door hinges/bushings
Old Jun 2, 2003 | 12:26 AM
pjd1959's Avatar
Car: 1983 Z28 (RED)
Engine: 305 HO
HELLO AGAIN:
My drivers door is sagging bad on my 1983 Z28. I read once there is a good replacement that has grease fittings for these hinges. Or is it easier to just to replace the busings???
thanks,
PAT
Old Jun 2, 2003 | 12:42 AM
jgifford's Avatar
Car: 1986 Z28
Engine: 355TPI 380hp
Transmission: Rebuilt 700r w/ Transgo Shift Kit
I'd say the question is not how easy it is, It's what it cost...
Here is the link to the kit with grease fittings.
You'd probably be better off replacing pins and bushings IMO.
Sorry, had to reword it.
Old Jun 2, 2003 | 09:54 AM
camaro6spd's Avatar
i put that kid on my camaro just a few weeks ago, i had to doors off so it made it much easier. We used a 5" High Speed Grinder and ground off the tops of the stock pins and punched them out, punched out the bushing and used 220 grit sand paper to clean the holes and make then nice for the new bushings.....it is not that easy, esp if you still have the door on the car....but there is not free play i my car at all, if i lift on the door i lift the car.
Old Jun 2, 2003 | 04:46 PM
Wootah's Avatar
Car: 88 Iroc-Z
Engine: 355ci
Transmission: WC-T5
Isnt there another way to do it, i mean i love that someone has made kits to fix the doors, but 80$ is alot of money to fix one door.. has anyone else fixed it themselves, and if so what did you go through to do so? Thanks for any info.
Old Jun 2, 2003 | 05:09 PM
dsaint1347's Avatar
I agree with Wootah. $80.00 is alot money for just one door, if he sold them both for $80.00 I'd bet he sell more. I know I would buy them.
Old Jun 2, 2003 | 05:18 PM
jgifford's Avatar
Car: 1986 Z28
Why not go to the parts house or Autozone, and just get 2 bushings and a pin for each door. I haven't checked yet, but surely the price has to be a lot better than that.
Old Jun 2, 2003 | 07:32 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
I copied and pasted my reply to a similar topic on chevytalk here:
Go to ebay.com and do a search for "GM door spring tool" I usually see cheap ones go for about $10, and will pay for itself the first time you use it.
Also, here are some tips from a tech that does this alot:
First, get some good quality masking tape and tape the front edge of the door and the rear edge of the fender. This will reduce the chance of chipped paint while removing and re-insalling the door.
Get new bushings and pins
To knock out the old pins, you can use a punch and tap them out. For pins that you can't get a punch on the end, you can grab the center of the pin with Vice-Grips and tap on the vice grips to remove the pin.
To install the new bushings, MAKE SURE you put the bushings in the same direcction they came out! It does matter!
BE VERY CAREFUL with the new bushings. They are very brittle. To install, I use a socket, wood paint stirrer, and channel locks. If the bushing intalls from the bottom up, I put the socket on top of the hinge, and put the bushing to the hole, then put the wood stirrer under it and sandwich it all together with the channel locks. The socket will allow the top of the bushing to protrude through the top of the hole w/o interference, the wood stirrer will allow you to put pressure on the bushing w/o chipping it and the channel locks will let you press the bushing it. You DO NOT want to beat on it! If the bushing installs from the top down, just invert the order. Put the socket under the hole and the bushing and wood up top. It has worked PERFECTLY for me every time!
Old Jun 2, 2003 | 10:53 PM
pjd1959's Avatar
Car: 1983 Z28 (RED)
Engine: 305 HO
Thanks for all the info here!!!
I'll probably take "GMTECH's" instructions and go buy that spring tool and put OEM bushings back in and keep some of my cash and use it for something else on the car.
PAT
Old Jun 17, 2003 | 08:55 AM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
I believe the bushings (or hinge pins) for the UPPER door hinge are not available from GM. Only a complete hinge assy is available from them.
Old Jun 17, 2003 | 07:16 PM
'89 superbird's Avatar
Andy is right, if the door is sagging it is the top hinge not the bottom and your only other option is to buy the whole hinge which is way too expensive and not the easiest of repairs either.
Old Jun 18, 2003 | 06:38 AM
fakeyankee's Avatar
Car: 87 T/A
Engine: LM1 350
Transmission: 700 R4
I just did my drivers side lower door hinge yesterday. You " DON'T" need the door spring tool !! Here is a quick tip for you guys/gals......... To get the spring back on, just fully compress the spring in a bench vise, leaving enough room to slip a length of heavy gaged wire through the inner side from end to end. Then twist the wire until it is tight. Slowly unclamp the vice and flip the spring 180 degrees and do the same on that side. Leave about 6-8 inches at the end of the twisted part so you can guide the spring where you want it placed in the door....then cut the wire with a pair of wire cutters and pull the wire out. The spring will expand and catch in its place. There you have it....spring in place and no money spent on tools !!!! Did it yesterday with out a hitch !!! Hope this helps out.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
86IROC112
Oct 9, 2015 10:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
kkirch15
Sep 30, 2015 04:44 PM
