Bombs Over Baghdad
Old Mar 23, 2003 | 10:51 PM
firebird2003's Avatar
Bombs Over Baghdad
Ok here is the deal. The hood of my bird looks like it got it by Patriot missiles like baghdad did the other night..The paint is just chipping every damn where. I take it to the car wash it just comes off. Well, here is what i thought i was gonna try to do. Buy some rattle can paint, sand the chipping spots with 400 grit to smooth the primer. Mask off the chipping areas and painting the base coat and then the clear coat. Well, the first spot I tried didnt turn out to bad the color was kinda dull but it looked decent. Well, i was sanding the other spots and the primer came off really easy and sanded down all the way to the metal (at this point im feeling pretty dumb, lol) I am no painter, No painting experience. The rest of the car is fine its just the damn hood and i cant afford to take it anywhere at this time. Are there any paint and body ppl out there that can tell me what supplies i can use and where to get some paint...cause i have a spray gun, screw the rattle can. I think im just gonna take the hood off the car and paint it. I prob should have just sanded it all back down to the original primer but the primer seems to come off to easy..either im using the wrong grit or sanding to hard..I tried another spot with another primer where i had sanded it back down to the metal. Well when i went to put the color paint on...It turned out to be a much brighter color than the other spot I had done..I was just seeking some help and was wondering if someone would give me some heads up!! Would be appreciated.
Old Mar 24, 2003 | 01:17 AM
Diabolical's Avatar
Car: 85 Trans Am WS6
Engine: 305HO L69
i'm no body expert, but i would say to just strip the hood and repaint the whole thing. if it's peeling like that, something is wrong with the paint job, and until you do it the right way, it's bound to do it again. i say do it right once, and never have to worry about it again.
Old Mar 24, 2003 | 01:35 AM
RSFreak's Avatar
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
Re: Bombs Over Baghdad
Originally posted by firebird2003
... hit by Patriot missiles like baghdad did the other night...
The Patriot is a surface-to-air anti-missile missile. Baghdad was hit by Tomahawk cruise missiles, not Patriots.
Old Mar 24, 2003 | 08:21 AM
FyreLance's Avatar
Car: 00 TA, 91 Formula, 89 RS
Unimportant, they're still getting their butt kicked. ;-)
Old Mar 24, 2003 | 10:27 AM
camaro6spd's Avatar
Is this your daily Driver, is so there is no need to go and get super expensive paint on you car.....this is what i am using. And the total cost is gonna be like nothing....
Etch-$29.66(1 qt activator, 1 qt etch)
Primer Surfacer-$22.98 (1 qt primer, 8oz activator)
Base-$68.00 (1 Gal of white, but you get 2 gals out of it, i am sure you can order only a qt if you call)
Clear-$21.60 (1 qt clear, 8oz activator)
reducer-$30.60 a gal.
http://www.autobodysupply.net/iciautocolor/valupro.htm
Old Mar 24, 2003 | 12:46 PM
I just need enough to paint the hood...u find the color code of the RPO codes, right? mine should be 37U
Old Mar 24, 2003 | 09:06 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
Sweet another Arkansas member, where ya at?
Dont worry with the first time at painting, just practice on something first before you shoot your hood. Look at my car, that was my first time ever painting a car. It came out really well for a first timer.
Old Mar 25, 2003 | 06:55 AM
Im in Camden....I have never heard of cove b4, lol....must be up in northern ark...well nice to have somewhere in here from ark.....I think ill just call around body shops and see how much they would charge to repaint my hood
Reddeath210
Oct 6, 2015 08:20 AM
AlienCatz
Feb 19, 2002 12:51 PM
ChevyGuy87
May 8, 2001 02:37 PM
GTA88
Jan 12, 2001 10:53 PM
88FormulaWS6
Aug 1, 2000 03:38 PM
