front clip question?
Old Oct 31, 2003 | 02:32 PM
MiscCamaro's Avatar
this might be a stupid question, but can a front clip with ground effects match up to a car that didn't come with any????mainly the parking lights and mounting holes.....do they match up the same????
Old Oct 31, 2003 | 04:22 PM
onebinky's Avatar
Yeah, but if you plan on useing the GFX, you'll have to drill the holes in your fenders. Not a big deal
Old Oct 31, 2003 | 08:32 PM
MiscCamaro's Avatar
just at the botom of the fender???& how many screws???-thanks
Old Oct 31, 2003 | 09:00 PM
89cmrodriver's Avatar
Car: 08 Sierra, 08 Silverado, 91 z28
Engine: 5.3, 4.3, 5.7
Transmission: autos
IIRC 2, unless u use the 91-92 gfx, then its 2 slots
Old Oct 31, 2003 | 10:40 PM
azcamaro's Avatar
Car: 1987 IROC-Z / 1992 Corvette
Engine: 305 TPI / LT1
The parking lights aren't the same. The SC type are smaller in size compaired to Z28\Iroc lights.
Old Oct 31, 2003 | 11:13 PM
onebinky's Avatar
Sorry, I thought he was asking if they were in the same vacinity for ease of wiring. My bad
It's just 2 bolts on either side like 89cmrodriver said.
Matt
Old Nov 1, 2003 | 01:17 AM
MiscCamaro's Avatar
so if i got the parking lights with the clip & ground effects, it would then match up????
Old Nov 1, 2003 | 02:04 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
From someone who has done the swap. Yes you can swap out a Sport coupe or berlinetta front end for a Z28, RS, or 88 SC front end. The upper nose will bolt on just fine "85-92 they are all the same" 82-84's are the same. Now the only difference inbetween the lower spoiler for the 85-92's is the chin desing and the side mounting hardware.
85-90 has 3 holes in the bottom of each fender for the side part of the spoiler to be bolted onto the fender.
The 91-92 spoiler sorta bolts on the same. I've never seen it in person but there are slilts on the bottom of the fender for the side part of the spoiler to be bolted onto.
I did the 85-90 gfx's swap on my 85 sport coupe. Its easy to do the Front nose and spoiler.
Your SC parking lights will not work with the new fisca, you need the light housings from the 85-92 design if you use that fisca and vise versa for the 82-84. The acutal light sockets that are attached to your wiring harness will work for those light housings.
Old Nov 2, 2003 | 01:02 AM
onebinky's Avatar
I was a 180 deg. flip from what you did
My fenders are 82-84, and the nose is off of an 89.
It really is a straightforward job though, you'll see once you get in there.
Good luck, and let us know how it turns out
Frozer!!!
Jan 19, 2024 04:55 PM
69 Six Pack
Oct 5, 2015 07:51 PM
Fronzizzle
Aug 17, 2015 02:52 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
