How the #@&* is this water getting into my back seat?
Old Aug 6, 2003 | 02:34 PM
Paul Riccioli Jr's Avatar
Car: 89 IROC-Z
Engine: 383
Most of the time when it rains now I end up with water on the upright part of my passenger rear seat and on the seatbelt. How is it getting onto there??
I thought maybe it was the weatherstripping for the trunk but I don't think it would leak that high up.
I also tried checking the weatherstripping for the t-tops to see if it could be leaking back because the piece of plastic that goes across the top right infront of the hatch had some water on it the other day too. I didn't find any spots where it could be leaking though....atleast none that I saw.
Anyone have any ideas? I'm planning on getting new seatcovers sometime this year and I don't want my new onese getting water stains all over them like this seat now has!
Old Aug 6, 2003 | 02:40 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
T-tops:
If yes, check between the seal and the t-top bar and the seal and the roof panels, a little silicone might be in order. Also check the attaching points for the hatch hinges.
IF NO, Check the Hatch hinge attaching points.
Chances are its dripping from the plastic trim piece on the roof that covers the hatch bolts on the body.
good luck.
John
Old Aug 6, 2003 | 03:53 PM
Car: 89 IROC-Z
Engine: 383
I did have the hatch hinge bolts out once or twice in the last year. What should I use to seal those suckers up? Windshiled ribbon or something like that??
Also I do have t-tops, but like I said I already took a quick look at the seals all the way around. The weatherstripping is about a year old and the only problem I had was infront of the t-bar required some more sealant because I had water coming out of my visor holes.
Old Aug 6, 2003 | 04:19 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
Paul its goin to be ur Ttop weather stripping. my car does the same exact thing i fixed it for now by 2 car covers and i havent had leak in my car yet excupt when i get caught in a rain storm while i drive but thats it. but yeah its coming from the ttop weather stripping becuz it comes out from there and drips back and hits the plastic interior pieces and ends up on the seats.
Old Aug 6, 2003 | 06:17 PM
Car: 89 IROC-Z
Engine: 383
Yeah but where would the water be getting in from on the weatherstripping? I already checked infront and back. How can I check the center section? Where should I look there? I might try adding some more infront and back of the t-bar too.
Also I'll probably take the plastic piece off so maybe I can get a better look of the path it's taking.
Old Aug 6, 2003 | 06:56 PM
_max_'s Avatar
get in car have someone spray car with heavy stream of water and then figure what you need to fix =\
Old Aug 7, 2003 | 06:49 AM
okfoz's Avatar
Mine was leaking between the weatherstrip and the metal t-bar.
a little silicone and all fixed
John
Old Aug 7, 2003 | 07:24 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Mine leaked in the same place. I pulled up the black bar between the t-tops, siliconed around the holes in the roof, and put the black bar back. Been fine since.
Old Aug 7, 2003 | 08:57 AM
okfoz's Avatar
mine was actually leaking I believe between the seal and the bar itself. I removed the tops, masked everything off where I did NOT want silicone, and pulled back the rubber, squirted some 100% silicone in there and took some suranwrap and put it on the edge of the t-top, then I installed the t-top, the silicone ozzed a little, wiped with my fingers, let it set for a few hours. Removed the tops, and suran wrap... no more leaks...
John
Old Aug 7, 2003 | 09:52 AM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
I think you just solved you're own problem bro....
I once had a 1983 Z28 (no T-Tops) that leaked water in the same area you are indicating. If you had the hatch off recently (and it didn't leak prior to removing it), then chances are you broke the seal under the hatch bolt plates. Just remove the hatch again, unbolt the plates from inside of the car.... and supply a generous amount weather adhesive under the plates. You could also add some teflon sealant to those bolts if you'd like..... worked for me!
Old Aug 7, 2003 | 09:58 AM
bigals87z28's Avatar
Car: Check The Sig
i say hatch, only cause my ttops dont leak, and one day at work, i saw a good about of water leaking into the car from the hatch... with this weather and the sudden down pour, you can sit in your car and see where its coming from... it was my hatch.. apparently, i didnt close it right!!!! i opened and closed it and it hasnt leaked since... i get a drop or 2 when i wash the car and the water goes around the top of the passanger side window.
Old Aug 7, 2003 | 10:44 AM
91Zman's Avatar
Car: 1991 Z28
Transmission: 4L60 automatic
Mine had leaked from the hatch hinges and onto the rear seats,so I siliconed them and wa-lah.No leaks.
Old Aug 7, 2003 | 11:09 AM
billsfirebird's Avatar
Car: 1984 Pontiac Firebird
Engine: 2.5L Iron Duke 4 cylinder
Transmission: 5 speed manual
same here on a 91 ttop bird I used to own. No problemo. Now my 84 firebird, is another story.
Old Aug 7, 2003 | 11:29 AM
Car: 89 IROC-Z
Engine: 383
Do I have to take the whole hatch off or can I remove each bolt individually and add some sealant onto it?? I didn't remove them from he car side, just the glass side.
Old Aug 7, 2003 | 11:41 AM
91Zman's Avatar
Car: 1991 Z28
You can just remove the bolts,the nuts actually, from the car side and silicone the holes.
Old Aug 7, 2003 | 11:46 AM
If you just remove the nut's, then apply sealant to the stem's..... you might not solve you're problem. If it still leaks, then you'll just have to take it all off and start over again!
Don't take the easy way out.... do it right, this way you're SURE that the problem is fixed! Take those plates that support the top of the hatch off, and supply a generous amount underneath them. Then.... supply the bolts and nuts with thread sealant.
Fast355
Dec 2, 2016 06:33 PM
lee01
Apr 9, 2016 01:56 PM
Wylecoyote08
Nov 6, 2015 03:46 PM
lakeffect2
Aug 23, 2015 08:44 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
