Firebird Formula hood scoop
Old Jan 2, 2002 | 11:14 PM
89Firebird Formula350's Avatar
I have an 89 Formula 350. Its black, but i noticed the inner part of the hood scoop (the part you can see from inside) isn't black, its a silver color or tin color. I know the owner before didn't do anything with it, so I was wondering if your firebird formula hood scoops inner part matched the body color of your car. I know this sounds a little confusing, but I hope you can help. Not a big deal, but I was just curious. Mine doesn't really look bad the way it is, but i just wanted to know. Thanks a lot!
Old Jan 3, 2002 | 12:24 AM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
well i dont have a formula but i have a trans am with the same kind of hood and mine is black on the inside and my car is white
unless you are talking about something else than i am
Old Jan 3, 2002 | 06:58 AM
'91 Formula's Avatar
Car: 1991 Firebird Formula
Engine: 383 Supercharged and Intercooled
Transmission: 6-Speed
Axle/Gears: Stock 10 bolt 3.42
Re: Firebird Formula hood scoop
Well this is what sound like happened. The plate is painted or powercoated aluminum. Over time, and many waxings, it wares off, showing the aluminum. You could aways get a new one or do what I did. Since our hood are the same that came on tha '84 T/A, which was functional, just order this plate, which has holes in it, from GM. I made a box underneith it for my air induction. Or you could just leave it open and let out the hot air out from under the hood. But the grilled plate looks good. Just a thought.
Old Jan 3, 2002 | 04:26 PM
Drew's Avatar
The 82-84 T/A hood bulge screen has been discontinued for at least the last three years. Check a junkyard for them. If it bothers you just pull it out and rattle can it semi-gloss black.
Old Jan 5, 2002 | 07:08 AM
FBODY-ADDICT's Avatar
I think I read somewhere that the powerbulge hood was offered in aluminum on some thirdgens.
Old Jan 5, 2002 | 05:00 PM
Drew's Avatar
The aluminum hoods were SCCA, Firehawks, and some people with very good connections got them... I'd imagine there aren't many still out there.
Old Jan 5, 2002 | 08:14 PM
HM Murdock's Avatar
Car: 1988 Formula and 1995 LT4 Z28
Engine: 305 TPI and 361 LT4
Transmission: M5 and stalled A4
Classic Industries sells the grill.
Old Jan 5, 2002 | 10:32 PM
TAdan's Avatar
Car: 1984 Trans Am
Engine: GMPP 350 V8
Formula Hoods.
All of the Formulas w/ the Bulge hood that I have encountered (seen in person) Had a silver colored plate inside the bulge, not body color. It may have been the natural finish or painted, I do not know. As far as I know, the "silver" plate is OEM.
My 84 T/A and 83 T/A(had, before the cowl hood) the functional powerbulge hood's. There is a grill located where the silver plate is on the Formy and a functional cowl unit that matches up to the aircleaner mounted under the hood.
Old Jan 7, 2002 | 12:11 AM
Drew's Avatar
Actually they don't, they sell the blockoff plate. The grill is a honeycomb screen that was stock on 82-84 Trans Am's and has been discontinued for quite a while.
xkingcodex
Feb 12, 2020 07:43 PM
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
ElPaleterro85
Aug 13, 2015 03:49 PM
