Installing locking floor storage COVER in car not orig equiped
Old Nov 6, 2003 | 01:54 AM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
Well fellas, I used to own an 86 Z and I really liked the locking cover setup. My iroc was not equiped with one and does not have those studs. So I was wondering rather than having to fab up brackets and what not, could I just drill some holes and use bolts to hold it down to the body? How much clearance is there between the body and the gas tank back there? Would it be worth it to make up some brackets and go through the hassle of welding them and everything? ANy ideas would be appreciated. My friend is donating a mint bose rear cover and I really wanna get it installed asap
Thanks guys
Will
Old Nov 7, 2003 | 12:06 AM
norcalz28's Avatar
40 views and not one reply.... ANYONE have any ideas? thanks guys
Will
Old Nov 7, 2003 | 12:21 AM
SuperTrans Man's Avatar
Car: Camaro
Engine: 5.slow
Transmission: 5 speed manual
you know sence u ask that i wanted to do the same for my baby but im not quite sure how it would work eather to be honnest but it looks fairly easy but the locking part might be the tricky thing i bet u could bolt it in but again the lock might give ya some trouble....
Old Nov 7, 2003 | 12:30 AM
strokedtpi's Avatar
Car: 1990 Formula 350
Engine: 5.7
i believe there is a separat rear panel (covering the hatch motor and such) fo the lockin tab...it has a little tab or somethin on it i had an 83 z28 with that set up i hung on the everything but that panel ...
Old Nov 7, 2003 | 06:35 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
There's a how-to article on this site.
JamesC
Old Nov 7, 2003 | 08:55 AM
bnoon's Avatar
Car: 2008.5 Mazdaspeed 3 GT
Engine: 2.3 DISI Turbo
Transmission: 6 speed MT
http://www.members.***.net/iroczdave1/
I've worked with Dave for an overhead T-top console and his customer service was great! Looks like he has the parts to do what you need on his site too as long as your interior color matches...
Old Nov 8, 2003 | 04:07 PM
norcalz28's Avatar
I already have both pieces, My question is how to I get the cover, the one that swings up and down, to bolt to the body of the car??? I havae the lock mechanism and all that crap, just need ideas on how to secure the cover itself to the body of the car.
Will
Old Nov 8, 2003 | 05:10 PM
JamesC's Avatar
I believe GM still sells the bracket(s) (which has a bolt coming through it and which were spot welded to the car itself) I think I still have the hardware--nuts and covering cap somewhere.
JamesC
Old Nov 9, 2003 | 08:36 AM
azcamaro's Avatar
Car: 1987 IROC-Z / 1992 Corvette
Engine: 305 TPI / LT1
Ebay>>>>
http://cgi.ebay.com/ebaymotors/ws/eB...category=33705
not sure if this is for the cargo cover or shade:
http://cgi.ebay.com/ebaymotors/ws/eB...category=42612
Old Nov 9, 2003 | 04:32 PM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
I have done this conversion. You will need the brackets from the (or a) doner car. The brackets are only spot welded to the body and a spot weld remover must be used to remove them. MAC TOOLS makes a nice one that does not drill a pilot hole through the body. The two hinge brackets are spot welded to the body near the fule tank hump, and the latch bracket is spot welded near tail lights. I took careful measurements and had the brackets tacked in place with a MIG welder in place and installed everything to test the fit. It it was OK so we finished welding them in place. The rearmost trim piece must also be changed to accomodate the locking floor.
I suggest you get these brackets, etc. from the car the panel came from.
andyZ28
Old Nov 9, 2003 | 10:11 PM
ES87iroc's Avatar
Car: 1987 Camaro Z28 IROC-Z
Engine: 5.7L TPI
Axle/Gears: 3.42:1
Hate to sound overly simple, but just use some self taping screws and call it a day, nothing complex. Worked fine for me.
Old Nov 10, 2003 | 08:42 AM
azcamaro's Avatar
What good is a locking compartment, if all you have to do to break into is unscrew a few screws?
Old Nov 10, 2003 | 11:16 AM
ES87iroc's Avatar
Engine: 5.7L TPI
Axle/Gears: 3.42:1
Umm, have you ever looked at one of these?
The screws would be inside the compartment when it is closed. Just as the stock bolt heads would be. No difference.
Old Nov 11, 2003 | 07:21 AM
azcamaro's Avatar
No, I haven't looked at one. I have been thinking of getting one. Now I know you don't really need to use the brackets, thanks.
Old Jan 3, 2004 | 06:32 PM
PhAnToMs's Avatar
Car: 1984 Z28
Engine: 5.7
Transmission: Auto w/ shift kit
i just picked one up at the junk yard its covered in greese and a driver side seat belt for 12 bucks took it home riped the rug off spay painted it bought some felt for it went to hardware store got some self tappin sheet metal 1/2 inch screws to mount plan on doing it tomorrow dont really care about the lock just got it there to cover subs but the lock would be nice when subs are under it special lock for your subs WOOHOO but i dont think im doin the lock
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
1nastygta
Oct 28, 2015 08:51 PM
mx127
Aug 10, 2015 08:13 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
