strut towers
Old Sep 22, 2003 | 02:57 PM
strokedtpi's Avatar
Car: 1990 Formula 350
Engine: 5.7
strut towers
hey on my strut towers im started to see rust that in one spot has ate away a small hole...i was wondering what could be done in terms of replacement of the tower surroundings....am i forced to use salvage yard parts and weld them in or can i buy new and weld them in....thanks
Old Sep 22, 2003 | 03:22 PM
MechCD's Avatar
Car: '92 Camaro RS, '93 Ranger
Engine: LO3, Vulcan
Transmission: 700R4, M5OD
Axle/Gears: 2.73, 3.45
I'd say junk yard.......
I had my passenger side strut "cap" pop off towards the engine last week..... Some steel plate and bolts awa a I go.
I'd seriously weld in new or like new wheel wells if you can yank them from the junkyard.
I had my caps fixed and welded, and then the cap broke off... go figure.
Theres some scary pics somewhere on this board of what it looked like before the caps were fixed.
Old Sep 22, 2003 | 07:55 PM
RacerXWS6's Avatar
You do not want to have to get the tops off of another car. Its a time consuming pain in the butt. I have the same issue with my Formula, and went through the pain of taking the tops off of a friends totaled Trans Am. If you want a set to replace them Ill sell you the ones Ive already removed cheap. I went ahead and bought a hard top body to replace my rusted out formula. But if you do decide to remove a set from another car. A good drill, bit set, air chisel, and sledge hammer come in handy.
Old Sep 22, 2003 | 08:22 PM
Kandied91z's Avatar
any idea where those pictures are at? i'd like to see where it broke.
Old Sep 25, 2003 | 05:28 PM
strokedtpi's Avatar
Engine: 5.7
what would you want for them and do you have any pics of what youve got?
thanks
Old Sep 25, 2003 | 05:50 PM
RacerXWS6's Avatar
I dont have any pics of them, but I can take some this weekend if you want. As for price.... how about $30 + shipping?
Old Sep 25, 2003 | 07:15 PM
CaysE's Avatar
take it to PMs or email guys.
I too would like to see those pics.
Old Sep 25, 2003 | 07:21 PM
strokedtpi's Avatar
Engine: 5.7
i sent you a pm racer thanks again
Old Sep 25, 2003 | 07:43 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
lol, if you have some money and time, see if you can get a chassis fab person to makesome custom one to replace your wheel well... then just pop rivet ( or use quarter turn fasteners!) some sheet plastic in for fenderwells and you will have a stiffer, stronger, and hopefully lighter front end...
id like to do that someday..........
Old Sep 25, 2003 | 07:46 PM
strokedtpi's Avatar
Engine: 5.7
i dont think there is anywhere around here where i can get that kind of work done
Old Sep 25, 2003 | 07:50 PM
RacerXWS6's Avatar
hey i just replied to both your pm's... and dude that sounds trick, but in the end will it hold up to heavy cornering would be my major concern. oh strokd when you get these pics dont freak on the holes youll see in the pieces. every spot weld had to be drilled out and i believe there were 23 in each top.
Old Sep 25, 2003 | 07:58 PM
strokedtpi's Avatar
Engine: 5.7
you dont think it will hold up if i weld these new towers in??? or that custom idea..?
Old Sep 25, 2003 | 08:27 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
i think he ment my custom design..
and i think my idea is very dependant upon how its designed....
Old Sep 25, 2003 | 08:47 PM
RacerXWS6's Avatar
I was referring to Dude's idea. As for putting the new tops on heres what Ive come up with. The stock spot welds work well, but once removed and then redone I wouldnt trust it. Even with 23+ spot welds in it it worries me was once redone. I decided to respot weld everything and the run several stitch welds around the lip that folds over the tower. I think that should work.
Old Sep 27, 2003 | 03:42 PM
MechCD's Avatar
Engine: LO3, Vulcan
Heres the link to the pics of my poor firebird:
https://www.thirdgen.org/techbb2/sho...hreadid=189958
There is one about halfway down, and one on the bottom of the thread. I don't have any after repair pics
Old Sep 28, 2003 | 07:51 PM
strokedtpi's Avatar
Engine: 5.7
wow nice pics i dont htink mine look quite like that...lol....tough break there..
Ed1LE
Sep 30, 2018 09:14 AM
LT1Formula
Oct 8, 2015 08:34 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
tcflint
Sep 27, 2015 05:58 PM
