getting a project car!!!!!
Old Feb 19, 2002 | 05:02 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
hey all,
i just put a down payment on a 1987 Z28
its in decent condition but needs some work
i am buying it from MSS, he's the moderator at the street racing board
thanx MSS
its white, it needs a new fender, passenger side GFX
it also needs a new tranny
its got a nice strong motor though.......its a 305 with a rebuilt top end and some performance parts on it.....sounds mean
so i am prolly gonna paint it 100% white (GFX and all) and put in a new tranny...............i am debating whether to put in another 700R4 or convert to a T56.......................
the primer on the front bumper didnt come out so good.............so i wanna re-do that
whats the best way to sand it off????
Old Feb 19, 2002 | 08:27 PM
Blue502's Avatar
Strip it with SEM flexable parts stripper. Get it at your local automotive paint store. Works great.
Old Feb 19, 2002 | 09:31 PM
cool thanx blue502
i guess i should take the rest of the paint off the body with that stuff
cuz i am gonna do all the prep work myself and then get it painted at maaco like i did my current camaro (turned out great)
how much primer should i put on it???
then i wetsand the primer util glass smooth right?
Old Feb 19, 2002 | 09:56 PM
mss's Avatar
mss
heres what i had planned man .
1)finish the body work , fill in all old dings etc etc re-primer with the flexable **** (7.99@auto zone)
2) finish the suspension(including wonderbar)
3) world class t-5 swap
4) black paint w/91-92 gfx
5) 3.42/disk/posi rear (g92 and 4th gens got em)
thats about it , i just ran out of money and time
Old Feb 19, 2002 | 10:26 PM
thats almost what i have planned
i think i am gonna put a T56 in it though...........
gonna cost me some major $$$ but this is gonna be my car i'm gonna bring to the track.................
first i am gonna do all the bodywork and get it painted
Old Feb 19, 2002 | 11:12 PM
Blue502's Avatar
No, that stuff is designed specifically for urethane parts (ie: bumpers and TA lower side gfx). I imagine you could use it but it works slowly compared to regular aircraft stripper, plus it is more expensive. Don't ever use aircraft stripper on urethane, because you very likely seriously damage the parts.
I never recommend using paint stripper on the actual body. It is easier and less messy to sand it down with a good DA sander. Plus if you don't get all the stripper out of the nooks and crannies and cracks, it can eat through your new paint.
Old Feb 19, 2002 | 11:24 PM
thanx for telling me
lets put it this way: when it comes to bodywork, i have NO idea what i am doing
could you gimme some general tips what i should do and in what order to do it??
i am assuming:
use the stripper you mentioned to get the paint and primer off the bumpers and GFX
then sand the paint off rest of the car (metal)
what grit sandpaper should i use??????
then primer the whole thing
then wetsand
(what grit sandpaper should i use?)
then take it to get sprayed
i am going to keep it the original color
but i am gonna try to get them to use a dual base/dual clear coat job
Old Feb 19, 2002 | 11:38 PM
Blue502's Avatar
Any areas where you need to do body work, you'll need to go bare. 80 grit should do you fine for that. For the rest of the car I'd just scuff it up with 200-400 grit depending on the power of your sander (feathering out any chips or scratches) and prime with a sealer primer, then a sandable primer. Wetsand the sandable primer. Maybe do another coat or sandable primer, or maybe a few more if needed. Use a glide coat when you think you are close to done.
If you have never done body work before, a book on the subject from your local Barnes and Noble or whatever would certainly help. You can also practice on old scrap fenders and hoods if you are uncertain about your abilities. Any flaws that shows up in the body work stage will probably show up 10 times worse after you paint.
Just remember, paint is a system. Use primers and reducers designed to work with the brand and series of paint you are going to use. When painting my cars I have always put on at least 2 coats of basecoat color, and 5 coats of clear, though 3 is sufficient if you only want to colorsand lightly or not at all. Remember to use flex agent in the paint you use on the bumpers, but don't use flex agent on the main body. It is much much better to paint with the bumpers, side mirrors, and gfx removed from the body (as well as any parts or weatherstriping you don't want painted)
Old Feb 19, 2002 | 11:40 PM
Blue502's Avatar
Oops, forgot to mention. Strip the bumpers and gfx after you remove them from the car. Don't do it while still attached to the body. And follow the instructions exactly.
Old Feb 20, 2002 | 12:19 AM
yeah, considering i am gonna take the car to get sprayed, i dont think i am gonna be pulling any body parts
but i still think i will prime the car myself
i think i remember seeing like one very small little dent on the driver side door.................how do i fill this in?
Old Feb 20, 2002 | 01:51 PM
mss's Avatar
mss
well believe it or not i used this stuff called "marine tex" on my old ss . what i did was sand the spot bare , apply the stuff so its flush with the rest of the body , than fine sand it until it looks right . marine tex is some really wicked stuff it works for basically everything
or you could just replace the door molding , thats why the dent is there
Old Feb 20, 2002 | 01:58 PM
hmmmm yeah i cant decide on whether or not i want the door moldings back one...............anyone know where i can find them?
looking forward to this car though...............man, i'm finally gonna have a V8 camaro
i think i even have a few sources to get the 700R4 rebuilt...................
hey jeff, i cant remember, does it have headers on it already?
i'm trying to think of some mods for the engine...............................prolly a cam and roller rockers.................dual roller timing chain......................some cool stuff
Old Feb 20, 2002 | 02:03 PM
mss's Avatar
mss
nah i never got to doing headers . tho, thats the only thing holding it back really lg4 manifolds are the worst!!!!! i bet you get almost half a second from a good set of headers and ypipe . the rest of the exhaust is already done . oh yeah the cam in it is 204/206 i belive and like .425 lift . i dont remember the exact specs i have to find the card
Old Feb 20, 2002 | 02:23 PM
ok cool, so the hardest part (the cam) is out of the way
guess that means i can put some roller rockers on it, and some new valve springs
guess i'll also get some headers..............
and a nice 4.10 rear gear with posi and discs
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Fast355
Dec 2, 2016 06:33 PM
Irocohio
Aug 12, 2015 08:03 AM
bryan623
Aug 10, 2015 11:33 AM
