How do I remove the shifter handle?
Old Feb 11, 2003 | 06:05 PM
92GTA's Avatar
I just received a complete NOS auto shifter plate that I bought. It looks great! Anyway, how do I remove the shifter handle? I know there is a little plastic button type thing on the front of it where you can't see but I'm afraid of pushing it too hard and it breaking or something, should I just go for it or what?
Old Feb 11, 2003 | 06:25 PM
Eric's85TA's Avatar
Car: 1985 Trans Am
Engine: 400
Axle/Gears: 3.70
I'm not sure what little hidden plastic button you're referring to, but my car is an auto with the shifter handle with a button coming out the side toward the driver that you have to push to put it in gear. If you have the same kind of shifter, it's really easy to remove. You can feel (and see it if you move the shifter back to first) a little metal "U" shaped staple right under the handle handle part of the **** on the front of the shifter. It holds the **** onto the shaft. Just grab that metal staple in the middle with a needle nose plier and pull it straight out (toward the radio). After this is removed, the shift **** will pull straight up and off of the shifter.
Eric
Old Feb 11, 2003 | 06:28 PM
92GTA's Avatar
Thanks! That's the piece I was talking about, I thought it was plastic
Thanks!
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Fronzizzle
Sep 8, 2015 12:10 PM
scottmoyer
Sep 7, 2015 07:06 PM
