power windows?
Old Oct 1, 2002 | 06:15 PM
f0rmula350's Avatar
power windows?
my windows go up and down real slow. are my motors going? i ve heard stuff about that just being one of the flaws with the fbodys. i dont know
chris
Old Oct 1, 2002 | 07:14 PM
TX_1987_GTA's Avatar
Car: 1987 GTA Hardtop
Engine: 350 T. P. I.
Hey there Chris....
I have a 1987 GTA, and I have lubricated everything I can lubricate. Everything works as it should. I dont know if its usual, best I recall my 1991 Camaro wasnt this slow. But I just wanted you to know that mines slow too..... Good Luck, Joe
Old Oct 1, 2002 | 08:47 PM
sheltonw3's Avatar
Car: 91' TRANS AM Modified
Engine: Classified
Transmission: Auto with Overdrive
power windows eh!
Four things are possible
1:Wires are corroding
2:Motor or arm may need some powdered graphite lubricant its dark and looks like pecil lead dust.
3:Power relay maybe going bad and needs to be replaced.
4:If its been raining hard recently in your area water may have seept into the motor, this happend once on 84' I had and the motor needed to be replaced on the driver side window after the mechanic disassymbled the motor it self!
Old Oct 1, 2002 | 08:55 PM
f0rmula350's Avatar
thanks for the replies. im just gonna wait till something dies to fix it. im not trying to tear apart my doors to try something that prob wont fix the problem. goddamn im lazy.
Old Oct 1, 2002 | 08:58 PM
sheltonw3's Avatar
Engine: Classified
power windows!
Another easy way is to simply replace the door and change the locks if you can find one the same color?
Old Oct 2, 2002 | 12:32 AM
2vmodular's Avatar
Re: power windows!
New window motors are around $50 aftermarket. Replacing the entire door because of a defective window motor is overkill.
Old Oct 2, 2002 | 06:09 AM
rocky383's Avatar
Car: 88 IROC-Z
Engine: 383 Stroker
Transmission: TH350
Re: Re: power windows!
I agree.
:hail:IROC-Z
Old Oct 2, 2002 | 08:11 AM
I agree as well thats a little overboard... The way i see it mine will just be slow untill they go out then I can address the problem. Its really not a problem at this point, just an annoyance .
Old Oct 2, 2002 | 11:36 AM
MdFormula350's Avatar
i had recently replaced my passengers power window motor, because it was so worn out that the window would stop like halfway and i had to wait a bit to get it to go down..
my drivers side is like 3 to 4 seconds slower to go up/down..
i am waiting on that to break soon, i give it another year...
new motor only like 50 to 60 bucks, i got mine from Advance Auto Parts and it has a lifetime warrenty..
good luck, changing motors is not hard, just takes time and another persons hands to help you.. it took me and my pop about hour and a half including the trip to the store..
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Sep 13, 2015 09:07 PM
stalkier
Aug 21, 2015 01:54 AM
