lighted switches in the overhead console
Old Jun 25, 2002 | 10:07 PM
Teds92RS's Avatar
Car: 1989 Camaro IROC-Z
Engine: Lt1
Axle/Gears: Quick performance 9" 4.11
Hey guys, I remember a while back someone installed I think 4 lighted switches in the overhead console replacing those counter things. Can that person post how they did it for me?
Thanks, Ted
Old Jun 25, 2002 | 11:03 PM
Tonyrodz's Avatar
Transmission: auto
I think that was nosaint--he has a web site w/alot of cool mods--www.nosaint.ca
Old Jun 25, 2002 | 11:25 PM
nosaint's Avatar
Car: 1986 Trans Am
I had three non lit switches in there but then switched to a cheesier version and now im working on adapting a digital compass/timer in there.
Old Jun 26, 2002 | 08:09 PM
Teds92RS's Avatar
Engine: Lt1
nosaint......how did you insert that plastic peice and how did you take out the spinners without damaging he console?
Ted
Old Jun 27, 2002 | 12:12 AM
nosaint's Avatar
Car: 1986 Trans Am
I used a dremel. Once you take it off it becomes easier to see what you can cut off and what needs to stay. I attached the plate using hot melt glue and have never had a problem with it. Pretty easy.
Old Jun 27, 2002 | 06:49 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Should anyone be looking for console bodies, I have several in the classifieds.
JamesC
Old Jun 29, 2002 | 11:45 PM
Teds92RS's Avatar
Engine: Lt1
nosaint- did you mount the switches to the panel, then mount the panel to the console? or did you mount the panel by itself first then determined where u wanted the switches and mounted them?
Thanks, Ted
Old Jun 30, 2002 | 12:48 AM
nosaint's Avatar
Car: 1986 Trans Am
I first cut out that cheesey counter and then made a template out of thin cardboard. Once i got it the way i liked it i transfered it over to a sheet of thin metal and cut the switch holes. I then mounted the switches and glued the panel to the console. I installed quick disconnect for all the electrical connections to aid in the install.
hope that helped.
T
Old Jul 1, 2002 | 09:57 AM
Teds92RS's Avatar
Engine: Lt1
thanks man, i'll let you know how it turns out.
Ted
Old Jul 10, 2002 | 01:01 PM
redraif's Avatar
Car: 87 Red/Blk Bird loaded 3.4L & 700R4
Transmission: Th700R4
Sounds like you did your the same way I did mine NoSaint. I have 6 switches in mine though. A few of them are giving me issues though. There are just too many wire up there at the moment. I have illuminated switches. I had a heck of a time installing mine after I did it. The wires took up all my clearance under the console. But they definately look better than the dials. I got mine from a yard and someone had already busted up the dials, so removal was no prob.
Here's a pic of my mess as I did the install.
Attached Thumbnails lighted switches in the overhead console-o-console-wires.jpg
Old Jul 10, 2002 | 01:20 PM
redraif's Avatar
Here is the finished product:
Attached Thumbnails lighted switches in the overhead console-overhead-console.jpg
1992 Trans Am
May 10, 2023 07:19 PM
Pilotrick50
Sep 2, 2015 12:48 PM
DiabolicalRS
Aug 26, 2015 07:35 AM
TheJoeY88
Aug 13, 2015 06:51 PM
Omega
Aug 10, 2015 12:46 PM
