Will an SS 17X9's fit my car ?
Old May 3, 2002 | 02:08 PM
DozaChris89TA's Avatar
I can get a set of rims off a 99/00-SS-17x9 for $400 and i was wondering if they will fit my 89 T/A, if not what can I do i have to do to get them to fit also is $400 a good deal?
Old May 3, 2002 | 02:29 PM
irocdan's Avatar
Car: 88 Iroc vert
Engine: 305 tpi. cts-v brakes
Transmission: Tremec T-56
first:yes thats a good deal,second:you'll need adapters
try www.wheeladapters.com i got mine for bout $300.
i have the zr1's on mine
Old May 3, 2002 | 08:25 PM
camaro6spd's Avatar
DUDE...you have the best look IROC convetible...OMG, i love white and i love black but the gray...OMG that is really really..OMG i dunno....:hail: :hail:
Old May 3, 2002 | 09:15 PM
350IROCconv's Avatar
That is a sweet camaro but why must you have adapters? I've got a v8 4x4 s-10 with zr1 rims off a 98 ss and they fit perfectly with no adapters. the reason i was asking was because i want to put them on my 88 iroc-z convertible.
Old May 3, 2002 | 10:13 PM
Twistopher's Avatar
Car: 91 Z28 Convertible
Engine: 305TPI
Standard camaro wheels have 5.5 inch back spacing. 93-on camaros have 7 inch backspacing... If you mounted them they would mount 2 inches closer and could causing a rubbing problem in the front. In the rear I dont think it would be a problem because you can fit an 17x11 in there. Like irocdan's above. but it would also be 2 inches further into the wheelwell and look a little funny. S-10s wheel wells might be a little different.
Old May 7, 2002 | 03:35 PM
irocdan's Avatar
Car: 88 Iroc vert
thanks camaro6spd,i'm doing lots of upgrades now hopefully
i'll have more pics when i'm done or just pics of what i'm doing...
Old May 12, 2002 | 01:23 PM
rad8tion's Avatar
Car: 92 RS Convertable
Engine: RAMJET 350
Transmission: G-FORCE T-5
The 2wd S10 have the same backspacing as a third gen but the 4x4 S10s use a different backspacing the bolt pattern rim is closer to the outside of the wheel like in a 4 gen.
What I was wondering, I know a 4 gen rear end will bold in to a third gen but it is wider so will it fit and look rite if you use 4 gen rims?
Old May 12, 2002 | 04:56 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Here is my car with a 4th gen rear,
First 2 are with my WS6 wheels and the last one is with my Brothers OZ Monte Carlos,
4th gen wheel doesn't even come close to mounting on the front wheels.
Old May 14, 2002 | 06:04 AM
rad8tion's Avatar
Engine: RAMJET 350
Zepher how did you get the front wheels to fit? Just use spacers?
Ryan
Old May 14, 2002 | 02:15 PM
Zepher's Avatar
Ya, I used 2-1/4" bolt-on wheel spacers that I bought from www.vettebrakes.com. Cost me $176.50 shipped for the pair.
If you look closely, you can see the spacer,
Old May 14, 2002 | 04:07 PM
theREIS's Avatar
Hey DozaChris89TA is there another set lyin around? Thats a really good deal, I would love to pick those up?
Old May 26, 2002 | 09:39 PM
jawzforlife1's Avatar
just thought i'd ad my pc to a dead post.
Old May 27, 2002 | 03:50 PM
86IROCTHD's Avatar
Car: 88 Trans Am
Engine: lt1 intaked 355 makin 277 on 25 psi of fuel pressure and stock timing :)
Transmission: A4 stock... that moved a mobile dyno a foot shifting into 2nd :)
what bout the 17X11's
hey will the 17X11's fit on the back of the IROC's? i want the 17X9's in the front and 17X11's in the back would i have 2 "tub" the rear end?
Old May 29, 2002 | 03:21 PM
irocdan's Avatar
Car: 88 Iroc vert
i posted pics of my car earlier on this topic,i have the 17x11's on the rear.no tubbing but adapters and some massaging to the inner fender walls and i rolled the fender lipps.if you want info
on where to get the tires,wheels or adapters.email me at
irocdan@hotmail.com.i'll tell you the best places to go.
customblackbird
Aug 15, 2021 10:16 PM
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
matthew911
Aug 12, 2015 09:38 AM
armybyrd
Aug 10, 2015 09:23 PM
