Rethreading?
Old Apr 22, 2003 | 05:36 PM
89cmrodriver's Avatar
Car: 08 Sierra, 08 Silverado, 91 z28
Engine: 5.3, 4.3, 5.7
Transmission: autos
Rethreading?
ok, well people are always messin with my b&m shifter,which mind u is a POS i shoulda gotten a hurst, ok well now the threads are all striped except the top 3, how would i go about rethreading it, i dont think it would work because then the shift **** wont be threaded the same, or the nut to adjust the tightness....erg, im so mad, someone give me some ideas on fixing it before i get really mad and take it out of my car
Old Apr 23, 2003 | 02:58 PM
hotrod87camaro's Avatar
Car: 1987 Camaro Sport Coupe LT
Engine: 357
Transmission: turbo 350
Axle/Gears: 10 bolt posi, 3.73 gears
tap it, then use helicoil. or you can probably just buy a new **** somewhere.
Old Apr 23, 2003 | 03:15 PM
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
I have the same problem, my shifter know spins on its axis. Just go to checker, they sell new ones for under $20.
Old Apr 23, 2003 | 03:20 PM
Transmission: autos
my **** isnt stripped, my shifter is stripped, the part u screw the **** onto, i only wish it was just the ****
Old Apr 23, 2003 | 03:43 PM
tyty49's Avatar
Car: 91 Maro & 97 Ram & 05 Roadstar
just tap the threads to the threads on the shifter handle. And on you go
Old Apr 23, 2003 | 10:24 PM
Engine: 357
why do you need to choose a new avatar?
Old Apr 23, 2003 | 10:53 PM
5SIZ's Avatar
Car: 1987 IROC-Z
that IS an avataar.
Old Apr 23, 2003 | 11:20 PM
82camaro's Avatar
Car: 82 camaro SC
The problem with that is the threads are mostly gone, a thread tap won't add metal.
Chances are the shift handle is also stripped. Get a new handle. FYI, the hammer handle uses a steel insert threads(and is a much better handle IMO). Then screw it on the shift lever using plenty of HD locktite--you might even try leaving off the locking nut. It might be worth a try. You could, in the process ruin the Hammer handle though. If the shift lever must be replaced you can get a replacement. A quick trip to B&M's website, then to summitracing.com I came up with the part you need.
BMM-80695 Megashifter Short Stick Kit(2 in shorter Stick)
$39.95l
Old Apr 23, 2003 | 11:50 PM
ontogenesis's Avatar
Car: 1985 Camaro, 2015 Audi A4
Engine: V8
i absolutely despise b&m products, but my megashifter is a pretty well built product, it's the damn shift linkage and bracket and cable that i hate about it...
Old Apr 24, 2003 | 11:53 AM
Transmission: autos
i really didnt like my b&m its gave me alot of troubles, thanks 82camaro i needed that info, i guess ill buy the new short stick, wonder if its easier to shift with it being 2" shorter? i definally want a hammer shift ****, i saw yours and like the look of it, but my **** surpisingly isnt stripped, right now i have a thinner nut near the top and is working for now, thanks for the help guys
Old Apr 24, 2003 | 01:57 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
You could always drill a small hole in the front of the handle and then put a small screw or bolt in there and tighten it down so it rests firmly against the flat part on the shifter. I'm willing to bet that might work.
Old Apr 24, 2003 | 03:09 PM
Dan88IrocZ's Avatar
Lock tite.
Old Apr 24, 2003 | 03:15 PM
Engine: 383 SBC
Yeah, but lock tite isn't going to help after the threads are already stripped out.
Old Apr 24, 2003 | 03:39 PM
badandy247's Avatar
Car: 91 Camaro RS
Engine: 3.1L V-6
Transmission: Fresh 700R4
you could try the JB Weld trick before you go buying parts after all it's free or at most 5 dollars for the JB Weld
just clean the threads on the stick real good, apply jb weld to the threads, put a little light oil on the threads inside the **** put some JB down in there and thread them toghther leave them together for like 24-30 hours then unthread, you should have new threads that may last a while just don't put the **** back on for a day or two then loctite it on when all done
the secret to this trick is in the timing of the removal of the **** you don't want to let the JB harden too much or take it off too soon there is only like a 4-6 hour window of oppurtunity for it to work well
may wor may not
hope this helps
Andy
Old Apr 24, 2003 | 03:46 PM
Transmission: autos
humm, u have a very good idea, but i dont need to take the **** off anyway, so i could just us jb weld, or something not as "permenant" like contact cement to hold it on there, u really helped, thats what im gonna do
Old Apr 24, 2003 | 03:48 PM
badandy247's Avatar
Car: 91 Camaro RS
Engine: 3.1L V-6
yeah if you don't need it to come off just JB it and it'll stay purdy good
you could always break the **** loose later if need be
Old Apr 24, 2003 | 03:51 PM
Engine: 383 SBC
liquid metal would probably do the same too
Old Apr 24, 2003 | 05:05 PM
Transmission: autos
well i went and used the jb weld on it, i figure i can use a pipe wrench to get it off if i ever need to, the stuff also worked good on the 2 inch long air leaki had around my blower motor high air flow now
Old Apr 24, 2003 | 06:23 PM
badandy247's Avatar
Car: 91 Camaro RS
Engine: 3.1L V-6
well, JB is all that is holding my TV cable in place on my car as well as several other things
the best part of it is you can sand it and paint it and make it look like it's supposed to be there
Old Apr 24, 2003 | 07:09 PM
Car: 1987 IROC Z
yeah, i've busted it twice myself (the linkage cable)
Old Apr 24, 2003 | 07:36 PM
Transmission: autos
i feel dumb to ask this, but what is the shift linkage cable, isnt that the cable that goes from the shifter to the trans? and its red?
Old Apr 24, 2003 | 07:50 PM
badandy247's Avatar
Car: 91 Camaro RS
Engine: 3.1L V-6
usually red or black yeah i think you got the right one
Old Apr 27, 2003 | 09:11 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
If the handle is steel (i'm assuming it is, but i dunno for sure) try to get your hands on a welder. You can add a metal bead to the inside on the threaded hole, which WILL add metal for you to re-tap.
Flightoficarus
Brakes
Dec 11, 2011 11:29 AM
fychelio
Feb 15, 2008 07:44 AM
JRoy91RS
Apr 16, 2006 12:55 PM
84 t/a 5.0
Carburetors
Jul 30, 2004 06:48 PM
PioneerCrazed
Oct 4, 2003 01:09 PM
