Testing the Avatar, check out the pic if it works.
Old Jan 23, 2002 | 12:02 PM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
If it doesnt post, might you know what I am doing wrong?
Old Jan 23, 2002 | 12:10 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Re: Testing the Avatar, check out the pic if it works.
You must resize your picture to 64x64 pixels using a program like ACDSee, and then save it as a gif. Then upload it to your profile.
Old Jan 23, 2002 | 12:18 PM
Anyone know how to convert the flash movie to something this site supports?
Old Jan 23, 2002 | 12:24 PM
JPrevost's Avatar
Car: 91 Red Sled
If you've got flash 5 just change one of the output parameters to make an animated gif file. As long as it isn't a huge animation with lots of detail it should be all good.
Old Jan 23, 2002 | 12:27 PM
Re: Re: Testing the Avatar, check out the pic if it works.
I just downloaded acdc and tried to save it as a gif from flash.
Oh yeah I'm using flash 5.0 to make this animation. How do you use a animated avatar?
Old Jan 23, 2002 | 12:34 PM
test
Old Jan 23, 2002 | 12:37 PM
Nightcruzer's Avatar
Car: Trans Am
Your problem might be in the size of the file. It can only be a MAX of 20000 bytes or 20kb. I had to shorten mine for that reason. Once you upload the gif file, it will play automatically under your user name.
Old Jan 23, 2002 | 12:40 PM
maybe it takes a while to load to the server?
I'll also try to attach it.
Your right its 74018 bytes
but there she is
come on avatar
Attached Thumbnails Testing the Avatar, check out the pic if it works.-redbird_400_lightning.gif
Old Jan 23, 2002 | 12:51 PM
>ok the image is now 17,000bytes
>just updated the avatar
>I'll also put it here as a attached file
>it may not be the whole image but............
Old Jan 23, 2002 | 12:54 PM
That I dont get, right click on it and go to the properties. It looks perfect. So unless the server is slow I have no clue what to do from here.
Old Jan 23, 2002 | 01:54 PM
does anyone use web hosting for pix anymore? IF so where, eg. webshots, geocity, anglefire......????
Old Jan 23, 2002 | 02:45 PM
Joe91Z28's Avatar
test
Old Jan 23, 2002 | 10:07 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
You're just attaching the image, you have to actually put it in your avatar using the options in the User CP section.
EDIT: And BTW, "test posts" are no longer necessary. Once you update it, the board updates the avatar and/or sig on all your old posts.. so just come back to a post you made and check it out.
Old Jan 23, 2002 | 10:26 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
anglefire and ,geocities will not let you have links from an outside source to show pics
so like if you put a link here toshow a picture from a geocities account it will not work
but homestead.com will let you do that
that how I host my pics
BRoss99
Aug 10, 2025 05:08 PM
69 Six Pack
Oct 5, 2015 07:51 PM
Mickeyruder
Sep 2, 2015 02:45 PM
justin57
Aug 20, 2015 07:05 PM
