Convertable top question
Old Mar 14, 2003 | 07:38 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
How many people have a power button to pop the touno cover?
Or do you have to use the 2 pull cords behind the back seats?
on another board someone pointed out to me his was power.
Old Mar 14, 2003 | 11:43 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Both. The manual releases are for emergency use in case the tonneau hatch release fails to function.
Lon
Old Mar 15, 2003 | 07:01 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Lon
Mmm, Did all verts have the electric pop? This is a 91 RS.
I know in my 92Z the button in the middle of the power windows is for the Hatch relese...
In the 91 vert that button is missing... Would that be the touno or trunk?
Old Mar 15, 2003 | 08:08 AM
patrickm00's Avatar
the power release for the tonneau cover is in the back seat by the release handle for the top.
Old Mar 15, 2003 | 09:08 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
This is the lever you pointed at right?
This is not electric on mine. All it does is pulls a cable to release the latch in the top by the rear window.
Old Mar 15, 2003 | 09:10 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
I just noticed you have a pontiac.. You are the 2nd Person to say you have a power button.
Old Mar 15, 2003 | 09:41 AM
lonsal's Avatar
The electric tonneau release for convertibles (note the spelling, "i" not "a") moved to the position Patrick shows in 1992. Previously the switch was located between the window switches, where the hatch release switch is located on coupes. The new switch location makes a lot more sense. It eliminated the "duck in to pop the switch" step.
Lon
Old Mar 15, 2003 | 09:52 AM
patrickm00's Avatar
i still find it unbelieveable that the dealer charges $95 for the cable release though. and especially for how cheaply built that handle is. i mean, what engineer in their right mind would put a long thin rod on the edge of a 1" square handle, then have the rod braced internally but not the connection to the handle?
mine snapped last year, so i backfilled it with epoxy and put a screw through it going into the rod. just thought i'd pass that along to other conv owners, or maybe someone that might help "rebuild" them better than stock for other people....
i'll take pictures when i get time if this description is too confusing
Old Mar 15, 2003 | 09:54 AM
patrickm00's Avatar
if i'm not mistaken, the power release was standard on 91-92 trans ams, if not all firebirds.
Old Mar 15, 2003 | 09:59 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
The electric tonneau release for convertibles (note the spelling, "i" not "a") moved to the position Patrick shows in 1992. Previously the switch was located between the window switches, where the hatch release switch is located on coupes. The new lake switch makes a lot more sense. It eliminated the "duck in to pop the switch" step.
Lon
Makes sence having the tonneau switch between the windows I guess, but that means no power trunk release.
Mmm time to make a remote switch so when I pop the top the tonno pops to.. should be easy with a little wire and a wot nitrous switch....
Old Mar 15, 2003 | 10:03 AM
patrickm00's Avatar
question for you though. i've never had time to properly diagnose this problem, but the electric switch will not throw when the headlights or fog lights are on. is this normal, some kind of 'safety' feature, or just something screwed up? (the guy who owned this before me was a total slob, so i wouldn't be surprised)
Old Mar 15, 2003 | 10:17 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
im making billet alum handles..... will have pics soon. if intrested, email me at MrDude_1@excite.com
Old Mar 15, 2003 | 10:30 AM
lonsal's Avatar
Something is screwed up. There are safety features to the tonneau release to prevent it from being deployed while driving. If the ignition is on the tonneau won't release unless the shift selector is in P or N (auto tranny) or the parking brake applied (manual tranny).
Lon
Old Mar 15, 2003 | 11:17 AM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
I have a power release switch!
Old Mar 17, 2003 | 04:17 PM
patrickm00's Avatar
Lon
then maybe something's just wired wrong in mine. i can pop it in any gear without the e-brake on, but not with the lights on.
Old Mar 18, 2003 | 12:53 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
over the weekend, i went and traced down why my power releases didnt work. turns out the power wire was shorted to ground under the carpet.
i wired up a new circuit for it (fuse, relay switch) and setup the switch(push button actually) next to the handle you pull to release the top.... its the best vert specific mod ive done so far..
now to lower the top, you roll down the windows, undo the latches, step out of the car, reach in, pull handle,lift rear of roof, push button, cover pops up, lower and fold the top, and click the cover down...
sounds like alot when you read it, but its soo much better then having to reach in and hit the switch in the center, and its worlds better then pulling the little cords.
anyhoo, just thought id pass the idea along.... move the release button to the cover itself... :lala:
oh, and im going to put a trunk release switch were the orignal cover release switch was...
Old Mar 18, 2003 | 06:42 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Travis,
better yet why not do like Im in the process of. when you Pull the lever to pop the top why not just have that hit a micro switch like a nitrous WOT one and pop the solinoids for the tono also.
Old Mar 18, 2003 | 07:08 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Originally posted by TPl383
Travis,
because i dont need to pull the handle to just lift the cover then... :lala:
if i truly wanted to be slick, i would shave the whole handle off, put one button there and have a 'noid pop the top off, have the top be spring loaded to lift up, and have the cover lift up under the top...
then its only one button...
but really, im happy with it like it is...
:lala:
Old Mar 18, 2003 | 07:42 PM
patrickm00's Avatar
you could still push the switch with your hand nonetheless...
but i don't see how that's any slicker than the '92 factory way, because you still have to reach out and pull the top up before you lift the cover.
Old Mar 18, 2003 | 08:37 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
i dont know the 92 factory way.
matter of fact, if what im assuming is correct, i modded my 91 to work the 92 factory way.
all i did was move the power top release button from the center of the console, to the edge of the top by the handle.
that means that once i step out of the car to pull the handle and release the top, i dont have to duck back into the car to release the cover...
matter of fact, it started to rain at a redlight today and i put the top up in what had to be under 5 secs....... much qucker then the factory 91 way..:lala:
1992 Trans Am
May 10, 2023 07:19 PM
69 Six Pack
Oct 5, 2015 07:51 PM
redmaroz
Aug 16, 2015 11:40 PM
Dan Hubbard
Aug 12, 2015 09:05 PM
