Interior Panels!!
Old Dec 3, 2002 | 08:21 PM
Electron_Blue's Avatar
Car: 83 Camaro
Transmission: th350
Interior Panels!!
Can sombody that has their car aprt allready show me what the fasteners look like that hold on the plastic interior panels and about how many do i need for my whole interior.....previous owner's system was stolen and they all dissapeared...until now ive just dealed with it....and if somebody knows off the top of their head it would be highly appreciated if you could show me using photoshop or something the approximate location of each of the fasteners onto the metal(car body)......thanks to anybody thats helps me out
Old Dec 7, 2002 | 03:13 PM
Car: 83 Camaro
Transmission: th350
com'on cant somebody at least describe what the fasteners look like?
Old Dec 7, 2002 | 03:18 PM
Skatepunk60's Avatar
Car: Hardtop 84' z/95' Cheyenne
Engine: 305 H.O./4.3L
Transmission: 5-speed manual/Auto
Alright man i switched out my whole interior so i can help ya with most your questions i hope, on the long panel theres two fasteners on the side under the weather stripping the female part is the exact same part that the big plastic screws screw into and the male part is a platic pin like on the door panels any other questions just ask
Old Dec 7, 2002 | 04:09 PM
Car: 83 Camaro
Transmission: th350
ok so in the metal body part of the car are there plastic square pieces i need to get with like a hole in the middle where a fastener like the door ones go in then the other side of the door like fastener to the plastic panel?....yes i dont have any of the pieces...cept on the doors
Old Dec 8, 2002 | 09:16 AM
Car: 83 Camaro
Transmission: th350
ttt...
Old Dec 8, 2002 | 09:36 AM
devianb's Avatar
How do you get that filler window glass channel off of the top of the door panels?
Old Dec 8, 2002 | 12:32 PM
robs91conv's Avatar
There are 13 platic screws that hold the interior door panel on. I will attach a pic of one. The top black piece also has screws built in it for holding the interioir door panel on. To take off the top black piece you have to let down your windowand pick the black piece out and then up.
Old Dec 8, 2002 | 12:35 PM
robs91conv's Avatar
forgot pic
Old Dec 8, 2002 | 12:37 PM
robs91conv's Avatar
here is pic to show location
Old Dec 8, 2002 | 12:57 PM
devianb's Avatar
Is that out from the passenger side or the driver side?
Old Dec 8, 2002 | 05:54 PM
robs91conv's Avatar
passenger side. I haven't done drivers side yet. If you need pics I can get them tomorrow.
Old Dec 8, 2002 | 09:58 PM
devianb's Avatar
Pics would greatly help me out. Do I need a special tool to remove the filler channel. I tried removing it by hand, but it didn't seem to budge.
Old Dec 9, 2002 | 04:39 AM
OnFiRe705's Avatar
all you need is to get a flat blade screw driver and pop em out. They do make a tool that has a triangle on the end of it, but it does the same as the screw driver.
OnFiRe705
Old Dec 10, 2002 | 05:50 PM
robs91conv's Avatar
BennyBoopy,
I just received some different interior door panels and they came with plastic fastners. If you want I can send you my old ones
Old Dec 10, 2002 | 08:15 PM
Car: 83 Camaro
Transmission: th350
naww....i figured out what i need...i saw them on ebay....im gonna call some junkyards around here and if that fils ill call hawks or thirdgenresource...they are like plastic screws about the size of the door panel fasteners...and sxcrew into squre plastic pieces
Old Dec 10, 2002 | 09:40 PM
JPrevost's Avatar
Car: 91 Red Sled
OnFiRe705
It's called scissors. You can get the blades right up next to em and pop em out. Simple stuff. The top trim piece on the other hand is junk. I've broken mine and had to do some plastic welding just to keep it from falling off. Now the passengers side is squeeking so it's either the same thing or I just use some black machine screws
Old Dec 10, 2002 | 11:28 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
The top of the door panel is held on with twist on fasteners. After removing the entire door panel, lay the panel flat on the ground, and use small pliers or needle nose pliers to slowly unsrew the caps from the plastic stems. After removing them all, you can replace the top piece with new ones and reverse the process. Take your time though as the plastic stems can easily break or strip. Don't overtighten the metal twist caps.
Hotrodboba400
Dec 10, 2019 07:07 PM
tglennon11
Sep 23, 2015 05:30 PM
Stryker412
Sep 7, 2015 09:11 AM
mrdevontay
Sep 2, 2015 08:04 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
