1984 Trans Am factory yellow undercoating removal
Old Aug 15, 2025 | 10:54 PM
TA392's Avatar
Anyone know what is best to remove the GM factory waxy yellow rust proofing / undercoating ? Thanks in advance.​​​​​​​
Old Aug 16, 2025 | 03:40 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: 1984 Trans Am factory yellow undercoating removal
Pretty sure that's not factory applied.
I've seen a thread or 2 about that stuff, not easy to remove iirc.
Old Aug 18, 2025 | 12:17 PM
GearheadSS's Avatar
Car: Yellow Gold 1986 IROC-Z
Engine: LG4 305
Dry ice removal maybe?
Old Aug 18, 2025 | 04:50 PM
TA392's Avatar
I found degreaser and a paint brush works best but its time consuming and messy, not something you can do in the driveway.
Old Aug 18, 2025 | 05:18 PM
Firechicken82's Avatar
Car: 82 TA
Transmission: Magnum f
Axle/Gears: Ford 9 w 4.11
For what it's worth, there are places that steam clean engine bays. IDK if that will take it off or not.
Old Sep 12, 2025 | 09:25 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
ive used mineral spirits to clean the bottom of my vert before I re-undercoated it with fresh undercoating. it didnt hurt the factory paint but took the undercoating off. you could try a test area and see if that works
Old Nov 5, 2025 | 05:27 AM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
I removed mine many years ago with a gel based engine degreaser from Gunk. I sprayed it on, let it sit and then pressure washed it off. It was messy and a lot of work, but it came out looking really good. I did need to do additional detailing after removal to clean up any residue, but for car shows, it was worth the effort to me.
Old Nov 24, 2025 | 09:42 PM
chevypower91's Avatar
Car: 1991 Camaro Z28
Engine: 305 cid
Transmission: 5 speed
Axle/Gears: Posi/3:42
Have you tried using WD40 it works really well.
Gen X T/A
Oct 20, 2013 05:14 PM
82tarecaro
Sep 6, 2010 03:46 PM
scotty d
Nov 1, 2000 10:53 PM
