020 | 08:49 AM
PAformula's Avatar
TBL?
I really rather just swap out a bulb. There $20 for a 2 pk at autozone, I just would like to hear from someone that did it and how well they work.
Old Jun 3, 2020 | 11:09 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
TBL =Third Brake Light
On my 84 it was a retrofit, but I put it in my vert later on.
Just buy the brightest bulb/led that will fit in the housing.
SMD or a super/hyper bright type will do.Don't use an ordinary run of the mill led.They're not bright enough.
Old Jun 4, 2020 | 10:19 PM
PAformula's Avatar
Here is Sylvania Zevo in red. White made the lense look orange.
Old Jun 6, 2020 | 05:41 PM
Engine: 4.7 Liter
Yeah, that's one way of doing it, I just like the looks of a strip of a bunch of LEDs.
Old Jun 6, 2020 | 06:29 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Me too.
Old Mar 3, 2022 | 02:04 AM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Daniel
no follow up? I have all front led bulbs. 2 LED flashers. Now when I install the rear turn leds, nothing flashes.
Old Mar 3, 2022 | 02:05 AM
  #42
Originally Posted by Firebat
https://www.amazon.com/gp/product/B0...RTUB8C52&psc=1 I'm planning on ordering this one from amazon that does have the ground wire. I'll find out if it works soon enough. CEC EF32RL Flasher. My turn signals aren't flashing at all right now but my hazard flasher works fine so I'm going to try just buying one.
any follow ups?
Old Mar 3, 2022 | 08:57 AM
  #43
scfbody's Avatar
Car: 1983 Z28, 1991 Z28 & 1985 TA
We have been using these flashers (2 prong no load flasher with ground wire), also the front side marker bulbs are important. You need polarity sensitive led bulbs on the front side markers or it won't work. Those are the two most common things that cause issues, not sure if that will fix your problem or not without more details of what you have.
Flashers:
1982-92 Camaro/Firebird LED flashers (screamingchicken.com)
Side marker bulbs:
1982-92 Camaro/Firebird LED Front Side Marker Bulbs (screamingchicken.com)
3rd gen LED lighting:
1982-92 Camaro/Firebird Lighting (screamingchicken.com)
Old Mar 5, 2022 | 02:26 AM
  #44
Flashers:
Side marker bulbs:
Here is what I got from SuperBrightLEDs.
Old Mar 5, 2022 | 08:28 AM
  #45
scfbody's Avatar
Did you replace the stock flashers?
Old Mar 5, 2022 | 01:49 PM
  #46
absolutely. Both signal and hazards. I took a video of the Camaro with front LEDs and incandescent rears. I'll upload it when I do another video with the rear LEDs installed.
Old Mar 5, 2022 | 02:02 PM
  #47
scfbody's Avatar
Make sure the front side marker bulbs are polarity sensitive, if you flip them 180 degrees they shouldn't light up. Also we have had better luck with the flashers that have the ground wire on them. Other than those two suggestions I would recommend asking the seller, may have a defective bulb or other issue.
Old Mar 5, 2022 | 11:48 PM
  #48
Cool man. The bulbs are fine. Verified with the old bulb connector when I replaced with new connectors. Also the fronts are fine other than alternate flashing with headlights. I'll buy the new flashers and give those a shot. Thanks for the tip.
Old Sep 16, 2023 | 06:56 AM
  #49
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
bump any good sites for LED #561 dome lights?
Old Sep 16, 2023 | 07:35 AM
  #50
scfbody's Avatar
We have been selling these bulbs for dome lights and they have been working well. I'm still using the same bulb I installed about 5 years ago when we started selling them.
1982-92 Camaro/Firebird LED Dome Light Bulb (screamingchicken.com)
