what's the weight of a camaro??
Old Oct 1, 2002 | 10:40 PM
92TPIZ28's Avatar
Car: 1992 Camaro Z28
Engine: 355
Transmission: T-5 w/centerforce dual friction plate clutch
i have a 92 z28 and i'm wondering how heavy is it. i thought around 3600 pounds, but i just did a search and someone said 3300 pounds, now i'm confused. and if you know the weight of the stock hood please let me know, thanks for all your help.
Old Oct 2, 2002 | 02:21 AM
88Bravo's Avatar
Car: 1988 Pontiac Firebird, flat black
Engine: Stock 305 LO3
Transmission: Five speed
My 88 Bird with the 305, headders, and stuff in it, not a lot but some and me not in it was 3420lb. I am not sure how acc the scale was, it was the one on base but I hope that helps.
Old Oct 2, 2002 | 12:22 PM
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
Transmission: ZF 6 speed
Axle/Gears: Dana 44 3,33
Hey how much is that in kilos ? I dont know what you mean by Ibs it doesnt say anything to me.
Old Oct 2, 2002 | 01:04 PM
Diabolical's Avatar
Car: 85 Trans Am WS6
Engine: 305HO L69
scania, 2.2lbs = 1 kg, so you can just divide the weight by 2.2. bravo's 3420 lb car is 1555 kg
Old Oct 2, 2002 | 01:18 PM
BORLAZ06's Avatar
Aint the shipping weight 3194??
Old Oct 2, 2002 | 01:27 PM
Saywhut's Avatar
2.2 will get you close as a conversion factor, but it's actually
kg = 2.204623 pound
As the weight increases, you get further off if using 2.2 as the conversion factor. In the case of the 3420# car, the true weight in Kg: 3420 pound = 1551.286 kg
Old Oct 2, 2002 | 02:14 PM
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
Ok thank you . We use kilos and meters over here thats why i didnt understand.
Old Oct 2, 2002 | 05:25 PM
johnsjj2's Avatar
Car: 1991 Z-28
Transmission: T-5 (gonna buy the farm)
You guys and that dam metric stuff!!
Old Oct 2, 2002 | 08:23 PM
Rage13's Avatar
Car: 89 Firebird
metric is much easier once you get used to it
Old Oct 3, 2002 | 01:13 AM
spike1856's Avatar
Car: '86 SC
Engine: '88 2.8L
Uh, the sticker on the door of my 86 SC says 3889lbs (1767kg) if that's any help.
Old Oct 3, 2002 | 04:07 AM
Saywhut's Avatar
You can get the "restoration package" for your car by calling GM and asking for it. The C/S number is 1-800-222-1020, not sure if that's the one you need but they'll be able to get you the right one.
The package has copies of the MVMA specification forms, which have all the weights for the car and different options listed. It's free.
You can also take your car to some truck stops and some dragstrips and have it weighed.
Old Oct 3, 2002 | 04:55 PM
johnsjj2's Avatar
Car: 1991 Z-28
Rage 13, you are right. But what gets me is when a car has half metric, and half SAE size bolts. We do the same on our engines at work. Half the bolts, hoses, and tubing is all in mm. Other bolts, are standard.
Old Oct 4, 2002 | 08:49 AM
polishdevil's Avatar
Car: 88 GTA
My 87 GTA with an 89 350pti, dual cats, headers weight in at 3570
Dave
Old Oct 4, 2002 | 05:01 PM
Rage13's Avatar
Car: 89 Firebird
and some torx to, i'm just waiting for them to throw in some of those square bolts..
Old Oct 4, 2002 | 05:17 PM
REVLIMIT's Avatar
Car: 1984 Chevy Camaro
Engine: Built L98
Transmission: T-56 6 speed
from what I know my car (91 RS) had a weight of 3,350 stock. I found one place that had the weights of all the cars and what not. But I forgot the url sorry.
Old Oct 4, 2002 | 05:36 PM
Anth's Iroc's Avatar
Car: 87 IROC-Z
Engine: =350 sbc
Transmission: TH350
Mine is 3408 thats what it marked on my registration
Old Oct 4, 2002 | 06:45 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
My 86 Trans Am with full interior, small speaker box and amp rack and 1/4 tank of gas weighed in at 3390lbs.
Old Oct 4, 2002 | 09:53 PM
Car: 88 GTA
my car sounds like its heavy compared to all your cars.
Dave
Old Oct 5, 2002 | 12:53 AM
Zepher's Avatar
my car was also a 5 speed.
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
