How hard to remove window tint?
Old Dec 19, 2001 | 10:36 PM
Black_Widdow's Avatar
Car: 05 GTO, 88 GTA, 98 SS
I was quoted $120 to get my windows re-tinted IF I go ahead and take off all the old tint myself. I figured why not save a few bucks. So is it hard to do or should I just get them to do it?
Old Dec 19, 2001 | 10:38 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
i dont think the sides are too much trouble but the hatch...i would rather masterbate with a handful of broken glass.
GOOD LUCK
-brian
Old Dec 19, 2001 | 10:59 PM
Old Dec 19, 2001 | 11:29 PM
Ions91Z28's Avatar
Car: 1991 Camaro Z28
also, when taking the tint off the rear hatch many times you lose the rear defroster.
Old Dec 20, 2001 | 06:11 AM
SgtSkip's Avatar
Windex and a green scrub pad works pretty good for getting off the left over glue. I did my hatch in about 15 minutes.
Old Dec 20, 2001 | 01:29 PM
89transam's Avatar
Took me forever...Im still in the proccess. Imgonna go finish up after writing this, Get it done....screw the cost. Its a pain ni the butt and you lose the rear defrost
N8
Old Dec 20, 2001 | 02:16 PM
I dont have rear defrost. So is it still difficult to do?
Old Dec 20, 2001 | 07:15 PM
c-5invalid's Avatar
TAKING MY TINT OFF WAS SOO DAMN EASY
first spray some windex all over... wipe it over the window... let it sit... then get a sharp rasor blade and in the corner try to make the blade go under the tint alitle without actualy riping the tint...
try and get a little edge from the corner big enough so u can dry it and grab it with your fingers
slowly pull at the tint and do your BEST NOT to tear it... slowly peel off the bigest single pieces before the tint rips and you have to start over again...
for the driver and passenger side doors i slowls peeled the tint off using my 4th grade sticker peeling skills...
i was able to get the entire window with 1 slow pull...
i had to remove my tinting to pass inspection...
the WORST part of removing the tinting is getting the sticky stuff left from the tint... it comes off with nail pollish remover + over 50 cotton *****... (used 1.5 bottles) the glue stuff needed to be rubed like hell b4 the glue beaded up into little tan brown glue *****...
Old Dec 23, 2001 | 09:45 AM
jmon92conv's Avatar
The glue comes off easy with a rag and gas. Th smell is strong, but it cuts the glue easy.
Jeremy
Old Dec 23, 2001 | 12:14 PM
SgtSkip's Avatar
I'd avoid using gas 'cus all it takes is one little spark from static any your a crispy critter.
Old Dec 23, 2001 | 12:48 PM
KZad's Avatar
Car: 88 Formula, 04 CTS-V, 06 Commander
Engine: 305 TBI, LS6, 4.7 V-8
Transmission: 5 spd, B&M Short Throw
Cake ...
I had to take the tint off the side windows of my car this summer to pass inspection. The tint looked great, but must have been sh1tty cause both windows came off in about 5 minutes. It came off in solid sheets, and all I had to do was wash some of the leftover glue off. Piece of Cake. My hatch tint passed so I didnt have to take that off.
BOY I MISS MY TINT.
Old Dec 23, 2001 | 01:01 PM
labrat's Avatar
Car: 87 IROC-Z
Transmission: automatic
I would think that methyl ethyl ketone or toluene would be good for removing the glue. In any case when you are using solvents you should wear gloves and a face mask. Those solvents aren't exactly good for you. Gloves and masks sould be available through an auto body supply shop, those guys work with this stuff all the time.
Old Dec 24, 2001 | 11:46 AM
SgtSkip's Avatar
OK guys, this stuff is not that hard to get off. MEK is WAY over kill and you'll end up getting it on somethng that you don't want it on. We use it on the aircraft to get off the toughest paints and other coatings. I've had great luck with simply using windex. Soak it down and let it sit for a minute or two. It then comes right off like a gel. I use a razor scraper just 'cus it's really quick. Use a green scrub pad (lightly) for any places you can't get to with the scraper. You don't need to scrub hard.
Old Dec 25, 2001 | 06:14 PM
Camrs89's Avatar
Car: 91 Formula, 79 Trans Am, 72 LeMans
Engine: 305 TPI, 6.6, 350 Pontiac
Transmission: T5, 3 speed, TH350
I used warm soapy water and a razor blade. I took it off in one evening after work. good luck
Old Dec 25, 2001 | 10:22 PM
BlackBird91's Avatar
State chemicale makes a heavy duty remover called PGR. Keep it away from the paint but I removed all the tint in an afternoon. I did remove the hatch and lay it upside down. a flat razor and a green scrubby pad for the detail work. lol
Old Dec 25, 2001 | 11:14 PM
Pentatonic's Avatar
Dude, you lucked out. With no rear defrost, taking off the tint is fairly simple. Just take some windex, spray it over the back window, let it sit in the sun, then scrape away with some razor blades.
Old Dec 27, 2001 | 11:28 AM
heavy_chevy29's Avatar
Car: 84 camaro Z28
Engine: 434sbc
Transmission: powerglide
Axle/Gears: moser 9" with 411 posi
taking the tint off the rear hatch is so damn easy. i was told buy a professional that it would cost $200 just to take the old tint off. naturaly i told the guy to blow it out his @ss. use a razor blade to get it started then just slowly pull it off (but be careful not rip the rear defroster). good luck.
Old Dec 27, 2001 | 11:45 AM
3.1EyeCandy's Avatar
Car: 1987 GTA
Transmission: 4L60e
Do exactly what c-5invalid described and instead use some ammonia in a spray bottle. This will enable you to take the entire hatch tint off in one single piece. I recommend taking some black trash bag, cutting it so that it is one large piece, and taping it to the hatch inside. Then spray the ammonia very generously over the tint. take the trash bag that's taped on the inside of the hatch and press it to the ammonia so that the two stick together. park the car in some sun. after about 30 minutes of soak, the tint comes right off.
Old Dec 27, 2001 | 01:13 PM
DiecastZ28's Avatar
When I bought my car, it had illegle tint on the windows. I mean you had to put your eye up to the window and your could just see into the car. That and the stickers came off it of and the bar. I didn't want any cops watching me knowing it a kid driving the car plus I want a hot rod not a *****. But when I took the window tint off I used a razor blade to start a corner and the tint came off in big sheets. Then I used some kind off alchole forgot what kind, my father told me to use it to take the glue off. To loosen the glue up I used a hair dyer too. Took me about 2 hours to take all the stickers off and window tint. But the car looks much better now I think as you can see in my sig. =)
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
Polo Z03
Sep 10, 2015 06:43 PM
stalkier
Aug 21, 2015 01:54 AM
3rdgenparts
Aug 8, 2015 07:09 PM
