questions on 85mph cluster to 145mph swap
Old Sep 14, 2002 | 09:21 AM
zee28's Avatar
Car: 86 iroc
I got a 145 mph cluster and want to replace my 85mph gauges.How do I keep the milage right?can I just take the face off and roll it back and If I do do I have to get this certified in someway to be legal?Also can I swap the 145 gauges to my 85mph cluster?(white part)I kinda messed up the back of the white cluster on the 145 set.Everything looks the same.Anything else I should know???1986 iroc.thanks
Old Sep 14, 2002 | 07:53 PM
chevymad's Avatar
Car: 87 Formula
Engine: 327
I just put a 120 cluster in my formula instead of an 85.. Yes you can put just the speedo unit in your old cluster.. To keep the mileage the same I took the odometer unit out of the speedos and swapped them.. It's just a few screws. Turning it back would be harder.
There shouldnt be anything else you need to do. Should be a direct swap.. I had questions when I did mine. The first 120 speedo I put in read wrong. But it turned out to be a bad speed unit. The second works perfectly with no other changes.
Old Sep 15, 2002 | 02:43 PM
BadBird84's Avatar
Car: 1984 Pontiac Firebird
Engine: 2.8l :(
Transmission: T-5 Five Speed
So if u put the 120 guages in the 85 mph pod it will ready correctly? I thought it was harder than that, could u explain tha process for me please?
Old Sep 16, 2002 | 12:17 PM
jocww's Avatar
Car: 84z, 65 elcamino
Engine: l69 and a hyped up sbc in the camino
Transmission: t5 m21
Axle/Gears: 373s 411s
is that the same for the 145 u dont have to redo ur speedo so that when ur goin 50 it wont say 40
Old Sep 16, 2002 | 12:48 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
It's easy to roll the numbers if you take them out. This of course is only legal in order to show the CORRECT milage when swapping gauges. It's probably easier just to take the numbers from your original speedo and swap them into the 145 unit.
Old Sep 16, 2002 | 01:00 PM
IROCmonkey's Avatar
Car: 85 IROC
Engine: LB9
all 3rd gen camaro speedos from 82-89 are a direct swap, just plug and play. many states dont even keep track of the mileage on cars that are 10yrs old or older, titles just say odometer exempt or the like.
Old Sep 16, 2002 | 03:28 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I have done mine a couple of times, granted your ding a camaro, but it should be similar, remove, swap Odometers, and replace...
remember to wipe everything cleen inside your dash so not to find fingerprints tho
John
Old Sep 16, 2002 | 03:33 PM
zee28's Avatar
Car: 86 iroc
just swapping the rolls sounds easy enough,so i will just do that.thanks for the help.
Frozer!!!
Jan 19, 2024 04:55 PM
Jeremys87
Jul 14, 2022 09:08 PM
355sbcTPI
Aug 19, 2015 04:38 PM
redmaroz
Aug 16, 2015 11:40 PM
ChevyZ71
Aug 13, 2015 07:30 AM
