Remove IMPOSSIBLE Pinstripes
Old Oct 8, 2015 | 11:55 PM
Walmartspinnerz's Avatar
I picked up an 82 z28 with 56000 miles on it. Perfect condition, but it has nasty painted pinstripes everywhere. They gotta go!
I scoured the web for solutions and here is what I've tried with zero success.
- oven cleaner - let soak for 1, then 2, then 10mins - did nothing.
- lacquer thinner - same story
The stripes are definitely on top of the clear coat. But they seem invincible. Anyone heard of this? Is sanding really my only option at this point?
Old Oct 9, 2015 | 08:31 PM
mjdavis68's Avatar
Car: 88 IROC Z/28-under re-construction
Engine: 5.7 Tuned Port
Transmission: It's in there....
Axle/Gears: 9 bolt Borg-Warner
Re: Remove IMPOSSIBLE Pinstripes
This will do it and wont damage the paint
http://www.googleadservices.com/page...el.php&cad=rja
Old Oct 10, 2015 | 03:30 AM
Just to double check - this works on painted stripes correct?
Old Oct 10, 2015 | 07:44 AM
haps's Avatar
Car: 91 Z28
Axle/Gears: Stock
No, it won't. Solvent or sand and buff are about the only option. Dangerous if you don't know what the substrate is.
Old Oct 10, 2015 | 10:08 AM
Abubaca's Avatar
You can't really "remove" painted pinstripes. Well, of course you can always sand and start over, but you can't simply remove them. That eraser wheel is for removing vinyl graphics.
Old Oct 10, 2015 | 11:02 AM
MintWS6FORMULA's Avatar
From: Michigan [Bodacious Member with the Bodacious TA'TAs (Trans Ams)]
Car: 91 Formula - Authentic and REAL
Engine: 5.0 Liter
Let's see photos. Maybe we'll think they don't look bad.
Old Oct 10, 2015 | 01:10 PM
dbrochard's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
Transmission: WC T5
Axle/Gears: Torsen 3.73
I would try removing them with like 1500/ 2000 grit sandpaper very carefully. I'm no expert but that's probably your best bet. Use too stron of a chemical on it and you destroy the paint under it too. Which would be bad
Old Oct 10, 2015 | 03:46 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Can you post some photos......
Hopefully you will be able to sand them off without hitting the actual car. Then trying to blend that area in with a DA Sander and polish of some kind.
Try it in a inconspicuous area and you will know if its feasible or not.
If not then in the end you might have to prep the entire car for paint. That means being able to sand them off if its not possible the other way.
Unfortunately most only have two options when it comes to paint.
A Maaco or a shop costing thousands.......
Old Oct 10, 2015 | 04:12 PM
I'm going to give some very cautious wet sanding a try today with 1000 grit. Pray for me haha
Old Oct 10, 2015 | 09:45 PM
Engine: TBI,5.0
Not an inconspicuous area is there.
Nice looking car though.
Old Oct 11, 2015 | 10:52 AM
jharrison5's Avatar
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
If they were painted over the factory clear coat, and not clear coated themselves, then you should be able to sand them off with 1500+ sand paper and buff the factory clear coat.
Old Oct 11, 2015 | 11:43 AM
Steve Mack's Avatar
Car: 87 Iroc
Engine: modified 350
Transmission: high performance built 700R4
Axle/Gears: Strange S60 3:73
You are correct.The pin stripe are butt ugly.But your Camaro looks super nice.Your best solution is to have a professional paint shop remove them.
Old Oct 11, 2015 | 01:37 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Mask off the surrounding area. Set up running water over the area. Get the best paper available. Go slow. Squeegee and dry the area, viewing it under good light.
If it was done over a healthy, thick, clearcoat, what you want to do is possible but time consuming.
Cheap wet/dry paper will waste your time. If you take it to a shop, they will probably be far more interested in a full repaint than you. Good luck.
Old Oct 11, 2015 | 03:44 PM
t/aws61985's Avatar
Car: 85-6 TA 85 IROC 82-86 MSE 83 Pace
Engine: Slow ones
Transmission: Noisy ones
Axle/Gears: Weak ones
If they are just decals I took mine off with a hair dryer, and water/rag.
Old Oct 13, 2015 | 10:58 AM
haps's Avatar
Car: 91 Z28
Axle/Gears: Stock
I'd try lacquer thinner first. Test a spot in an inconspicuous area that's related to the area your working (fender=fender, door=door). If color comes off then don't use it. If it's clean then use it sparingly and carefully.
Old Oct 13, 2015 | 01:55 PM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
I really didn't notice them at first and then I thought "man, what's that weird reflection of?.....OH!"
Old Oct 14, 2015 | 08:41 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
There is no factory clear coat if this is the original paint. Clear coat started in 1986. With the lower body stripes missing, the car may have been repainted. The striping may be under the clear if the car had a base coat/clear coat repaint.
Old Oct 18, 2015 | 06:39 PM
Sorry if these uploaded out of order, but it looks a lot better now!!! Wet sanded with 1500 grit, then buffed with Meg's ultimate compound. Not perfect, but it's a million times better imo
Old Oct 18, 2015 | 07:55 PM
Steve Mack's Avatar
Car: 87 Iroc
That's a pretty good job,Looks good.
Old Oct 19, 2015 | 07:23 AM
Car: 1983 Z28
Looks good! Glad it worked out for you
Old Oct 19, 2015 | 09:11 AM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Wow, nice job!
Old Oct 19, 2015 | 04:19 PM
scottmoyer's Avatar
If you removed them with 1500, you may need to smooth it out more with 2000 before using compound. The entire panel should be compounded for an even look.
Old Oct 19, 2015 | 08:30 PM
mjdavis68's Avatar
Good job sir
Old Oct 19, 2015 | 08:37 PM
Engine: TBI,5.0
Very nice.
Old Oct 19, 2015 | 09:14 PM
jharrison5's Avatar
Car: '87 IROC
My Step mom has worked in a Kenworth dealership since 1982 and I've seen a hundred trucks come in with pinstripes over the years and watched the body guys just sand them away lol!
I second the sanding with a higher grit to get the best quality.
Old Oct 25, 2015 | 07:28 PM
jmd's Avatar
jmd
Nicely done!
58mark
Jan 17, 2016 06:09 AM
EvilMunky707
Nov 30, 2015 03:00 PM
91_1LE5SPEED
Oct 8, 2015 08:07 PM
roguecoxnet
Mr. McGuire
Oct 6, 2015 07:54 AM
