Door problem
Old Jul 24, 2002 | 08:12 AM
SLOW5.0's Avatar
Door problem
Howdy all,
When I hit a bump in the road it sounds like my door is loose. It only happins with the window down or cracked. I replace the striker. Can you adjust the door catch? Thanks for any input.
Old Jul 25, 2002 | 05:34 AM
SLOW5.0's Avatar
ttt
Old Jul 25, 2002 | 05:36 AM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
Check to see if the UPPER or LOWER door hinge is worn out. Lift the end of the door by hand, and watch the UPPER hinge joint for any looseness.
Thanx,ANDYZ28
Old Jul 25, 2002 | 11:01 AM
SLOW5.0's Avatar
nope replaced them about 4 months ago...thinking about getting a new latch assy form classic ouuuch the money they want for it.
Old Jul 25, 2002 | 11:21 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Are you sure its actually the whole door? When my windows are down, the windows rattle because the I don't have the inner weather strip seal on, and my felt pads are worn out.
Old Jul 25, 2002 | 06:27 PM
ANDYZ28's Avatar
Car: 1982 Z-28
You replaced your UPPER door hunges 4 Months ago?
Old Jul 25, 2002 | 07:14 PM
SLOW5.0's Avatar
I replaced the pins in both doors. The window seems tight and not loose in any way.
Old Jul 25, 2002 | 08:50 PM
ANDYZ28's Avatar
Car: 1982 Z-28
You must have replaced the pins in the LOWER hinge. The UPPER is not replaceable with readily available parts, that I am aware of.
Old Jul 26, 2002 | 09:01 AM
SLOW5.0's Avatar
Its an 1980 fbird sorry for the confusion.
Old Jul 26, 2002 | 02:16 PM
ANDYZ28's Avatar
Car: 1982 Z-28
OK Now I got it. I was talking about 3rd gen cars.
www.3rdgensolutions.com
Thanx,ANDYZ28
Old Jul 26, 2002 | 06:17 PM
87'IROC5.0's Avatar
Most of my cars without window frames on the doors had rattling problems with the windows. To eliminate a loose window from your list of causes, roll the window down half way and drive on the roads that you hear the noise on, if the noise goes away when you grab the glass then you know what it is.
NOTE: I never did fix the rattling windows on my cars, just lived with it since most of them were living on borrowed time.
1992 Trans Am
May 10, 2023 07:19 PM
1Aauto
Sponsored Vendors
Apr 9, 2018 03:00 PM
86IROC112
Apr 9, 2016 10:20 PM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
