82-84 vs. 85-90 TA fender?
Old Mar 25, 2003 | 01:17 PM
HotRod's Avatar
Car: 87 GTA
Engine: Eaton Supercharged 350 TPI
Hey everybody,
I had a wheel fly off the front of my 87TA yesterday and crunch the front drivers fender and door with it (guy before me pressed standard thread studs in the rotors and I didn't know ). Anyway, I know the 85-90 fenders are differant from the 82-84s but I found an 84 for cheap. Do I just have to drill different holes for the gfx or is the shape of the fender actually different? Thanks for your help, searching gave me to much crap on this topic,
Tyler
Old Mar 25, 2003 | 02:24 PM
300hpse's Avatar
Car: 1990 Trans Am
Engine: Lb9
Transmission: factory T5
Axle/Gears: 3.08 limited slip
i just know the vent is larger on the 82-84 and the bottom of it would be covered by the gfx off a 85-90
Old Mar 26, 2003 | 04:33 PM
redraif's Avatar
Car: 87 Red/Blk Bird loaded 3.4L & 700R4
Transmission: Th700R4
Same fender all years... the "fender vents" are different in 85-90. Only TAs came with the fender vents in 85-90. But in 82-84 I think they all came with the vents and the vents were larger. Fender is no different though. The GFx holes in the 82-84 will be different from the 85-90.
Does your car have a fender vent?
Old Mar 26, 2003 | 05:10 PM
kanuck's Avatar
Car: 1982 Trans Am
Engine: 350 Crate
Transmission: TH350
Fender shape is identical all years for Firebirds. (I assume Camaro fenders are the same for all years too, but not sure)
82-84 T/A's had the large fender vents, 82-92 Firebirds, Firebird S/E's, Formulas had no vents at all. 85-90 T/A's had the smaller vents. 91-92 T/A's had no vents either I think.
Old Mar 26, 2003 | 06:13 PM
HotRod's Avatar
Car: 87 GTA
My car is actually an 87 GTA but after a colision the fenders were replaced with 85-90 TA fenders with vents. Does anyone know how much bigger the old vents are? I am wondering if anyone would notice if I ran the old style on one side and the new style on the other or will the ground effects cover most of it? Bottom line.......looks like if I redrill the fender for my gfx and run the larger vent I could use the older fender??? Thanks and please let me know if I am missing something,
Tyler
Old Mar 27, 2003 | 08:35 AM
300hpse's Avatar
Car: 1990 Trans Am
Engine: Lb9
i think it would be noticable, ill measure mine and let you know
Old Mar 27, 2003 | 08:53 AM
redraif's Avatar
Yes you can use the older fender and only need to redrill. That is if the 84 fender has the fender vent. You can swap your current fender vent into this new fender! If you old fender vent is crunched, you can probaly find some of the later style at a yard. heck they might swap you for the older style vent since it is more rare...But will it be noticible, a little. It would be something you could probably live with for a bit and then swap out when you find one.
Old Mar 27, 2003 | 10:25 AM
GarageToys's Avatar
Car: 89 Iroc Hardtop
Engine: LB9 w/G92 Pkg
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt, 3.45
Originally posted by redraif
...Only TAs came with the fender vents in 85-90. But in 82-84 I think they all came with the vents...
No, standard Firebirds in 82-84 did not have fender vents. At least mine doesn't and none I've ever seen has had them.
Old Mar 27, 2003 | 10:51 AM
LT1guy's Avatar
Car: 1987 Trans Am
The vent on the 85-90 fender is shorter so that it will not be obscured by the ground effect; the hole is the same though, so you can use your shorter vent in the early fender. Just drill holes to match the 85-up fender and you're set.
Old Mar 27, 2003 | 12:34 PM
slickrock55's Avatar
Car: 82 Trans am
Engine: Twin turbo 350
so . . . the 85-90 vent is a different size (shorter) than the 82-84, yet they fit into the same hole??
im putting 85-90 gfx on an 82 trans am, and i need to get this straight before i do.
Old Mar 27, 2003 | 12:39 PM
kanuck's Avatar
Car: 1982 Trans Am
Engine: 350 Crate
Transmission: TH350
That's great news if you're restoring an 82-84 T/A! You can just use an 85-90 T/A fender, remove the GFX and patch the bottom, and use an old fender vent!
Old Mar 28, 2003 | 12:31 PM
redraif's Avatar
Yes that is correct!
The actually difference is the hole in the actual vent. The "vent" is shorter since the gfx are longer & cover part of the vent... the piece that goes in the fender is the same size.
Old Mar 30, 2003 | 12:52 AM
Car: 82 Trans am
A HA! it is all so clear to me now. . . . thanks for clearing that up redraif, ground effects plans will now continue as planned
by the way, i have been looking for an unmolested, good shape (paint not included) front bumper cover, 85-90 trans am style. im looking for no rips or tears, and no license plate mounting holes. . .anyone have one they are looking to get rid of?
Old Apr 1, 2003 | 03:28 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I am running the 82-84 Vents on my 86 since I am running the 91-92 Camaro rocker panels. The 85-90 vents looked funny, when I found out that there were 2 different styles.
Old Apr 4, 2003 | 10:18 PM
Car: 82 Trans am
can anyone post a pic of the 85-90 shorter vents closeup, just to see how much is covered?
Old Apr 5, 2003 | 02:53 AM
Zepher's Avatar
Here are mine,
Old Apr 5, 2003 | 11:37 AM
HotRod's Avatar
Car: 87 GTA
Now can someone post a pic of the other vent for so that we can reference them off of each other? Thanks,
Old Apr 5, 2003 | 02:54 PM
Zepher's Avatar
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
KNIGHTE
Southern California Area
Oct 22, 2015 09:11 PM
jovibuilt
Oct 18, 2015 08:12 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
IROCZDAVE (88-L98)
Sep 22, 2015 02:22 PM
