Remove rust from rear axle housing?
Old Aug 13, 2017 | 11:37 AM
two-if-by-sea's Avatar
Car: 89 RS Vert, 89 Formula, 89 Bird
Engine: L03, TBI 350, none
Transmission: 700R4, 700R4, none
Axle/Gears: 3.42, 3.45, none
While I have the rear dropped, what can I do to remove the rust. Car is a play toy and not a show car, and I'm not looking for perfection. pics:
Old Aug 13, 2017 | 11:52 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Remove rust from rear axle housing?
Wire wheel and white vinegar, or muriatic acid.
Old Aug 13, 2017 | 11:56 AM
I've got a bottle of muratic acid that use for the swimming pool. Does it remove rust? Maybe brush it on with an old paint brush, then wire wheel everything off?
Old Aug 13, 2017 | 11:57 AM
Engine: Lb9
Transmission: M20
It will remove rust rinse with water and keep it away from the aluminum calipers.
Old Aug 13, 2017 | 11:59 AM
Perfect. I'll give it a try and post my results. Thanks for the advice
Old Aug 13, 2017 | 12:09 PM
Engine: Lb9
Transmission: M20
No problem be safe with that acid.
Old Aug 13, 2017 | 08:04 PM
TylerSteez's Avatar
Car: 86 Trans Am WS6
Engine: 383 stroker
wire cup wheels are great to remove rust. just please wear safety glasses, the little wires will break off
Old Aug 14, 2017 | 08:18 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Follow the directions to a T and it will turn out great I have done it to a bunch of rear housings and it hold up awesome
Amazon Amazon
