4TH/3RD gen subframes
Old Nov 18, 2002 | 07:52 PM
AFast83z28's Avatar
Can 4th gen subframe connectors be put on a 3rd gen?
Old Nov 18, 2002 | 09:18 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Re: 4TH/3RD gen subframes
I am pretty sure that they are not interchangable since the places that sell them have 82-92 and 93+ listings, but I could be wrong.
Old Nov 18, 2002 | 09:20 PM
AFast83z28's Avatar
Re: Re: 4TH/3RD gen subframes
Yeah I figured that but Ia lways see 4th gen going for so cheap I figured itw as worth a try. What all is interchangeable? I am putting a 4th gen backseat and maybe a console for sure in mine..I would like see a 98-02 ss wing on a 3rd gen to see what it is like..
Old Nov 18, 2002 | 09:35 PM
Zepher's Avatar
Ok, here is a small list that I know are interchangable since I've done it,
Lower Control Arms
Panhard Bar
Rear Sway Bar
Rear Sway Bar Endlinks
Driveshaft
Exhaust CatBacks
Rear End
Rear Springs
Seats
Center Console (Direct Bolt in if you have a Firebird)
Rear Shocks
Steering Wheel
Wheels with appropriate adaptors
And I think that is about it.
Old Nov 19, 2002 | 03:47 AM
89firechicken's Avatar
you forgot to mention the spoiler and i belive raif has 4th gen side mirrors
Old Nov 19, 2002 | 09:56 AM
Zepher's Avatar
Well, I was talking about bolt on's with no mods.
A 4th gen spoiler off of a 4th gen won't fit perfectly, you need to do something about the two center pillars that don't meet up to the hatch on our cars.
The 4th gen mirrors require some cutting and drilling to get them to mount, but from what Shannon told me, it's not all that hard.
LT1 is a drop in if you don't have the A/C, wiring shouldn't be too much hassle.
LS1 front brakes can be used as well, just some drilling and cutting to get them on. This is an overall good upgrade for the 3rd gens.
Old Nov 19, 2002 | 10:07 AM
LT1guy's Avatar
Car: 1987 Trans Am
The mirrors were easy...made a template, marked three holes, drilled them, and dremeled out the center. Took a couple hours the first time, most was spent making the template and doing the first one. We could do it again in probably 15 minutes. The only part thats halfway tough is welding up the holes in the door for the old mirrors. My 85 is getting this mod, and Shannon's 82 probably will also.
BTW 4th gen interior mirrors are another easy upgrade (lighted), as well as the gas tank (late ones are plastic).
Old Nov 20, 2002 | 02:38 PM
MRZ28HO's Avatar
Car: was: 1984 Camaro Z28
Engine: was: L69
Transmission: was: 700-R4
To answer the original question ... NO! Although the rear suspension is identical, the front suspension (and sub frame) is completely different. On thirdgens, the front sub frames angle in toward the tranny, next to the cat location. On fourth gen, the sub frames are straight out. You would have to modify the sub-frame connectors severly to get them to work. Cost less to get '82-'92 connectors.
nugentcj
Camaros Wanted
Dec 22, 2015 02:58 PM
my86bird
Oct 23, 2015 12:20 PM
New2Chevy
Sep 28, 2015 12:35 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
