How do I lock in these Louvers?
Old May 11, 2017 | 10:22 PM
BewleyBizzIROC's Avatar
Car: 1989 IROC CAMARO
I recently bought the plastic Louvers for my 89 Iroc of off Ricks Camaros. All they came with was soft washers. How am I supposed to lock them in? I had one fly off today, it didn't break but it got scratched up. $200 gone already :/
Old May 11, 2017 | 11:15 PM
Drew's Avatar
Re: How do I lock in these Louvers?
Nuts.
Old May 11, 2017 | 11:42 PM
Originally Posted by Drew
Nuts.
Its just a plastic strut underneath. I'm not sure how a nut would stay on it.
Old May 12, 2017 | 01:06 AM
Twin_Turbo's Avatar
A speed nut. It's self threading onto the plastic studs. It's not a solid nut like usual but a sort of bulged stamped piece with a slotted hole that twists onto the stud.
Old May 13, 2017 | 07:26 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
When you install them with the speed nuts be very careful not to tighten them. You only want them touching the surface that they are bolting to. If you try to tighten them down you will cut the stud off or strip the usable plastic off.
Old May 14, 2017 | 04:28 PM
jharrison5's Avatar
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
You take all the studs off and replace them with bolts, nuts, washers, and rubber pads. Mine are factory though and the whole project cost me like $10.
Old May 17, 2017 | 04:37 PM
cheves's Avatar
Car: N/A
Engine: N/A
Transmission: N/A
What adhesive did you used?
Old May 18, 2017 | 12:38 AM
Twin_Turbo's Avatar
Why rely on adhesive. If the studs are broken drill a pilot hole and use self threading sheet metal screws. I use m5 flange head torx screws (I use them a lot. My cars are full of them for securing brackets and what not)
Old May 18, 2017 | 09:01 PM
jharrison5's Avatar
Car: '87 IROC
Quick answer is Loctite epoxy, but for the full write up here is my thread listing what I did and products I used. Thread was posted in 2014 so you'll have to scroll down to post #7 for the pics.
https://www.thirdgen.org/forums/body...ud-repair.html
