Shift Lever Indicator
Old May 8, 2003 | 05:14 PM
The Beast's Avatar
Ok,
I've taken the plate off the center console of my 85 firebird. I'm looking for (if it even exsists) the "pointer" or ANY indicator that tells the driver what gear the car is in. I can see the white plastic channel that has the small light atached to the lower rear portion (so the PRND) is visible @ night. BUT there is nothing that is coming from the actual shift lever to point to or highlight what actual gear the vehicle is in! Any suggestions. Its an 85 standard with auto.
Old May 8, 2003 | 07:14 PM
ramair350's Avatar
The one in my 89 Formula is the same as your 85 I think but I have a buddy that has a 91 that has a shifter that has an indicator. His shift boot and everything is different so if you got the shift boot and inticator from a 91 or so that would give you what you need. Good luck!
Old May 8, 2003 | 07:24 PM
The Beast's Avatar
Thanks for the info.
It's not that big of a deal, but hard to believe that there is no type of indicator... I mean SH## Everything has an indicator
Old May 8, 2003 | 07:46 PM
ramair350's Avatar
Yeah I thought the same thing when I realized that my buddy's had an indicator and mine didn't! His is even a baseline model and mine is a Formula 350. It just boils down to the year. Sucks but true.
Old May 8, 2003 | 07:54 PM
The Beast's Avatar
Ditto on my 85.
I aquired it from a coworker a few years back. Its a base model 2.8 V-6 . Still hard to believe that there is no indicator...
Thanks again
Old May 8, 2003 | 09:55 PM
bubbakutz's Avatar
Car: 1987 "1991 Z" Sport Coupe
Engine: LG4
Transmission: TH700R4
ok....so what years auto camaro had a shift indicator?
Old May 8, 2003 | 10:04 PM
The Beast's Avatar
Old May 8, 2003 | 11:26 PM
ramair350's Avatar
Good question! I don't have an answer cause my 83 Z-28 was a manual. Sorry!
Old May 8, 2003 | 11:48 PM
87gtaowner's Avatar
why do u need to know what gear u in.. i rarely look down to see what im in, and i have only had my 87 gta 350 for a month or so... im also 16 and have yet to get my license... lol
good ole begginers
Old May 9, 2003 | 05:19 PM
Need4Speed1387's Avatar
Car: '86 IROC
Engine: 305 LG4 awaiting the crate Vortec 350
hmmm... how about so when you back out of the driveway and want to go forward, you know where the gear is, and you don't have to take time to think what you're in. i've though of making a sweet LED indicator or maybe finding an indicator assembly off some other car and rigging it or sumthin.....we'll see......
Old May 9, 2003 | 05:31 PM
The Beast's Avatar
I was'nt expecting to start a debate on this. I was and still am curious why there is no indicator.
Old May 11, 2003 | 04:30 PM
TekViper's Avatar
Car: 1990 Pontiac Firebird
Engine: 3.1L v6
Transmission: Automatic
after a while u just know where it is. park wont move, one click down is reverse and u can bump it down to neautral without pushing the button. once its in neutral it wont move back to reverse unless u hit the button so u can slam the shifter forward from drive and only fall into neutral. i just move it down one notch from neutral and im in drive. not hard, u dont need to look down at it even if it had an indicator.
Old May 11, 2003 | 07:31 PM
bubbakutz's Avatar
Engine: LG4
whats the purpose of shifting from neutral to drive....i quite dont understand the point
Old May 12, 2003 | 02:01 PM
The Beast's Avatar
Ok Ok... I understand the point that ashift indicator is NOT necassary, but it still does not anwser the question of why this paticular model does not have one!
Old May 12, 2003 | 10:51 PM
Agent13's Avatar
Car: 1983 Daytona Trans Am
Engine: LG4
Old May 13, 2003 | 12:18 PM
hotrod87camaro's Avatar
Car: 1987 Camaro Sport Coupe LT
Engine: 357
Transmission: turbo 350
Axle/Gears: 10 bolt posi, 3.73 gears
so you can be driving along, and shift into nuetral and rev it up at people
Old May 13, 2003 | 12:19 PM
Engine: 357
it does not have one, because it does not need one. but really though, mine doesn't either, and it is ok because i am used to it, but i think it should have one though.
Old May 13, 2003 | 02:35 PM
The Beast's Avatar
Yeah,, there's a good question.. what years did the birds and cams have a shift indicator? and while we're @ it! Why did they decide to not have them in some but not others... I mean my bird is a base model but... come on!
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
racereese
Oct 3, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
ndndndnd
Sep 28, 2015 08:00 AM
tattmann
Sep 27, 2015 05:20 PM
