leak on driver side floorboard
Old Aug 15, 2003 | 02:49 PM
kristopheer's Avatar
i got my ttop leaks fixed with silicon, and i know it isnt coming from the ttops.. after a hard rain, my whole driver side floorboard (where you put your feet at if your were driving) is soaked. i have no idea where this leak is coming from. any suggestions?
Old Aug 15, 2003 | 03:45 PM
armac's Avatar
Car: 83 ta
check the firewall were the wiring harness,steering coulmn ect is coming through. try spraying water on hte firewall and look for the leak then. also try pulling the black padding up and look ofr water track on the foam.
Old Aug 15, 2003 | 04:21 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
If you don't have A/C, then it may be leaking in from the vent just above your feet; make sure the drain areas on the sides of the cowl aren't plugged with leaves, etc.
Pete
Old Aug 15, 2003 | 04:22 PM
83Firebird420's Avatar
Car: 87 GTA 120,000k, 90 CRX Si
Engine: 5.7 TPI, 1.6L 16 valve SOHC
Transmission: 700r4, 5spd std
if your car doesnt have AC then it could be comming from the vent on the drivers side...my car has that problem its a bitch to get at even when u take the whole dash apart, i just gotta go take the time to fix it one of these days.
Old Aug 15, 2003 | 04:25 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Mine was leaking around/through the grommet that surrounds the wiring harness that passes through the cowl.
JamesC
Old Aug 16, 2003 | 04:45 PM
my car has ac, i will look at the firewall, thanks for the suggestions.
Old Aug 19, 2003 | 03:54 PM
rodrigo diaz's Avatar
Car: 92 rs
Engine: 5.0
Transmission: 5 speeds
check the grommet from the hood release cable , that was leaking in my car
Old Aug 24, 2003 | 07:02 PM
Belker's Avatar
Especially since you know you used to have a leak - this is a worthwhile way to spend some time .... pull up the carpet and look for holes in the floorboard. If you see any rust then now is the time to get it under control. If you wait you will regret your laziness. You may have a (or many) hole.
Old Aug 25, 2003 | 12:28 AM
crazycrocket's Avatar
Car: 1985 camaro
see behind the front wheel on my car where it is cut away... that may be your problem... mine was rusted out there and a good way down the rocker... funny thing is on my passenger side the area rusted could be filled in with a mig alone
Old Mar 23, 2005 | 10:54 PM
Tweaked's Avatar
Car: 88 t/a red w/body kit
Engine: 305tpi...355 carbed
mine leaks...it runs from the front of drivers side top. the water runs along the piler and goes along the door and then floods my friken floor....any ideas on what i can do
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
Street Lethal
Aug 14, 2015 08:25 PM
timonator
Aug 11, 2015 09:56 PM
wruiz
Aug 11, 2015 02:59 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
