Hood won't open - HELP!!!
Old Dec 28, 2002 | 12:45 PM
colonboy14's Avatar
Car: Trans Am
When I pull the hood release, it just pops up maybe .5 centimeters. The release handle is loose like when it is fully open, but the hood is barely popped up. You can't pull it open, and you have to push it back down for it to latch again. What is going on?
Old Dec 28, 2002 | 12:59 PM
MdFormula350's Avatar
well to get it open, i had to get under the car and release it from there. after that i extended the spring on the hood a bit longer. then i adjusted the rubber screws things that you can adjust on each side on the body.. another good adjustment is the locking mechanisn that hooks on the body with two bolts.
i finally got the my hood to work right, i dont know why it all of a sudden it did that but after adjustment i am not having any problems..
good luck
Old Dec 28, 2002 | 01:06 PM
colonboy14's Avatar
Car: Trans Am
how did you release it from under the car?
Old Dec 28, 2002 | 01:07 PM
tyty49's Avatar
Car: 91 Maro & 97 Ram & 05 Roadstar
Mine is donin the same thing I'm gonna adjust the little black bar on the hood that it latches onto and grease the latch!
Old Dec 28, 2002 | 01:16 PM
colonboy14's Avatar
Car: Trans Am
I will grease it and adjust it, but I need to open it first!!
Old Dec 28, 2002 | 01:26 PM
tyty49's Avatar
My bad I didn't relize that you didn't have it open, When mine wouldn't open it would just click I'd push down on the hood hard again and pull the lever it will almost always open the 2nd time.
Old Dec 28, 2002 | 01:48 PM
colonboy14's Avatar
Car: Trans Am
IT'S OPEN!!!!!!!!!!!
I had to perform surgery with a skewer from the kitchen, but I got it open!!
I'll never close it again.
Old Dec 28, 2002 | 06:12 PM
uk89camaro's Avatar
Happens on mine occasionally.
I have to call one of my boys to hold the pull handle out, whilst I give the front of the hood a couple of sharp pushes down.
Old Dec 28, 2002 | 07:50 PM
EvilCartman's Avatar
Car: '82 Z28
Mine sticks sometimes, I just open the driver door and close it again and the hood usually pops up lol
Old Dec 28, 2002 | 09:54 PM
91Zman's Avatar
Car: 1991 Z28
Transmission: 4L60 automatic
my brother's '84T/A does that,he just beats on the hood near the front in the middle and the hood pops open more,then he can open it.
Old Dec 28, 2002 | 10:56 PM
Thundering Z03's Avatar
Car: 92 Camaro Heritage
Engine: 305 TBI
LOL As goofy as it may sound. It works for me as well.
Old Dec 29, 2002 | 03:51 AM
biff85ta's Avatar
Car: 04 Vette
My TA does the exact same thing weird isn`t it.
Old Dec 29, 2002 | 12:45 PM
tbfirebird's Avatar
Car: Black 89 Formula
Engine: ??????????
Transmission: ??????????
so does my 89 firebird sometimes i have to push down at the front tip of the hood then it pops up.
Old Dec 29, 2002 | 05:53 PM
meridius's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7 TPI (Now HSR)
Transmission: 700R4 by Probuilt
Axle/Gears: 3:27 9 Bolt Posi W/ Discs
for the problem with the hoods that are sticking they need lubed. spray the latch with some kind of degreaser to get all the dirt out and then give it a bath in a lube like WD40 or something like that. Mine did the exact same ting and it was embarassing when I wanted to show people my engine and the damn hood wouldnt open and then I had to beat on it then it would pop up. I did that to my car and it works like a champ now. Next problem is to get the damn thing to open evenly, one side likes to go up faster than the other.
Old Dec 29, 2002 | 06:41 PM
rscamaro305's Avatar
when i pull the hood release nothing happens then i pull up on the hood and it opens. I then procede to adjust and lube all moving parts. Then it works properly for about 2 days. Then the cycle repeats. I love working on cars. Rock on!
Old Dec 29, 2002 | 07:35 PM
tbfirebird's Avatar
Engine: ??????????
yeah that happens to me it opens now when i pull the release,but when i litf the hood the right side always stays down more.
Old Dec 29, 2002 | 07:48 PM
swerve-driver's Avatar
From: "When the going gets weird, the weird turn pro." -RIPHST
Car: 1991 RS
Engine: 383TBI Fastburns and 2"TB
Transmission: T56 held up by Spohnstuff
Hood-
I was having this problem with my 91 RS.
WD-40 bath (on all the hood latch and release cable) took care of the problem.
Though, I also replaced my gas-charged hood shocks at the same time, so that may have a something to do with it.
To Success-
Old Dec 29, 2002 | 07:51 PM
tbfirebird's Avatar
Engine: ??????????
I also replaced them at the same time the shocks but it still does that.
Old Dec 29, 2002 | 09:14 PM
K-DOG's Avatar
These darn hoods
I had this problem, not anymore. I use WD-40 periodically on both the main latch and the "dumbass" catch latch. Ya-know the extra latch for those of us who leave tools under the hood and the hood doesn't catch the main latch. The main thing that I found that helps "pop" the hood is the spring on the hood next to the dumbass latch. The spring after some time might get crushed down so I just pull the end of it and stretch it out so you get more "pop." I do all this once in a while after working under the hood and I dont have any problem anymore.
Old Dec 29, 2002 | 09:35 PM
biff85ta's Avatar
Car: 04 Vette
I use a spray lithium grease on my hood latch it seems to work much better than wd40 and sticks around a lot longer also works great on door hinges and latches
Old Dec 30, 2002 | 01:42 AM
89V6FBIRD's Avatar
Car: 1999 Pontiac Trans Am
Engine: LS1 - 346 ci
I third that, it must be a thing w/ the Firebird hoods. I hit it on the bird decal on the front clip.
Frozer!!!
Jan 19, 2024 04:55 PM
AussiePr0nCar
Mar 6, 2020 04:04 PM
Street Lethal
Apr 30, 2019 12:14 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
