B&M Shifter, dont think this has been asked!
Old Jan 1, 2003 | 04:36 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
Is the B&M Mega shifter, once installed taller that the stock shifter or lower? I looked thru some pictures but cant really tell, not the right angle.
Let me know guys...
thanks
Old Jan 1, 2003 | 06:18 PM
ThunderBird's Avatar
it should be a little shorter, so you can shift faster..
Old Jan 1, 2003 | 06:25 PM
V6camaroman's Avatar
i just got a hurst v-matic 2 shifter for my bird. when i found it in the junk yard it was in a maro. my hurst shifter is like 3" taller than my stock shifter.
Old Jan 1, 2003 | 06:26 PM
should be? Do you not have one?
Man I hope its not taller!
Old Jan 1, 2003 | 06:40 PM
my hurst v-matic 2 shifter is taller than my stock one actually by like 3" mi not sure about the B&M mega shifter though
Old Jan 1, 2003 | 07:03 PM
3".....thats alot! Anyone with a mega shifter?
Old Jan 1, 2003 | 07:47 PM
@ZZKKER's Avatar
Car: 86 iroc, 87 iroc, 89 iroc, 89 formula, 84 supra, 85 trans am
Engine: t\a motor 355 lt1 intake, t56,the works, 89 roc 427 sbc tt project
Transmission: to many to list
Axle/Gears: 9bolt 4:10 in the T/A
if so not by much. the handle on the other hand is huge.
thanks
anthony
Old Jan 1, 2003 | 07:52 PM
thanks
anthony
Ah! which are you refering to?
Who has a B&M Mega Shifter that can answer the question?
Is it taller or shorter than a stock shifter?
thanks
Old Jan 1, 2003 | 08:43 PM
harvtherabbit's Avatar
just a bit taller not too much once you get usta it youll never know the difference
Old Jan 1, 2003 | 08:59 PM
@ZZKKER's Avatar
the b &m . here is a pic of a stock maro shifter. keep in mind that the stock firebird shifter is a little shorter.
Attached Thumbnails B&M Shifter, dont think this has been asked!-cluster1.jpg
Old Jan 1, 2003 | 09:02 PM
@ZZKKER's Avatar
then here is the pic of a b & m in a ta, but since it has no consle, you have to judge by the steering wheel, and the hvac control.
the mega shifter is taller then the stock ta shifter, but aboutthe same size as the maro.
hope this helps.
thanks
anthony
Attached Thumbnails B&M Shifter, dont think this has been asked!-megashifter.jpg
Old Jan 1, 2003 | 09:49 PM
badandy247's Avatar
Car: 91 Camaro RS
Engine: 3.1L V-6
Transmission: Fresh 700R4
the B&M is allright bout the same as a auto camaro shifter but the shift boot is ugly go with the hurst dual-gate looks great performs great and is shorter than stock camaro, and the chrome!
Old Jan 2, 2003 | 11:21 AM
Jza's Avatar
Jza
It's a tad bit taller, but the throw is very short.. About an inch in either direction to ratchet, and only about 3 inches from park to drive. A lot shorter throw than the stock shifter.
Hotrodboba400
Dec 10, 2019 07:07 PM
Whata69
Mar 2, 2016 06:34 AM
BlackFormula
South East Region
Sep 8, 2015 09:59 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
tonys91rs
Sep 2, 2015 07:07 PM
