low beam headlights
Old Dec 27, 2002 | 02:25 PM
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
low beam headlights
Someone please tell me that I don't have to take the nose piece off in order to replace the low beams on my IROC. I took a quick glance at it before I went to work today, and it looks like the nose is in front of the screws for it. I am sure that once I get off, I will find that I am wrong... but please someone save me the time and tell me that I am.
Old Dec 27, 2002 | 04:38 PM
GKK's Avatar
GKK
Car: 91 Camaro RS Update: Sold Camaro, now own a "91" Corvette.
Engine: Corvette L98 TPI
You'll have to push the headlight plastic down slightly to access the lower headlight screws. I also taped the lower screws to the screwdriver when reattaching the headlight so they wouldn't fall behind the facia.
Old Dec 27, 2002 | 05:10 PM
360Iroc's Avatar
just so you know you dont need to remove all the screws to pull out the light i only take out the top two and slide the light out
Old Dec 27, 2002 | 09:41 PM
bradkeith's Avatar
Just to warn you, those bottom headlight screws are normally very stubborn. They strip easily.
Old Dec 27, 2002 | 10:24 PM
Thundering Z03's Avatar
Car: 92 Camaro Heritage
Engine: 305 TBI
KDogg is right. No need to take the lower screws out. Just a plain pain in the @!#. Just take the two top ones out, pull it back from the top and out with the light.
Old Dec 28, 2002 | 02:46 PM
Car: 1987 IROC Z
sweet.. will do that today then, thanks.
Old Dec 29, 2002 | 02:31 PM
Tremo's Avatar
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
Ditto. All you need do is loosen the lower screws, don't back them out all the way. Completely remove the top screws. I hit the screws with a quick shot of WD40 and let them soak for about a minute before I try to loosen them. It's a bit of a pain in the ***, but it works and you can swap lamps.
Speaking of lamps, has anyone tried those golden colored bulbs like they sell at www.autooptiks.com in their fog lamps? I'm thinking of trying a pair to help during wet weather.
Old Dec 30, 2002 | 08:31 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
i have never once even loosened the lower screws, just undscrew the top ones, and the headlight will come out.
Old Jan 1, 2003 | 11:46 PM
HybridZ28's Avatar
ditto
Old Jan 2, 2003 | 09:29 AM
CaysE's Avatar
Just a note, if you do need to loosen the lower screws, put a cloth between the screwdriver and the plastic so you don't scratch off your paint.
db057
Apr 28, 2019 07:45 AM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
adelane
Sep 9, 2015 08:51 PM
sylentnite
Sep 9, 2015 02:55 PM
luvofjah
Sep 3, 2015 07:08 PM
