View Poll Results: June 2018 Car of the Month
Ls2 GTO
11.48%
dmccain
22
36.07%
tonys91rs
8.20%
prossi
27
44.26%
Voters: 61. You may not vote on this poll
June 2018 COTM **Voting Thread**
Old May 20, 2018 | 08:08 PM
Linson's Avatar
COTM Editor (Retired)
Car: 89 Formula 350, TTA
June 2018 Car of the Month...
Ls2 GTO*****1992 Purple Haze Z03 Z28
dmccain*****1989 Formula (Trans Am Clone)
tonys91rs*****1991 Camaro RS
prossi*****1987 GTA
Old May 20, 2018 | 11:04 PM
prossi's Avatar
Re: June 2018 COTM **Voting Thread**
Thanks for the nominatioI have owned this car on and off since 1994 I bought it back in 2011 and have been improving it since. I do run the car on the track and put it through it’s paces. This last time I built the car I completely took it down to just the shell and built and detailed it all. I replaced just about everything
I have set the car up for track use but it does remain a street car with all the comforts...I even did a custom vintage air set up in
Of course I have some more I want to do to it but my Next mod is a roll cage which should be in soon
Here is a list of some of the current mods
383 stroker motor all forged with AFR heads and HSR intake it’s built to hold up running at the RPM’s it does
last time I dynoed it put down 414hp 432tq to the wheels...not huge power but it does what I need it to do When I ask it to
March front drive kit
Aluminum radiator w/Canton overflow tank
Custom fuel system w/ aeromotive components
Centerforce billet flywheel
Spec stage2plus clutch
Quick time bellhousing
Libertygear modded tremec TKO trans w/ short throw shifter
Tilton hydraulics
Heidts high horsepower IRS rear suspension w/ aluminum Yukon 3rd member
Heidts K member
Heidts a arms
Heidts SFC’
Quick ratio steering box
PS cooler
Wilwood aero6 front 15”brakes
Wilwood 12.8” rear brakes
Ridetech rear shocks
Custom front struts
TSW wheels wrapped in RE71 tires
Vintage air A/C
Corbeau racing seat
AIM data acq system
OMP shift **** and pedals
Braille trunk mounted lightweight battery
Old May 20, 2018 | 11:29 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Fantastic car, prossi.
Old May 20, 2018 | 11:57 PM
Richardman1992's Avatar
Car: 2021 LT1
Engine: Lt1
Transmission: Tr6060
Love that car! Nice 4th gen as well!
Old May 21, 2018 | 07:22 AM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Thank you guys so much for the nomination. Bought the car in 2014 after being out of a Thirdgen for 7 r 8 years. It was very mechanically sound but in need of body work and paint at around 90k mi. Car had started out an 89 Formula but PO had added ground effects so I stayed with that theme and replaced the warped pieces, cracked factory wing, and went with crosslace wheels. Also went through and replaced every bit of the suspension as far as replacing springs, shocks, struts,end links, etc.. all the usual worn out things. My father and my sons helped me with the paint and bodywork project which made it a lot more fun. Other mods ive done are 3.73 posi rear, S10 torque converter, shift kit, 3" Flowmaster exhaust system, custom chip, to name a few off the top of my head. I use the car to go to shows, cruise ins, and sometimes to church on nice Sunday evenings. It has been very fun and very reliable and trouble free. The 5.0 TBI engine runs very sound but I have an L98 on the engine stand now I'm going to tear down over the winter to replace the L03. Again thanks so much for the nomination. So many great cars on here
aaaaaaaaa
111111
Old May 21, 2018 | 08:46 AM
tonys91rs's Avatar
Car: 91 Camaro RS
Engine: 305 TPI conversion.
I bought this beat up and neglected teal RS back in 2000. Since then I’ve done most of the upgrades and repairs on my own. She’s not perfect but she’s mine.
305 TPI conversion
headers
streefire electronics
a/c and smog delete
4th gen coolant tank
T56 conversion from t5
4th gen 373 rear and drive shaft
LS1 front brake conversion
dynomax exhaust
UMI, BMR, TDS suspension upgrades
4th gen leather seats
IROC steering wheel conversion
z28 gauge panel upgrade
Orange paint
Iroc Hood
ZR1 wheels
Old May 21, 2018 | 01:09 PM
blunierdr's Avatar
Car: 87 Trans Am GTA
Engine: Vortec Stealth Rammed L98
An '87 GTA with a Stealth Rammed small block setup for track use. It's kinda like my car but way better! Not to mention how in love I am with that suspension setup and center exit exhaust right underneath the rear differential. Prossi you have an amazing ride.
Old May 21, 2018 | 02:03 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Originally Posted by prossi
Are those exhaust hangers that are coming off of or by the driver's side seat belt bracket and then another in the rear passenger side seat area? Can't tell if that is what they are or something else?
Old May 21, 2018 | 05:12 PM
prossi's Avatar
Yes those are exhaust hangers andthey aren’t just screwed into the floor pans if that’s what your wondering 😁 there is reinforcing plates welded to the floor pans under the carpet with weld nuts on them so the exhaust can be bolted in and out but most importantly doesn’t fall off😛
Old May 21, 2018 | 10:10 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
dmccain, that car doesn't just shine, it dang near glows! Now that's a proper red
Old May 22, 2018 | 07:11 AM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
GM named it bright red and rightfully so. Thank you we worked hard on it. Six coats of clear it should shine lol.
Old May 22, 2018 | 10:13 AM
vinny R's Avatar
Car: 1991 Z28
Axle/Gears: 3:42 Auburn
I love that color also. When in the sun it will literally blind you! I know, that is the paint code I have. Great job dmccain!
Man this is a tough one, Prossi's ride is over the top but I also have admired how clean and nice you have keep that bird.
Old May 22, 2018 | 05:14 PM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Prossi has a wicked hot-rod for sure! All these cars are nice.
Old May 22, 2018 | 05:52 PM
prossi's Avatar
All the nominees have put hard work into these cars so props to all!!
Also forgot to add my GTA is a digital dash car with dove interior and paint is originally gunmetal gray with 68k miles....I have to take some interior pics i
Old May 28, 2018 | 07:25 PM
Buddy's Avatar
Car: '87 FIREGOOSE!!!!
All sweet cars.
Old May 30, 2018 | 12:07 AM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
dmccain,you got my vote.
Old May 30, 2018 | 12:54 AM
mantaguy's Avatar
Engine: 5.0 EFI
prossi, your car is GORGASE ,great job in the mods you made,you would have got my vote for Modified if this was a Stock Vs. Modified voting thread.
PS ,I think we should have a Stock and Modified voting thread for each month.
Old May 30, 2018 | 11:39 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
So you would change your vote if the title of this thread was different.
Old May 31, 2018 | 08:41 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Very cool cars yet again !!!
Linson
Nov 24, 2018 11:04 AM
Linson
Apr 2, 2018 11:44 PM
Linson
Feb 27, 2018 01:29 AM
Linson
Jan 31, 2018 07:31 PM
Linson
Dec 31, 2017 10:38 AM
