Materials needed to clean and polish GTA rims
Old Jan 30, 2002 | 01:09 AM
Stormshadow GTA's Avatar
What should i use to clean and polish my GTA rims
Old Jan 30, 2002 | 01:23 AM
SilverChevy's Avatar
For the love of *** do a search
Old Jan 30, 2002 | 02:04 AM
na too lazy
Old Jan 30, 2002 | 08:45 AM
SlowCamaro88SC's Avatar
use aircraft paint stripper all over. get factory paint off. wetsand with 240 till it's all clean, and it all looks the same. do the same with 320,400,600,800, then 1000 grit. for each higher grit, take a long time. take your time with every grit, and I mean take it slow to make em' perfect. then don't bother to hand polish. it just won't work. get something elecric like a dremel or something bigger. then just go to town polishing. time is a factor again. try your damndest to make them look like chrome. you'll be impressed with your work. I did this all last weekend on my GTA lookalike wheels on my grandprix, and it got cold again after sunday, so I haven't been able to go @ them with the final polishing via, electric drill. and they already look awesome.
Old Jan 30, 2002 | 10:55 AM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
Now, Im not tryin to correct anyone here, but I personally wouldnt, and dont use sand paper on GTA rims. Its easier to just strip off the clear, polish with aluminum polish, and reclear. Sanding them is quite iffy, and can leave tiny scratches which are very hard tog et out if you dont do it right!
Old Jan 30, 2002 | 10:42 PM
do the GTA wheels have a "machined" finish?? my crosslace wheels on my grand prix do that's why I sanded mine. they look just like GTA wheels. I used all those types of sandpaper, and the wheel looks flawless, no scratches whatsoever. that's why the transition from 320 to 400 then so 600 is extremely important, it is during this grey area that any scrathes can be fairly easily removed. 1000 and higher is cosmetic. it's for a better factor of reflection.
Old Jan 31, 2002 | 07:28 PM
ttt... I'm actually curious whether or not the GTA wheels have a machined finish or not. I can't remember, but then again I don't have a GTA. Ah well, I still made my crosslace wheels look better. :rockon:
Old Jan 31, 2002 | 07:53 PM
When I sripped my GTA wheels to bare aluminum, there was NO machined finish! The "machined" finish is merely how the clear coat is applied.
Old Feb 1, 2002 | 12:45 PM
on my wheels, I had to sand it off after I used aircraft stripper.
IROCZ1989
Jan 24, 2016 03:55 PM
kah992
Aug 19, 2015 02:55 PM
kyleb24
Aug 15, 2015 08:24 AM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
