Re-painted a valve cover and not happy with results
Old Jun 11, 2018 | 06:38 PM
MY87LT's Avatar
Car: 1987 Camaro LT
Engine: LG4 w/ SLP headers & a 3" catback
Transmission: THM700R4 (Stock)
Axle/Gears: Stock 2.73 gears. No Posi
I know I screwed up somewhere. But, after watching a comprehensive video on You Tube on how to paint a valve cover and come up with great results, I bought all the supplies and had a crack at it.
I had ordered a set of decent silver/gray TPI valve covers that needed some repaint. I decided to go a bit custom and go a bit darker but still have metallic sheen to it. Everything seemed to be going well until I came up with a color just too dark. Going to have to re-strip and start over again.
Pic#1 is before any prep work.
Pic#2 is using aircraft paint stripper
Pic#3 is the first coat of paint after three coats of high temp ceramic primer
Attached Thumbnails Re-painted a valve cover and not happy with results-20180610_150057.jpg   Re-painted a valve cover and not happy with results-20180610_150554.jpg   Re-painted a valve cover and not happy with results-20180610_190328.jpg
Old Jun 11, 2018 | 06:39 PM
MY87LT's Avatar
Car: 1987 Camaro LT
Re: Re-painted a valve cover and not happy with results
Last pics.
Pic#4 is after three coats of paint and one coat of high temp clear coat.
Pic#5 is the final product which was three coats of primer, three coats of paint, and three coast of clear.
Attached Thumbnails Re-painted a valve cover and not happy with results-20180610_190650.jpg
Old Jun 11, 2018 | 06:48 PM
MY87LT's Avatar
Car: 1987 Camaro LT
Sorry, computer acting up right now. Here is pic#5
Attached Thumbnails Re-painted a valve cover and not happy with results-20180610_195642.jpg
Old Jun 11, 2018 | 08:26 PM
dagwood's Avatar
Top Answer: 1
Car: 1986 Camaro Drag Car
Engine: 383 on Ethanol
Transmission: Automatic
I don't think it looks bad....
Old Jun 11, 2018 | 08:27 PM
Abubaca's Avatar
I'm not sure I'm following. Where'd you screw up? -they look pretty good to me. ....unless you simply don't like the color. That's not really a screw up.
Old Jun 11, 2018 | 09:29 PM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Looks good to me. Id sport em.
Old Jun 11, 2018 | 10:30 PM
NoEmissions84TA's Avatar
I don't see anything wrong with that.
Old Jun 11, 2018 | 10:37 PM
MY87LT's Avatar
Car: 1987 Camaro LT
It's the color. I was hoping for it to be a lot lighter. As far as the work that went into it, I'm ok with it. This weekend I'll do a side by side comparison with the lighter one that's already installed.
Old Jun 12, 2018 | 09:48 AM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
I like the color in photo 3.
"Pic#3 is the first coat of paint after three coats of high temp ceramic primer"
Old Jun 12, 2018 | 09:52 AM
MY87LT's Avatar
Car: 1987 Camaro LT
I used Duplicolor Metal Cast paint. The cap appeared to be the color in pic#3. One coat just didn't seem enough to make it last. Possible that three coats was overkill and made it darker.
Old Jun 12, 2018 | 10:25 AM
vinny R's Avatar
Car: 1991 Z28
Axle/Gears: 3:42 Auburn
I like em! I don't think 3 coats is overkill. Some paints need multiple coats to achieve desired results. I am curious to see if it maintains the shine through the heat cycles of the engine.
Old Jun 13, 2018 | 01:18 AM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Chrysler color med gray
Old Jun 14, 2018 | 03:47 PM
TallTim's Avatar
Car: 1989 Formula T-Top
Engine: 350 TPI, twin turbo
Nice job on the finish, after so many coats it's easy to screw up one pass and get a sag or run then ugh.
I've used the metalcast with their color coat being a tinted clear. Each successive color coat adds tint and deepens the color. I found one of my runners hard to re-paint and get the same as the first time I did them.
FWIW looks really nice to me!
Old Jun 14, 2018 | 04:19 PM
t/aws61985's Avatar
Car: 85-6 TA 85 IROC 82-86 MSE 83 Pace
Engine: Slow ones
Transmission: Noisy ones
Axle/Gears: Weak ones
I would just get them powder coated. Usually the best way to go. Not too expensive as well.
Old Jun 14, 2018 | 04:42 PM
Steve Quinn's Avatar
Car: 1990 Camaro IROCZ
Axle/Gears: 3.45
I just lightly sand and panted over with silver rust oleum engine paint.
Attached Thumbnails Re-painted a valve cover and not happy with results-9bd6c483-a0d9-47b4-883a
Old Mar 25, 2019 | 06:09 PM
1986BANDIT's Avatar
Car: 1986 trans am
Engine: 305/350
Transmission: 5 speed
take them both off,prep both of them then paint both together using one lot# of spray paint.this way they match and have the same color
Old Mar 26, 2019 | 07:16 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Adding to the old thread....
Mid America Spruce Paint...."Spruce Nickle" is the color of Original Valve Cover. Google Mid America Spruce Paint.
Old Mar 26, 2019 | 05:09 PM
6998poncho's Avatar
Car: 1998 Firebird Formula M6
Engine: LS6 installation finished 8-17-2011
Axle/Gears: Stock 3.42 Ratio
I'll second that comment. If you want a finish that is oil, heat, and solvent resistant that is the way to go. They have high heat finishes that work particularly well in engine compartments and when you add in the cost of your labor and time there's no comparison to rattle can finishes and I've done a lot of those too.
Old Mar 27, 2019 | 07:32 AM
Firebat's Avatar
This is my method when I spray paint stuff:
1.Wetsand the old paint
2. Wash and clean really good
3. Sometimes use primer, mostly only if I have exposed metal or uneven area or scratches. Sand again if I used primer. Clean again.
4. Apply Spray Paint
5. Apply clear if necessary.
I kind of consider the old paint the primer. It's sticking to the metal just fine and probably better then the spray paint I will apply. A lot of the time the item is powder coated or better paint then spray paint. 99% of the time I have no problem with spray paint sticking to sanded down paint with no primer. Using paint stripper takes a lot more time and doesn't always remove the paint evenly.
The spray paint I use:
A. Rustoleum High Performance spray paint in the silver can is the best spray paint I have used. It is way different then even the regular white can Rustoleum spray paint. Silver can RHP paint dries in 15 minutes. I have not tested this paint in the engine bay yet though. Just discovered it last year and used it on my mowers.
B. Krylon Plastic Fusion - Amazing for plastic. Painted plastics with this in temperatures as low as 40 degrees and stuck to the plastic with no issues.
Old Jun 17, 2020 | 11:21 AM
MY87LT's Avatar
Car: 1987 Camaro LT
I went ahead and ordered this paint from Corvette Central yesterday. As soon as it arrives, I'll prep the valve covers, repaint them, and post pictures. Hopefully I'll get the results I am looking for.
quick90rs
Aug 8, 2009 03:30 AM
NOSFEDGTA
Apr 28, 2005 09:25 PM
seanof30306
Dec 21, 2003 08:23 PM
Kj Rockz
Mar 21, 2003 06:36 PM
poncho9789
Nov 27, 2001 09:51 AM
