Carpet cleaning
Old Dec 21, 2017 | 10:40 PM
podiatra's Avatar
Car: 1986 Camaro IROC-Z
Engine: 350 swap
Transmission: manual
Carpet cleaning
Hi all,
I will be cleaning the carpet inside my Camaro. What’s the best product/ process that any of you could recommend?
Thanks in advance!
Old Dec 22, 2017 | 01:49 AM
Neil350's Avatar
Car: 93 Trans Am
Transmission: T56 Street Twin
Axle/Gears: 12 Bolt 3.90
Re: Carpet cleaning
There's several ways, depending on how bad it is. If it's just a maintenance clean, I use a portable carpet cleaner like a bissel spot remover. Use fabric cleaner with hot water in the tank, as well as a spray carpet shampoo, brush it down really well. Can mix some thing like oxy clean or tide in to a paste and scrub in the bad spots it while your doing that. Use the spot remover to suck up the excess water and allow it to dry really well. Best to do it in the summer, especially in Texas since it'll dry fairly quickly. A steam cleaner also works really well, I use it on leather while I am using a cleaner to pull it out tough spots.
If the carpet is really bad, you can pull it and soak it in a kiddie pool with oxy clean or some sort of detergent and then scrub it with detergent like oxy clean, can also pressure wash it if it's out of the car. Depends on how much effort you want to put in it.
Old Dec 25, 2017 | 01:43 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Re: Carpet cleaning
Try using "FOLEX" comes in a white bottle. AMAZING stuff for cleaning and spot removal. Made the carpet and door panels in my old 87 TA look like new.
GREAT product.
http://www.folex.net/
Old Dec 25, 2017 | 05:22 PM
Lakerman62's Avatar
Car: 1985 Z28 & 1997 Z28 SS SLP
Engine: Sbc 305 TPI & LT1
Transmission: 700r4 and A4
Axle/Gears: 9 bolt Posi 323 & Posi 323
Re: Carpet cleaning
Originally Posted by podiatra
Hi all,
Thanks in advance!
All of the suggestions are spot on, I've used Folex too great for pet smell BTW, also stubborn spots react well to cheap shaving cream, I know it sounds crazy. If the carpet is really bad, u get a new one as well
Old Dec 25, 2017 | 08:38 PM
podiatra's Avatar
Engine: 350 swap
Re: Carpet cleaning
Thanks! The carpet is not that bad. I wasn’t sure if I should steam wash it or do it with a handheld device. Sounds like I need to do in th summer to allow for better drying??
Old Dec 25, 2017 | 10:08 PM
Neil350's Avatar
Car: 93 Trans Am
Re: Carpet cleaning
Either way would be fine, hand held sucks a lot of the water and detergent back out. Steam cleaning drys pretty quick, so long as it gets some time to air out you'll be fine.
Old Dec 26, 2017 | 09:10 PM
podiatra's Avatar
Engine: 350 swap
Re: Carpet cleaning
Super thanks!
Old Dec 27, 2017 | 12:21 PM
88IROCvertZ's Avatar
Car: 1988 IROC Z Convertible
Engine: 305 TPI (LB9)
Transmission: 700 R4
Axle/Gears: G80 GU2
Re: Carpet cleaning
Steam cleaning is really good and they make small ones for vehicles if you’re really into detailing.. nothing wrong with a carpet cleaner like resolve, a bucket of water, a brush and a wet vac.. you don’t need too much water.. focus on the soiled areas.. let it sit a few minutes, scrub again and wet vac..
Old Dec 27, 2017 | 08:15 PM
podiatra's Avatar
Engine: 350 swap
Re: Carpet cleaning
Wow! I di have a wet vac, but havent use yet and have not read the instructions...
Old Sep 14, 2020 | 10:05 AM
RickeyHoyt's Avatar
Re: Carpet cleaning
Yes, by reading instructions you can use wet vac for carpet cleaning.
Berlinetta Baby
Nov 26, 2013 12:47 PM
TunedportL98
Jul 25, 2006 09:29 PM
azcamaro
Dec 3, 2003 07:26 PM
IROC57TPI
May 21, 2002 02:14 PM
LeftTurn1LE
Feb 12, 2002 12:35 PM
