Vents not working?
Old Jun 1, 2003 | 06:44 PM
Trandizzle's Avatar
Car: 1990 Trans Am
Engine: TPI 305
Transmission: 700 r4
Vents not working?
I have a 90 TA that I've had since september, when I bought it the AC vents weren't workin, but since winter was close I didn't pay much attention to it. Now since it is excessively hot I've started to notice this little problem again. When I turn on the AC or the heat, the vents don't work. All of the air comes out of the top of the dash, and the floor, but not the vents. What would cause this and how do I go 'bout a fixin it? Any information or help on this would be greatly appreciated!!
Old Jun 1, 2003 | 08:40 PM
1986redbird's Avatar
the air diverters are vacuum operated, there is a small plastic box mounted on the firewall in the engine compartment (about 3" wide and 7" long) check and see if there is vacuum on that. the default position for the diverters (without vacuum) is defrost.
Old Jun 2, 2003 | 04:21 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Ditto on that... Check For Vacuum Leaks... Mine was easy to find tho, right on top by the firewall...
John
Old Jun 3, 2003 | 11:42 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
any pics what it looks like??? Where is it located by the blower motor??? Mine sometimes coves through the vents the rest is through the defroster.
Old Jun 4, 2003 | 03:44 PM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
when you turn on anything in the system - heat, a/c, vent - do you hear any vacuum leak around the controls?
Old Jun 4, 2003 | 03:48 PM
okfoz's Avatar
They look like little tubes and they run all over in certain years.
Best thing to do is to start the engine, and listen for the above mentioned hiss. It sounds like someone shushing you... If you have a tube you can use it like a stethascope, put one end up to your ear and put the other end in other locations to try & locate the problem area...
John
Old Jun 4, 2003 | 05:49 PM
FAST RS's Avatar
when i turn themon i hear like a quick vacume suction then it goes away.
86White_T/A305
Aug 17, 2015 12:16 AM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
mizz0313
Aug 12, 2015 06:45 AM
mustangman65_79
Aug 11, 2015 03:17 PM
