Should my heater light up?
Old Nov 4, 2002 | 09:37 PM
DISTURBthePEACE's Avatar
Car: 89 Camaro RS
Engine: 2.8L V-6
My heater/air-conditioner doesnt light up and I can't see it at night. Is it a light-bulb or what? Any info will help!
Old Nov 4, 2002 | 10:39 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
You've guessed right. The bulb(s) in the HVAC controls have most likely burnt out.
Old Nov 5, 2002 | 11:07 PM
Car: 89 Camaro RS
Engine: 2.8L V-6
How do I change that? I dont even know where it is or what HVAC stands for! lol, any insite on how to change them?
Old Nov 5, 2002 | 11:15 PM
deadbird's Avatar
Engine: TPI 305/ v6
(HVAC... Heating, Ventilating, Air Conditioning)
Take the trim off around the radio-a/c controls, remove the 4 hex screws from the controls and pull it out some (but not too far), you should see the wires (usually a black and a grey) going to the bulb(s). They should just pop (tug or twist.. I forget) out so you can change them.
Old Nov 5, 2002 | 11:17 PM
Car: 89 Camaro RS
Engine: 2.8L V-6
Sweet, I'll do that tomorrow, thanx alot!
Old Nov 6, 2002 | 10:49 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Hey, Distrub,
Don't expect an incredible difference--though certainly replacing the bulb will help. Even with a higher intensity 194 bulb, the brightness is limited by inferior design.
JamesC
Old Nov 6, 2002 | 11:29 AM
Car: 89 Camaro RS
Engine: 2.8L V-6
THanx james, I'll keep that in mind, but any light is better than no light, am I right?
Old Nov 8, 2002 | 10:24 PM
fast83camaro's Avatar
Car: 1983 Camaro "SC-350"
Engine: Mild 350 4-bolt
Transmission: 700R4 w/ TCI Stall
To make the lighting brighter in my HVAC controls, I took off the radio/HVAC trim. Then, I actually popped off the front clear part with the lettering on it off of the controls. There is a black sheet of plastic behind the clear plastic peice, controlling how much light shines through. I made the hole where the light shines through it bigger, and now it is alot brighter. If you need any more details IM me on aol as thefast83camaro.
Old Nov 11, 2002 | 11:18 AM
Car: 89 Camaro RS
Engine: 2.8L V-6
Pulled out my heater, and there is no lightbulb back there...am I missing something?!?!? Am I doomed to have an unlighted heater the rest of my car's life (which will be a very long time!)
Old Nov 14, 2002 | 07:48 PM
Car: 89 Camaro RS
Engine: 2.8L V-6
I checked again when I had a little more time, and still no light. Is it hidden somewhere that I have to move a bunch of stuff?
Old Nov 14, 2002 | 08:05 PM
JamesC's Avatar
Pull the heater assembly out a bit. The light should be on the upper passenger side. If nothing is there, feel for the hole where the socket inserts. If the hole is there, but the socket/bulb is missing, seach around a bit. Could be that the socket/bulb has managed to work its way out and is flopping around somewhere--turn the lights on at this point.
JamesC
Old Nov 14, 2002 | 08:08 PM
Car: 89 Camaro RS
Engine: 2.8L V-6
aight, thanx for the help, ill go check it right now.
Old Nov 14, 2002 | 11:06 PM
deadbird's Avatar
Engine: TPI 305/ v6
I forget but, I think camaros only had one bulb in them. Here's where they are on a firebird control (red arrows)... a camaro would have at least one in a similar location. IIRC as well (my camaro has a 'bird hvac in it), the camaro control has a 194 bulb in it as well ? Don't quote me on any of that except where the bulbs on in the picture..
Old Nov 15, 2002 | 06:25 AM
JamesC's Avatar
The Camaro 194 bulb is on the backside of the controls.
JamesC
Old Nov 15, 2002 | 06:02 PM
Fade00's Avatar
Is it possible to change the color of the bulbs? I'm trying to convert all my dash lights to blue, orange looks so.... 80's. =)
Old Nov 15, 2002 | 07:36 PM
Cuno's Avatar
yeah...it is a pain in the a** though. The instrument cluster ones are a little difficult, you have to remove the bulbs from behind the gauges. If you pull of the gauge bezel and the plastic piece, then the metal piece, you will see what I mean. They are kind of back behind the speedometer gauge. I used needlenose pliers the firsat time I switched them out. The second time, I removed the whole gauge cluster to replace it so it was a little easier.
Old Nov 15, 2002 | 08:17 PM
ZRated85355's Avatar
I was bored and now i just found somthing to do!! change the bulbs in my heater control ( no ac).......
Old Nov 16, 2002 | 11:06 AM
Car: 89 Camaro RS
Engine: 2.8L V-6
I found the lightbulb hole, but there is not bulb or connection to be found anywhere! Its not the only light im missing though. I was going to put a light where the stock shift light is, but there is no bulb connection there either, same with the security bulb and one or 2 more on the gauge. Is it some kind of wierd factory delete? Is there another way to get my heater to light up...maybe a 3" neon...
Old Nov 16, 2002 | 03:30 PM
Car: 89 Camaro RS
Engine: 2.8L V-6
I found it!! It the bulb connection was WAY back in the back and I literallyhad to pull out my stereo, its adapter, and the stereo trim to find it, but I found it, and my heater now lights up!
Old Nov 20, 2002 | 05:44 AM
davecamaro's Avatar
Car: Bonnievillie
Engine: 3.8L
WE HAVE LIGHTS THERE?!?!?!?!?!?!?!??!?!
I never thought we have lights there!
COOL
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
fasteddi
Sep 10, 2015 09:32 AM
andy74
Sep 3, 2015 08:41 AM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
Omega
Aug 10, 2015 12:46 PM
