Have you ever seen this tire brand?
Old May 25, 2002 | 03:06 PM
DISTURBthePEACE's Avatar
Car: 89 Camaro RS
Engine: 2.8L V-6
I have some American GT Grand Turbo tires on the rear of my car. The only problem is, I can't find them anywhere but Salina, KS, which is bout 2 hours away. Nobody in my area has ever seen or heard of the brand. Can any of you help? I need 2 for sure, mabye a new set by the time I find them. The guy said they were rather expensive, at bout $150 a piece. Any info is great.
Old May 25, 2002 | 06:09 PM
bradkeith's Avatar
I am not trying to be the bringer of bad news but there is no way those tires are $150 a piece. they are probably50-70 $ a piece. If i was you i'd look into a different brand of tires.
Old May 25, 2002 | 08:10 PM
Tom Keliher's Avatar
Here you go:
http://www.accconline.com/grandturbo.htm
http://www.tirepros.com/products/american.html
The tire is made by Michelin and sold under the "American" tire brand name. Shouldn't be too hard to find a local retailer who carries the American brand tires, or else you can probably order them online and have them shipped to your home.
Old May 26, 2002 | 10:56 AM
IROC350TPI's Avatar
Car: 89 IROCZ28
Engine: 350TPI
Axle/Gears: 2.77 Gears
You could go pretty much anywhere and buy a cheaper Z-rated tire for less than $150. I just bought some Ultra Z's from Pepboys, nothing special but they get the job done and they look good, plus they were only $100 each, luckily I have access to mounting equipment otherwise it would have cost about $150 per wheel to mount and balance with the tire.
Ryan
Old Apr 5, 2005 | 11:00 AM
1meanGTA's Avatar
Car: 1987 GTA/1998 Explorer
Engine: 355, trick flow heads, zz409 cam, 3
Transmission: 700r4, shift kit, valve body
Axle/Gears: precision 3.73's, auburn diff
sweet christ, you joking? cost me 75 bucks to get all 4 275/40 17s put on, and they did it in about 20 minutes while i waited.
Old Apr 5, 2005 | 01:40 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Ultra Z tires are nice tires if you want to save a buck and don't care about the horrible dry traction and downright dangerous wet traction, but for hardly any more money you can buy something like a kuhmo that will actually stick to the road.
Old Apr 5, 2005 | 02:15 PM
dual_88s's Avatar
From: In my own little world - but they know me well in here
Car: 88 Sport convertible
Engine: 305TBI
Transmission: AUTO
Axle/Gears: 3.42 rear end
yeah just picked up a couple of kumho ecsta for 188 total installed for the pair
Old Apr 5, 2005 | 11:26 PM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
dude i have those tires........ Im in Ohio i paid $389 installed and aligned. Just a heads up they're trying to get you for some money. They're traction isn't great, but the sidewall being as tall as it is doesn't flex very much when inflated properly. They lasted me about 15000 miles but that was with a 5 speed plenty of torque and an alignment that went bad and didnt realize it. Both wheels were leaning in. I still have them on my project car just to let the car roll around. also mine were 215/65/15's
Old Apr 6, 2005 | 05:11 AM
Night rider327's Avatar
Car: 1988 Camaro
Yall sure are paying high prices for mount & balance
I buy my tires (yoko avids s/t) online at tirerack then take em to the local good tire shop.
$10 a wheel for mount & balance. But they do other stuff for that $10 a wheel too
take old tire off, wire wheel clean wheel sealing bead, put in new valve stems, mount tire, and high speed computer balance wheel/tire, and they keep old tire.
Old Apr 6, 2005 | 09:47 AM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
best price i could find in the area was $16 a wheel mount and balance
Old Apr 6, 2005 | 03:40 PM
dual_88s's Avatar
Engine: 305TBI
Transmission: AUTO
hmmmmm let's see
$188(for 2)x2=$376 for 4 tires mounted balanced and road hazard warranty.....
you $389 for 4 AND a front end alignment. PLUS they were smaller tires...215/65/15 as opposed to my 245/50/16
Yeah sounds like they were really trying to take my money.....
Old Apr 6, 2005 | 10:39 PM
AJT86's Avatar
Car: 87 Buick Grand National
Engine: 3.8 SFI Intercooled Turbo
Transmission: 200R4 3000 Stall
in NJ we have a tire tax for each tire its either 2 or 4$ i forget they started that last year
Old Apr 6, 2005 | 11:43 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
[QUOTE]Originally posted by dual_88s
[B]hmmmmm let's see
$188(for 2)x2=$376
deadbird's Avatar
Engine: TPI 305/ v6
hmmmmm let's see
To play devils advocate.. maybe 87CIZ was replying to the originator of this post ($150 per tire/$600/set)....
Not psychic though..
Old Apr 7, 2005 | 01:18 AM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
I bought my kumho escta 712's for around 120 a piece and they look good and perform great. They do good dry or wet.
Old Apr 7, 2005 | 11:05 AM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
I forgot to say also that this was 5 years ago..... And yes deadbird that's what i was replying to..
Old Apr 9, 2005 | 09:10 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Check out a BF Goodrich Radial TA, good looking tire, reasonable price, right size white letters, wear decent, ride nice, plenty of traction and performance for the 2.8 or most V8s. Had several sets and no problems. Just a suggestion.
1992rs/ss
Jan 31, 2025 05:10 PM
Scamo-2.8
May 20, 2016 07:01 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
my86bird
Oct 23, 2015 12:20 PM
Dialed_In
Aug 20, 2015 01:45 PM
