Those who have done the 4th gen dash. ???'s about Guages??????
Car: An '87 Italian Retard Out Cruisin'
Engine: LS1 install in progress
Transmission: 4L60e
Axle/Gears: 9 bolt
I have a 155mph guage cluster from a 2000 Firebird. If anyone has done one of these, will I run into a problem with any of the guages or odometer working??
of course you will.........
it isn't a direct bolt up by any means...that is unless you were transplanting the proper engine, computer, harness, sensors, etc.
are you just installing the dash? there are ways to make the guages work properly with stock equipment.
try searching though as youll find your answers quicker.
do you have the dash itself in?
Transmission: 4L60e
Axle/Gears: 9 bolt
I know Its not a direct bolt in. The dsh is not in yet, haven't gotten all the pieces I need yet. Also I know I am going to need the plug for the back of the new guages.
My problem is that I haven't found any posts here on this site about people installing the 99-2002 Firebird guage cluster which I think are considered digital. I was reading some fourth gen sites and they (the 93-98 firebirds) were even having problems swaping in the newer style guages. I think their problems were with the tach and odometer working properly. Any one have info on that? Thanks.
the problem you run into is that those who have done this don't seem to like to share....
so either a. they are lying or b. they are complete jerks.
try bugging the hell out of fatal88, her husband seems to have done the conversion quite nicely.
i wouldn't mind doing it myself if i know that it could be done and look right; i wouldn't trust myself to fabricate something like that though. what a mess that would be to start and have to go back.
good luck!!
good luck!!
Car: 1985 Trans Am
Engine: upgrading...
Transmission: upgrading...
I dont know if fatal88 would be a good one to ask...
Originally posted by Fatal88
Let me say this again..... EVERYTHING in the car works because everything is 4th gen to 4th gen. Nothing mechanical or electrical is 3rd gen anymore.
Well Fatal88 used Camaro dashboards and Camaro clusters on both version of his 4th gen interiors (pre and post 98), so if there is something Firebird specific then he probably didnt have to deal with it. To be honest I wasnt aware there was a difference between pre and post 98 firebird clusters. My cluster is a 155 from a 2000 T/A as well so now I am curious about this. I'll do some searching.
Transmission: 4L60e
Axle/Gears: 9 bolt
Originally posted by BeNnYBooPy
i think dakota digital makes mechanical/electric changeover "black boxes"
Now for some reason I was thinking my 87 Iroc had a electronic but after rereading again it seems I have a mechanical speedo, Correct? So now I will need the Dakota box or swap to the electronic speedo crap(vss and yellow box) from a thirdgen?
Also after doing some more research over at camaroz28.com it seems that the
Ghettobird52
Jul 5, 2024 11:18 PM
