Need help w/cargo cover mount!!!!
Old Oct 27, 2002 | 08:39 AM
GreenRS's Avatar
Car: 1992 RS Heritage Edt.
Engine: 305(LO3)
I got a cargo cover for my 92, but it didnt come with one. I removed the trim panels to find the outline for the mounts but there's no place for the screws to go into. Any ideas?
Old Oct 27, 2002 | 01:41 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
check the tech articles.
JamesC
Old Oct 27, 2002 | 06:17 PM
TPIterror's Avatar
Car: Formula
Transmission: M5
Its pretty simple really. Just locate about where the mounts go(by either looking at a car or a pic of a car with them), drill a 2 or 21/2 inch hole with a hole saw( I forget the exact diameter so measure the mounts), then just crazy glue them in. You don't need the reinforcements behind the mounts because the tension of the cargo cover will keep it rigid enough.
You will need the reinforcement that goes behind the trim panel on the hatch though(where the blind connects to when it opens).
You can still order this from GM. I bolted it in and just used a drill to make the holes for the attachment points. It works great. E-mail me if you need more specific directions.
Old Oct 28, 2002 | 12:41 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Hole saw??
Just cut out the holes by following the outlines of where the mounts go. Get yourself a set of metal brackets off another car or make your own, hold them where they should go, mark that spot with a Sharpie, and screw them to your car with sheet metal screws ...done.
Ed
Old Oct 28, 2002 | 09:09 AM
TPIterror's Avatar
Car: Formula
Transmission: M5
Yeah..hole saw...its a $5 attachment for a drill and will make a better, more precise cut.
Also, the metal brackets behind the mounts are NOT necessary.
Old Oct 31, 2002 | 08:00 AM
GreenRS's Avatar
Engine: 305(LO3)
If either one of you two guys have pics it would be most helpful.
Old Oct 31, 2002 | 02:08 PM
ebmiller88's Avatar
No flame intended, terror. Just thought it was a bit overkill for interior panels..my opinion and I'm sure it'll work just fine.
Green, what exactly would you like pics of? Just the location or what?
Ed
Old Oct 31, 2002 | 06:11 PM
TPIterror's Avatar
Car: Formula
Transmission: M5
No biggie...I'm just trying to save him time. The metal reinforcements that go behind the round plastic brackets aren't really necessary. And the hole saw attachment for the drill makes a faster, cleaner cut.
I dont have any pics, but no lie, it took me like 10 minutes to put in the brackets and another 10 minutes to drill and screw in the reinforcement that goes in the hatch trim piece. Its really easy..go to GM and get the reinforcement and check out a car that has a cargo cover already.
Old Nov 1, 2002 | 07:59 AM
GreenRS's Avatar
Engine: 305(LO3)
I would like to see the backing plate so I can detirmine if thats what I want to do or not, but because I dont have access to a car that has one, any pics would help. After I use the hole saw, what do you recommend to cut those notchs out with, a Dremmel?
Old Nov 1, 2002 | 10:29 AM
TPIterror's Avatar
Car: Formula
Transmission: M5
Well, if you dont get the reinforcement, the cover will pull on that plastic piece on the hatch when its closed. It's about 4 inches long with holes for the cover. The factory one is riveted on. I just drilled two small holes and bolted it on with shallow nuts and bolts.
If you go to the dealer, they'll have a detailed illustration that they can print out for you. The reinforcement is like 6-7 bucks.
Old Nov 1, 2002 | 10:30 AM
TPIterror's Avatar
Car: Formula
Transmission: M5
Oh, and yeah a Dremel will definitely work better than the drill bit that I used!
Old Nov 1, 2002 | 12:32 PM
GreenRS's Avatar
Engine: 305(LO3)
Hey Terror, thanks for the tips, I'll see what I can do with it this weekend and try an dlet you know how it turns out.
Old Nov 1, 2002 | 02:17 PM
91Zman's Avatar
Car: 1991 Z28
Transmission: 4L60 automatic
Attached Thumbnails Need help w/cargo cover mount!!!!-im000728.jpg
Old Nov 2, 2002 | 10:06 AM
GreenRS's Avatar
Engine: 305(LO3)
Thanks for the pic, do you have a pic of the inside so i can see the guts of this thing.
Old Nov 2, 2002 | 10:17 AM
91Zman's Avatar
Car: 1991 Z28
Well this is basically it,a square type sheetmetal frame/bracket that holds the round shade holders in place.
Attached Thumbnails Need help w/cargo cover mount!!!!-im000729.jpg
Old Nov 2, 2002 | 10:18 AM
91Zman's Avatar
Car: 1991 Z28
Attached Thumbnails Need help w/cargo cover mount!!!!-im000730.jpg
Old Nov 2, 2002 | 01:39 PM
Rage13's Avatar
Car: 89 Firebird
sorry to get off topic but do you guys know if you can order those plastic "anchor" things in the pic? (white square looking thing if your not sure what i mean) i've looked in 5 auto stores in my area and not one of them have these things...
Old Nov 2, 2002 | 04:24 PM
JamesC's Avatar
I've picked them up at the boneyards and a local body shop. They're fairly common so I'm surprised you haven't located any.
JamesC
Old Nov 2, 2002 | 05:07 PM
91Zman's Avatar
Car: 1991 Z28
for those clips..
yeah,nothing like the 5 finger discount at the junkyards.
Old Nov 3, 2002 | 07:27 AM
GreenRS's Avatar
Engine: 305(LO3)
:hail: Zman Thanks for the pics!!!!! Hopefully i can make this happen. Let me ask for some advise. My interior is tan. Should I paint the mounts tan or leave black?
Old Nov 3, 2002 | 07:31 AM
GreenRS's Avatar
Engine: 305(LO3)
Oh yeah, the guy looking for those anchors, they are sold at Autozone or Orielys or just about any other parts store in the trim and fasteners section
Old Nov 3, 2002 | 09:07 AM
91Zman's Avatar
Car: 1991 Z28
Do what ya like but I'd leave them black being that you got a sort of a rare color car,a Heritage Edition at that.
Hotrodboba400
Dec 10, 2019 07:07 PM
FormulasOnly
Sep 6, 2015 10:42 AM
SG91camaro
Sep 5, 2015 10:27 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
