'Vert rear wheel wells.
Old Apr 11, 2003 | 10:27 AM
Dan88IrocZ's Avatar
Dammit! One side of my trunk ALWAYS got plastered in dirt, dust...everything. I couldn't ever figure out why...
Today I took my rear wheels off, masked everthing off and sprayed the wheel wells, when I realized there is about a 4 inch gash in the wheel well!! I've never seen replacements available on the net...so what can I do? I have a huge tub of Bondo in the garage
Any ideas????
Old Apr 11, 2003 | 12:04 PM
91DropTopTA's Avatar
Car: 91 Trans Am Convertible
Engine: 300 HP 350 CI
Axle/Gears: Drums?
If the actual metal is got a hole in it, you may be able to either
A. Use a hammer and dolly and return it as close to possible to the original shape. Then have it welded closed and paint it.
B. Have a small sheet metal patch panel made and welded over the hole. Then, finish with some body filler and paint.
That's what I would probably have done. If you use only body filler, it will more than likely crack and you will definately have rust form underneath.
Old Apr 11, 2003 | 12:06 PM
Dan88IrocZ's Avatar
It's actually the plastic inside the wheel well....
I was thinking, maybe I could take it down the street from me and have it sprayed with that heavy duty truck liner to fill in the hole?
Old Apr 11, 2003 | 02:19 PM
Midnight Sun's Avatar
Car: 1983 Trans Am
Engine: N/A
Transmission: N/A
if it is only that plastic deflector inside of the wheel well. I am 75% positive Hawks sells them used for like 10 bucks.
Old Apr 11, 2003 | 03:00 PM
Dan88IrocZ's Avatar
It doesn't resemble the deflector that you see in the front wells.
It's like a thick thick material...but I'm going to give bondo a try tonight. If that doesn't hold up, I'll go have it sprayed with that truck liner stuff!
Old Apr 12, 2003 | 10:07 PM
drain89's Avatar
Car: 02 WS6 White/Ebony
Axle/Gears: Stock 3.42
You'll probably spend as much in bondo and truck bed liner as what it will cost you to buy a new piece at the dealer. Best of all a new one (or even an undamaged used one) is not gonna look like hammered **** on a white pickett fence like the monstrosity you're suggesting will. No offense. If you're gonna fix it, have some pride and fix it right man, especially when where dealing with a part that doesn't cost much.
Old Oct 24, 2007 | 05:32 PM
Jays92Camaro's Avatar
Car: 92 Camaro RS, 04 Dodge RAM
Engine: 305 TPI / Hemi 5.7L
Transmission: 5 speed / 4x4 auto
Re: 'Vert rear wheel wells.
Midnight Sun...you mentioned HAWKS as a source for the rear inner wheel well deflector/liner. I suspected these existed but were removed from my son's 92 RS before we got it. What's this HAWKS? please post a link or pm me. Thanks
Old Oct 24, 2007 | 07:25 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
brought back from the dead! hawks is http://www.hawksthirdgenparts.com/
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
B_Dubya
Aug 26, 2015 05:09 PM
kah992
Aug 19, 2015 02:55 PM
aaron7
Exterior Parts Wanted
Aug 18, 2015 05:47 PM
