Paint job..
Car: 86 Trans Am
Engine: 305 LB9
Paint job..
Hey guys,
I have an all white 86 bird and the paint is getting rough from college and I'm looking to paint it.
I'm hoping for this: http://car-from-uk.com/ebay/carphotos/full/ebay1027258.jpg
That color scheme is my favorite and blue just so happens to be my favorite color.. I'm not too worried about originality as I'm swapping the engine too.
Taking this to a decent place in town for an estimate. Does anyone know the name of this color scheme or color codes? I like the fade effect too, didn't know if that is a special thing. Coming to painting, I have no idea what anything is.. Just want to get some advice
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Re: Paint job..
I could not get your link to work so I posted the photo for you.
Sometimes you must put more of a space between the link you post and the sentences around it.
I like the color and scheme it has.
Don't be surprised if you get a quote of $ 3,000.00 or higher at a good automotive paint shop.
Car: 1992 Z28 Targa Top. Full air ride
Engine: 305 5.0 tpi v8
Transmission: A4
Axle/Gears: 3.73 gears posi
Re: Paint job..
Correct me if I'm wrong but the fade he refers too, that's just a decal and not actual paint.
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: Paint job..
Color changes always cost more because someone will end up sanding down by hand and repainting all of the door jams and cowl and any other PITA area to paint. 3,000 seems ballpark to me if you have no rust and very few dings and no dents. You can save a bit of money if you can remove everything and at least sand the ground effects. If you have a garage do ALL of the sanding yourself and really save, in the neighborhood of $1000. Sometimes you can also save if you allow them to finish it within reason without a completion date. If you also know someone who can buff you can have them spray clear and stop. Saves at least $250.
Car: 1991 Z28 Vert
Re: Paint job..
For some members taking it to a high school or college that does this work to teach students is an option and in comparison very cheap. It could even be free if you supply all materials and they agree to write you a tax slip for a charitable donation. Food for thought.
From: Michigan [Bodacious Member with the Bodacious TA'TAs (Trans Ams)]
Car: 91 Formula - Authentic and REAL
Engine: 5.0 Liter
Re: Paint job..
Hey guys,
I'm hoping for this: http://car-from-uk.com/ebay/carphoto...bay1027258.jpg
This is what you want :
1985-86 Trans Am "Square dot fade stripe" with "Accent" Stripe Kit Only $119 with "silver with blue accent" on the order form
and for the blue, tell them this:
http://paintref.com/cgi-bin/colorcod...irebird&con=yo
1986 Bright Blue 23 WA8751
1986 Silver 13S WA9021
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Paint job..
Try and get this kit from Phoenix instead of the rolled up stuff.
Car: 1987 IROC Original Owner
Engine: LB9
Transmission: M39 MM5
Axle/Gears: G80 G92 J65
Re: Paint job..
Good tip with that kit - goes on easy and is already pre-contoured for the bends in the body. They have a similar kit for the IROC-Z ground effects stripe that I have used with great success.....even a cave man can do it!
Car: 86 Trans Am
Engine: 305 LB9
Re: Paint job..
Thank you for the link to that kit! Unfortunately this like other planned restores are on the back burner because if a coolant leak, bad brakes, and the ebrake. I'm hoping *hoping* to have it painted by summers end. I'd much rather have a well running bird than a good looking one.
I appreciate everyone for the help!
Hotrodboba400
Dec 10, 2019 07:07 PM
1Aauto
Sponsored Vendors
Sep 13, 2017 12:58 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
