AfterMarket Seatbelts?
Old May 2, 2003 | 04:24 PM
Drunken_Polak's Avatar
I just broke my seatbelt buckle....and wanted to get some 3 or 4 point seatbelts. Ive been told that i cant put 3 or 4 point seatbelts in my car because it wont work for some reason. Can anybody say differently...im sure ive seen some other seatbelts around in the 3rd Gen's....maybe u guys would like to tell me what kinda mod u did to make it work?
Old May 2, 2003 | 04:34 PM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
Yes you can use a 3 or 4 point harness system. I have seen pics of it on this board.
Old May 3, 2003 | 09:24 AM
CustomX's Avatar
Car: 90 irocz
Engine: 350tip
I have 5 spoint rci harnesses for both front seats, they work, but i dont suggest getting the 4 point.
the 4 pointsdont have anythign to anchor them on the bottom so the belt tends to pull up on you, so youll find the latch sittign in your stomach,w hich is a BIG BIG NO NO for safety reasons.
Not to mention that with harneses, not everyoen is comfortable in them, much harder to get in and with bolt ins, yoouve basically just killed any chance of ever using your back seats (ie no more seat belts back thier. Same goes with roll bar mounted ones. But hey, if you need 16.1 cert, 5 points be the way to go!
Old May 3, 2003 | 10:36 AM
Pics??
anybody got any pics of their seatbelts? I dunno which ones to get... but I wanted to see them in the cars...
Old May 3, 2003 | 12:05 PM
Superman's Avatar
Car: 1989 Camaro
Engine: 406
Transmission: Pro-built 700R4
Here are my Simpson 5 point harnesses.
Old May 3, 2003 | 08:49 PM
82firebird's Avatar
Car: 1982 Firebird
Engine: sbc 307
Transmission: 200
Superman, any pics of where you mounted the rear of the harness to the floor? Thanks.
Old May 4, 2003 | 09:19 AM
Electron_Blue's Avatar
Car: 83 Camaro
Transmission: th350
couldnt you but the 3 point like ones...where its 4 things by the driver but the over shoulder ones go into a y and then you could mount em where the old seat belt tops went
Old May 4, 2003 | 09:20 AM
Car: 83 Camaro
Transmission: th350
are there any street legal 3 or 4 or 5 points....id hate to get pulled over and get a big *** ticket for em
Old May 4, 2003 | 05:50 PM
Wootah's Avatar
Car: 88 Iroc-Z
Engine: 355ci
Transmission: WC-T5
Dood x point harnesses are better then stock harnesses.. i dont see ANY reason why a cop would say something about it, because instead of 2 straps you have 5.. theyd probably give you a thumbs up if they saw your car with them installed. just my .02
Old May 5, 2003 | 01:00 AM
any more pics ppl?
Old Jun 10, 2005 | 05:35 PM
theshmo891's Avatar
bump, i wanna know more, people who have them : are they too much of a hassle? i want to get a 4 point or somehting, but are they too much work, for like a girl thats sittin in the pass. seat? Do they take too much time to clip up? And also, are there ones where you can use like a reg belt sometimes? And someone said before that it makes your backseats a bitch to get into or w/e, so hmm....im a newb when it comes to belts ha
thanks
Old Jun 10, 2005 | 08:28 PM
phoenix305's Avatar
Car: 1987 IROC, 1989 IROC
Engine: built 305, stock 305 tpi
Transmission: Corvette 700r4, t-5
Axle/Gears: 4.10 posi, 3.08 posi
So with out a roll bar to mount them to you have to mount them to the floor? That sucks.
Old Jun 10, 2005 | 08:37 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The factory 3 point belts were designed, tested and installed by GM to meet defined crash safety standards. Any idiot can buy 5 point restraints off the shelf and install them in a way which is even more likely to cause injury in a crash than the stock belts.
Old Jun 10, 2005 | 10:27 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I can't even imagine what a cop would say if he saw that.
"Where you off to, speed racer?"
"Do you think this is a race track?"
etc.
Like Aperiron said, any idiot can toss a 5 point harness in. Not many do it right unfortuntely. And if you get in an accident odds are insurance won't cover injuries.
Old Jun 11, 2005 | 01:24 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
Yes, inproperly installing harness' is very ussafe. Anytime the the should mount location is further than 90* from the torsoe, you risk compression of the spin in an accident. The long the leads are, the less safe they are also, the harness material has a certain amount of flex designed into them, the longer the shoulder belts are, the more flex there is. There is a reason the NHRA, IHRA, NASA, SCCA, FIA, etc all have very strick rules about harness mounting, in both how and where the harness attaches.
Old Jun 11, 2005 | 06:50 PM
stalin05's Avatar
Car: 88 IROC-Z
Engine: 350+
Transmission: Wishin Manual
so a good idea would be to have someone who knows what there doing like a body shop or something?
Old Jun 11, 2005 | 07:18 PM
Dewey316's Avatar
Car: 1990 Camaro RS
unless you are doing a full roll caged car, and building it one of the sanctioning body's specs, i would do them at all.
Old Jun 11, 2005 | 08:23 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Chances are your average body shop isn't going to know jack about racing restraints, and wouldn't touch a liability issue like that with a ten foot pole anyway.
If you need the 5 points for racing, put them in (and do it properly). If it's a street driven car as well, leave the stock belts in, and use them instead when driving on the street. They're a whole lot more comfortable anyway.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
