Underhood Insulation Revitalization
Old Jun 4, 2016 | 01:21 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Since the molded insulation is no longer available and since the new 1/2" thick version won't fit my application (note the indentations in the OE insulation), I threw caution to the wind and decided to attempt a clean-up. I used Simple Green on a towel and softly wiped in the direction of the insulation's weave. I did that several times, then rinsed the towel with clean water and went over it again. Big improvement, I think. Next? I purchased some adhesive-backed Neoprene rubber (1/16") that will cover the hole made by the air-cleaner nut.
Before and after pics.
JamesC
Attached Thumbnails Underhood Insulation Revitalization-img_3902.jpg   Underhood Insulation Revitalization-img_3904.jpg
Old Jun 4, 2016 | 01:43 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Re: Underhood Insulation Revitalization
Nice improvement.
Old Jun 4, 2016 | 05:48 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
It's always a leaking AC compressor that throws refer oil up there.
Looks good.
Old Jun 4, 2016 | 06:11 PM
DynoDave43's Avatar
Old Jun 4, 2016 | 07:18 PM
JamesC's Avatar
Looks good.
Yep. Long repaired.
Thanks!
JamesC
Old Jun 7, 2016 | 10:52 AM
BADNBLK's Avatar
COTM Editor
I have been using plasti-dip with great success on my last couple resto's. Leaves the satin sheen of the original, and will fill in the defects from belt abrasion, or else. You can kinda mat the fibers how they need to lay, then spray.
Old Jun 7, 2016 | 03:47 PM
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
Excellent!
Old Jun 7, 2016 | 04:00 PM
chazman's Avatar
Axle/Gears: BW 3.45
Looks good.
Mine has leaked from day number as well as all the 3rd gens I've owned. The exception being the '89 'vert I just got.
Old Jun 7, 2016 | 04:05 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Most of the GM compressors that followed after the old A6 haven't been very good. Just my opinion....
Old Jun 7, 2016 | 04:08 PM
JamesC's Avatar
Pics?
JamesC
Old Jun 7, 2016 | 05:32 PM
BADNBLK's Avatar
COTM Editor
Originally Posted by JamesC
Pics?
JamesC
From my 1991 Z28 Convertible
Before:
After: 3 cans if I remember correctly
From my Z03 Z28 Convertible:
Before:
After:
Not perfect, but I'd rather have this than the aftermarket replacement.
Old Jun 8, 2016 | 02:17 PM
DynoDave43's Avatar
An interesting idea...
Old Jun 9, 2016 | 03:13 PM
92GTA's Avatar
Wow, didn't know you couldn't get these from the dealerships any more! I bought a new one for my 92 GTA back in 2002 from my Pontiac dealership and it was a perfect identical match for the original. Sadly my STB has worn into it in a couple spots since then. Crap.
Old Jun 11, 2016 | 02:44 PM
JamesC's Avatar
Is this the rubber coating version or something else? Part number or some other identifier?
JamesC
Old Jun 13, 2016 | 09:12 AM
BADNBLK's Avatar
COTM Editor
JamesC
Just the black Plasti-dip in the aerosol can. Should be stocked pretty deep in the auto parts stores or home improvement stored. Most other aerosol paint companies (duplicolor & Rustoleum etc) have their own versions which I think would probably work just fine as well.
Old Jun 13, 2016 | 09:52 AM
JamesC's Avatar
Here's what I ended up with, though I'm unsure if I'm totally lovin' it. I plugged the hole with insulation then used 1/16 inch thick Neoprene self-adhesive sheet to cover the hole on both sides. The naked hood doesn't look too bad, so at some point I might just jerk it altogether and wait for a proper repo.
JamesC
Attached Thumbnails Underhood Insulation Revitalization-img_3927.jpg   Underhood Insulation Revitalization-img_3938.jpg   Underhood Insulation Revitalization-img_3930.jpg
Old Jun 13, 2016 | 10:16 AM
JamesC's Avatar
Thanks. A coat of two might have evened the look up a bit.
JamesC
Old Jun 18, 2016 | 06:24 AM
radracer3's Avatar
Car: 1989 Formula T-Top
Engine: LB9-N10
Transmission: MM5
Axle/Gears: 3,42 posi
Guys,
Did all Gen3's come with that hood pad? My is missing and it almost appears like it did not have one installed to begin with.
All I have on my hood is that ac compressor stripe...
Thx,
Old Jun 18, 2016 | 03:24 PM
irvan's Avatar
Car: 1989 IROC Z28
I think mine is past redemption, I like the look without it but I figure it's probably going to need a lot of clean up under the pad if I remove it. I was gifted the one insulation holder i'm missing so I guess I will just install it the next time I have the hood up.
Old Jun 19, 2016 | 01:33 AM
chazman's Avatar
Axle/Gears: BW 3.45
Originally Posted by radracer3
Guys,
Thx,
Yes.
Old Jun 19, 2016 | 02:01 PM
mikeceli's Avatar
Engine: LB9 305
Transmission: AT
FWIW The Factory Shop Manual for my 1979 Trans Am, SPECIFICALLY states some oil leakage from the front seal, on the A6 compressor is NORMAL. IT says only replace for a Freon leak.
Old Jun 19, 2016 | 03:05 PM
radracer3's Avatar
Engine: LB9-N10
Transmission: MM5
Yes.
Thanks, need to add that to the list now too!
Polo Z03
Nov 22, 2016 06:24 AM
santiclause
Interior Parts Wanted
May 18, 2016 08:01 PM
billybob6110
May 11, 2016 06:20 PM
gpetry
May 10, 2016 09:15 PM
skinny z
May 7, 2016 03:30 PM
